Old 09-17-2013, 08:50 PM   #15
thebus
Drives: Whiteout
Originally Posted by Decay107 View Post
I was under the impression that some people had issues with removing the resistor? Something about the side mirror adjustment motors no longer working?
Oh really? crap when did it start happening to people, I haven't had an issue yet and I did the same to my fj no issues...
thebus is offline   Reply With Quote
Old 09-17-2013, 08:55 PM   #16
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I'm not sure if/when it started happening, but I read about some having the issue in the Resistor Removal DIY thread. I thought it was easier to just go through techstream.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
thebus (09-17-2013)
Old 09-17-2013, 08:58 PM   #17
thebus
Drives: Whiteout
When I bring my car in for service ill have them disable it just in case... Time to research! Thanks!
Old 09-17-2013, 11:01 PM   #18
benlaz88
Drives: 2013 Asphalt FRS
Originally Posted by JohnJuan View Post
Are your headlights on? I believe the DRL's turn off when you turn the headlights on.
Yes my headlights was off
benlaz88 is offline   Reply With Quote
Old 09-17-2013, 11:04 PM   #19
benlaz88
Originally Posted by Mikegraves777 View Post
Please let me know ur solution
ya def, i mean DRL not working it doesn't bother me however i just want everything working since is a new car.
Old 09-17-2013, 11:08 PM   #20
benlaz88
oh ya i forgot to mention, i think is start not working is when i hardwire my radar into the fuse (i just guessing, didn't pay attention to that until i notices). I'm sure hardwire doesn't make the DRL not working because i did unplug the fuse for the radar to see if that cause the problem and the solution is not.
Old 09-18-2013, 01:45 AM   #21
Well, benlaz88, I'm guessing your problem is in that area. How did you tap into the fuse circuit?
If you used a "add-a-circuit" type thing, did you install it the "proper" way? Best I recall ...one can put them in backwards ...
Old 09-18-2013, 10:32 PM   #22
benlaz88
well i put a spare fuse in the empty socket and use my hardwire kit to tap it with it. The fuse is insert properly.
Old 09-19-2013, 08:56 PM   #23
benlaz88
Please let ,e know what u find out about this issue mine stopped working when I first got car and yes my power mirrors do not work I checked fuses relays and even replaced stupid resister still nothing I don't care about the drl jus would like power mirrors to work sometimes
Problem solve. I change it to a 20amp fuse under the DRL socket and its work! I hope this will help you solve your problem too!
Old 09-19-2013, 08:58 PM   #24
Yellow13
Yellow13's Avatar
Drives: 2013 6MT Asphalt FR-S
I removed the DRL resistor from behind the bumped and had NO issues what-so-ever. Its also a heavy ass resistor, pretty crazy.
Yellow13 is offline   Reply With Quote
First problem with the STX Brz Simmons Tracking / Autocross / HPDE / Drifting 94 06-23-2014 12:05 AM
Has anyone have this problem....... CSI:86 Issues | Warranty | Recalls / TSB 29 06-17-2013 09:29 AM
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 12:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 02:31 PM
