Old 09-16-2013, 06:22 PM   #1
benlaz88
Drives: 2013 Asphalt FRS
DRL problem
I just found out that my DRL is not working after i let go off my ebrake. I also checked the DRL fuse that was label in the fuse box, and the fuse look fine. I alsos checked to see if the high beam work and it does so it can't not be the bulb problem. Anyone has this problem before?
benlaz88 is offline   Reply With Quote
Old 09-16-2013, 06:46 PM   #2
stugray
Drives: 2013 GBS BRZ Limited
They can be disabled in the ECU.
Are you the original owner?
Unlikely to be disabled by the dealer.
Old 09-16-2013, 06:56 PM   #3
benlaz88
The DRL was working fine before. I just found yesterday that is not working for some reason. I guess i will wait until my next service and tell them that as well.
Old 09-17-2013, 01:45 AM   #4
I haven't experienced that ..... but, I would suspect that the little "switch thing" in, or connected to, the e-brake is acting up.
I'd make sure your e-brake handle is going all the way down ... maybe even push it down a bit.
Old 09-17-2013, 11:49 AM   #5
benlaz88
ok, i will give that a try and let you know.
Thanks!
Old 09-17-2013, 01:44 PM   #6
benlaz88
I try and push it down, still no luck
The Following User Says Thank You to benlaz88 For This Useful Post:
Frstorm (09-17-2013)
Old 09-17-2013, 04:29 PM   #7
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Are your headlights on? I believe the DRL's turn off when you turn the headlights on.
JohnJuan is offline   Reply With Quote
Old 09-17-2013, 06:03 PM   #8
PR FR-S
Drives: 2013 FR-S, Asphalt
I want this problem to happen to my car...
PR FR-S is offline   Reply With Quote
Old 09-17-2013, 06:09 PM   #9
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
You are aware that you can turn your DRLs off pretty easily via software using techstream right?
Decay107 is offline   Reply With Quote
Old 09-17-2013, 07:56 PM   #10
thebus
Drives: Whiteout
Or just disconnect the resistor under passenger head lamp there is a DIY on here that I followed
thebus is offline   Reply With Quote
Old 09-17-2013, 08:28 PM   #11
Decay107
Decay107's Avatar
I was under the impression that some people had issues with removing the resistor? Something about the side mirror adjustment motors no longer working?
Old 09-17-2013, 08:36 PM   #12
Mikegraves777
Drives: 2013 Scion FRS
Please let ,e know what u find out about this issue mine stopped working when I first got car and yes my power mirrors do not work I checked fuses relays and even replaced stupid resister still nothing I don't care about the drl jus would like power mirrors to work sometimes
Mikegraves777 is offline   Reply With Quote
Old 09-17-2013, 08:37 PM   #13
Mikegraves777
Please let me know ur solution
Old 09-17-2013, 08:48 PM   #14
Decay107
Decay107's Avatar
For you I would double check that the resistor is connected and grounded properly. Sounds like that is where your problem is coming from.
The Following User Says Thank You to Decay107 For This Useful Post:
Hardrock4445 (09-19-2013)
First problem with the STX Brz Simmons Tracking / Autocross / HPDE / Drifting 94 06-23-2014 12:05 AM
Has anyone have this problem....... CSI:86 Issues | Warranty | Recalls / TSB 29 06-17-2013 09:29 AM
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 12:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 02:31 PM
