Old 08-12-2013, 07:08 PM   #127
pmccut
Drives: Blue Subarus
Originally Posted by whitefrs View Post
IMO
I would go with a diferrent tuner
I don't have many options. E-tuning obviously didn't work out well for me. Local dyno tuning is a massive improvement, for sure.
I just went home and found some 1000cc injectors from LJ. I think we can take another stab at dyno tuning this with LJ as these are the injectors he uses on his E85 builds. Thanks LJ!
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 08-12-2013, 07:16 PM   #128
Frs300
Frs300's Avatar
Drives: Pile of junk
IMO
your opinion doesnt really hold water. this is the 3rd or 4th tuner you have tried and you have yet to get a car that runs correctly
Frs300 is offline   Reply With Quote
Old 08-12-2013, 07:19 PM   #129
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I am on my 2nd tuner too.
Old 08-12-2013, 07:20 PM   #130
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
My car is perfect
I didnt have mechanical issues
My fuel trims are 0 to 2.2
Before they were like -25
No problems whatsoever
Old 08-12-2013, 10:21 PM   #131
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Originally Posted by pmccut View Post
I didn't notice the 'Correction Met Fly Wheel' until now. The stock graph shows the same and is 140hp, so I hope this is really whp and not inflated. I'll have to get one with stock power on the same graph.
Here's the old stock vs turbo map.
Nice dude!
Take me for a ride sometime!!!!!
clayrush is offline   Reply With Quote
Old 08-12-2013, 10:35 PM   #132
Ross
Drives: 85 corolla gts
I have seen odd graphs produced from people using dynapacks before but you really need to see what is going on at your 4k to 5k. It is ither pulling timing. Some odd boost fluctuations, or air fuels are jacked. As well your trims should be no were near that far off. By no means am I trying to bash anyone but your tune is far from complete. Please do not beat on it to much until you figure out what is going on.
Ross is offline   Reply With Quote
Old 08-12-2013, 10:37 PM   #133
Ross
Also what is your commanded cam timing in the 4k to 5k area?
Old 08-12-2013, 10:40 PM   #134
pmccut
I believe it's mostly the pig rich tip-in. I'm barely driving it at all, not my dd.
I'm going to try and find some time on their dynapack to let LJ do his magic with the 1000cc injectors.
Old 08-14-2013, 01:29 PM   #135
mad_sb
Drives: 2013 Asphalt FR-S
.. I have talked to many tuners now, and it seems that getting the injector scaling correct for these Bosch 550cc injectors is not easy.
it would be if anyone would bother to install them on a stock pump gas motor before going FI. I'll probably go that route (fuel pump and injectors on NA engine) before installing a charger next year just so i can nail down the injector scaling before adding boost into the mix.
The Following User Says Thank You to mad_sb For This Useful Post:
pmccut (08-14-2013)
Old 08-16-2013, 08:09 AM   #136
mad_sb
ll
Yup, sure seems to be. I read over one of your good tuning threads and this seems to jive. He's going to try and adjust the MAF scaling on direct injection tonight, as he said the port fuel trims don't seem to be a problem.
It's good he is looking at the trims under all 3 conditions (port only, direct only, both), at least it sounds like he is. If you log the correct parameters you can easily tell which set of injectors needs to be tweaked.
If you guys get stuck feel free to hit me up..
Sportsguy83 (08-16-2013)
Old 08-16-2013, 02:21 PM   #137
pmccut
At my second home (WORKS). We're going to swap the wastegate spring (red+green=15psi), swap to the 1000cc injectors LJ@FullBlown sent me, back to the stock MAP sensor, and do some remote dyno tuning with LJ. Hopefully there will be some good news this time
Old 08-16-2013, 02:41 PM   #138
Ross
Why use the stock map sensor if you are going for more boost?
Old 08-16-2013, 02:43 PM   #139
pmccut
Were going for whichever fullblown prefers. I believe they use the stock MAP sensor for their E85 builds.
Old 08-16-2013, 02:45 PM   #140
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
4bar is the beat
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Richmond VA Dyno Day Results 5/4/13 vtmike Engine, Exhaust, Transmission 86 09-17-2013 02:34 PM
Interesting Dyno Results Gen Forced Induction 86 07-31-2013 08:45 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
