Old 09-11-2013, 12:08 AM   #43
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by solidONE View Post
I was thinking more about the amount of camber gain (probably negligable to begin with) u der compression. Less camber gain under compression with bolts vs plates, no?
Ah, yeah, that would probably be true. It seems small, but how much, I have no idea... quick someone plot up the camber curve of this car and see what the sensitivity to baseline SAI is...
Wepeel is offline   Reply With Quote
Old 09-11-2013, 12:35 AM   #44
ayau
Drives: Some rust bucket
Clearance of the 245's with 5mm spacers installed. Note the upper SPC camber bolt is zinc coated and silver in color.
Spacers, hubcentric:
This is the type of road I typically run on when not commuting.
http://s174.photobucket.com/user/sol...43611.mp4.html
this is with the stock tires and both camber bolts installed. TC on. A lot of intervention as the tires were breaking away easily with the swift springs installed. Kicked up a pice of asphalt bigger than my fist at about 0:19 into the "lap".
Your 245 tires haven't rubbed against the front lower spring perch?
I have 17x7.5 +50 on 215/45/17. After a track event, I noticed the inner tire rubbed against the lower spring perch. I have -1.5 and -1.7 front camber with OEM crash bolts.
Old 09-11-2013, 02:17 AM   #45
mfbmike
Drives: 2013 FRS, 2008 R32
Sounds like those having serious rust issues with the SPC bolts are up north. I have a set on the way but live down here in south Florida.
Any suggestions on rust prevention for SPC camber bolts i.e. spraying them down with never-wet or something?
mfbmike is offline   Reply With Quote
Old 09-11-2013, 11:30 AM   #46
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I just added the second set of bolts this past weekend. Made some rough measurements. I was able to get 2.6* at the front with 1" drop and 2 sets of SPC bolts. Surprisingly little bit of toe in after the mod, about 1/32". If you run wider wheel/tire you might want to check your clearances. I added a 5mm spacer to my 245/40/17 @+45 wheels and still have clearance issues. Camber plates will not have this problem.
Above.
Old 09-11-2013, 02:03 PM   #47
solidONE
solidONE's Avatar
That's actually not a bad idea, rust proofing it. I'm not sure what never-wet is, but coating the threads on a bolt might cause some problems during instal and removal.
Old 09-11-2013, 03:55 PM   #48
mfbmike
[ame="http://www.youtube.com/watch?v=DZrjXSsfxMQ"]NeverWet Arrives - Hands-On Product Demonstration - YouTube[/ame]
I thought the same about install and removal of said bolts.
The Following User Says Thank You to mfbmike For This Useful Post:
solidONE (09-11-2013)
Old 09-11-2013, 05:40 PM   #49
solidONE
solidONE's Avatar
Oh wow! That's a very nice product.
Old 09-11-2013, 10:08 PM   #50
ML
ML's Avatar
Drives: 13 White MT FR-S
are these the 14mm bottom bolts?
http://ft86speedfactory.com/spc-camb...front-776.html
I have had the 16mm Whiteline bolts installed for about 6 months, and still holding good and no rust. (also have a set for sale if you need them)
Old 09-11-2013, 11:00 PM   #51
solidONE
solidONE's Avatar
No. Those are the 16mm bolts that replace the uppers and the same exact bolts you get from whiteline. The part you need is SPC #81260 for the 14mm bottom bolts.
The Following User Says Thank You to solidONE For This Useful Post:
ML (09-12-2013)
Old 09-11-2013, 11:03 PM   #52
solidONE
solidONE's Avatar
How thick a coating does it leave per application? If it is thinner than paint I would not hesitate to use it on the bolts and steering knuckle or anything else cast iron or steel for that matter.
Old 09-11-2013, 11:12 PM   #53
red-frsky
frstrm-frs
Drives: Red FR-S
I installed the whiteline 16mm bolt last night and adjust it to negative camber but my wheels are are rubbing against the struts. My setup is stock struts with Eibach Sportlines springs on 18x9.5 rims on 225/35/18 tire, the tires have a little clearance but the rims are rubbing against the struts so this setup will not work! Have to run positive or no camber which is hideous on 9.5 rims sticking out on the front im waiting to switch out to coilovers with camber plates.
red-frsky is offline   Reply With Quote
Old 09-11-2013, 11:25 PM   #54
solidONE
solidONE's Avatar
If you have anything more than maybe +35 offset on rims that wide, you'd have problems with clearance. you can do what I did and add a pair of spacers for clearance. Rulers are your friends.
Old 09-12-2013, 12:03 AM   #55
mfbmike
Doesn't appear to leave a thick coating at all. Look at some of the product it is sprayed on. You don't even see it.
Old 09-12-2013, 12:34 AM   #56
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
Ive gotten -9 degrees up front by notching the top hole plus using camber bolt in top hole. Bottom hole is left as is, oem bottom bolt. (Also camber plates maxed out up top)
Cheap way for camber on our mcpherson setup is top hole notch, although this brings the strut very close to the inner wheel well, might have clearance issues if not on coilovers
SLICVIC is offline   Reply With Quote
The Following User Says Thank You to SLICVIC For This Useful Post:
nix (09-13-2013)
camber adjustment SMOKETREES Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-26-2013 04:39 PM
regarding camber adjustment aruxe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-10-2013 01:02 AM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
KW V3 camber adjustment olorin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-28-2013 04:46 PM
