Old 07-21-2013, 01:35 AM   #1
pmccut
Drives: Blue Subarus
Thumbs down pmccut's FBM dyno results
Just picked my car up from WORKS motorsports in Sonoma, CA after adding some goodies: ClutchMasters FX300, Perrin engine mounts, Perrin rear shifter bushing, and Perrin transmission support mount.
I'm e-tuning with Visconti. This is the fourth map so far. The fuel pump (dw 65c) had 2 o-rings and no white spacer originally, so I added a third myself, and WORKS just added the 4th before this dyno run.
I'm waiting on FullBlown to send over a map for the 3BAR sensor as well, and plan to see if LJ can get the car running OK.
The dyno run is absolutely terrible - 179hp, 180lb/ft
Here's the really worrying plot - boost/afr.
Right before the car goes into boost it goes really lean, then super rich.
I have yet to drive this car fast, or even on a fun road. Someone keep my hopes up please
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 07-21-2013, 01:52 AM   #2
wootwoot
Drives: FRS
Seems like a tune issue. No worries. Talk to John about it. I am sure he will get you running tip top in no time.
wootwoot is offline   Reply With Quote
Old 07-21-2013, 01:54 AM   #3
sw20kosh
Drives: 2013 Black FR-S
Why don't you flash in the base tune that Full Blown supplies with the kit?
How long has the car been in this condition (waiting for a proper tune)?
Old 07-21-2013, 02:05 AM   #4
husker741
Considering another Full Blown kit hit 13.7 with stock tires, it has to be the tune.
husker741 is offline   Reply With Quote
Old 07-21-2013, 02:06 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The results really are all in the tune. I don't know what to say because my Visconti tune was running nearly twice the boost you are running.
The Following User Says Thank You to King Tut For This Useful Post:
Sportsguy83 (07-21-2013)
Old 07-21-2013, 02:36 AM   #6
pmccut
The base tune I had from fullblown was for the stock MAP sensor. I emailed LJ on Thursday for a new tune. Ill bug him again on Monday.
Old 07-21-2013, 02:43 AM   #7
Gen
Drives: Scion FR-S
Have you considered going to someone closer to you to do your tuning? It's a bit easier than the back and forth stuff. I know I had some issues with the fuel pump myself.
91 base map isn't that great either to be honest. Red line is base. I was thinking I was going to need to upgrade the clutch--not so much. (dyno dynamics)
After a bit of tinkering this is the best that we could get out of 91 octane and a stock exhaust. California gas is crappy. A bit more than what the innovate kit puts out on this dyno. (mustang dyno)
Wasn't he on 10+ psi and E85? I know he has a built engine with 9.5:1 compression, so not exactly a straight comparison...
Gen is offline   Reply With Quote
Old 07-21-2013, 03:14 AM   #8
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
listen to King Tut. hes got his FBM kit running great at 320WHP and 260WTQ (give or take)
lbroskee is offline   Reply With Quote
Old 07-21-2013, 03:22 AM   #9
suaveflooder
Looks like you are local! Where are you located? I have to see your car please!!!
suaveflooder is offline   Reply With Quote
Old 07-21-2013, 03:26 AM   #10
Gen
Drives: Scion FR-S
Dude, you've met me! I'm pretty sure you were at Stone. I'm out in Escondido. You're welcome to swing by any time.
Old 07-21-2013, 03:27 AM   #11
suaveflooder
No, I wanted to go, but couldn't get anyone to work for me I hate my life
Old 07-21-2013, 03:35 AM   #12
dabocx
dabocx's Avatar
Drives: Scion FRS
The back and forth is going to take some time, hopefully it wont be too long and you can get that running smoother.
The pump that comes with the full blown kit also needs the spacers? Where can I pick those up?
dabocx is offline   Reply With Quote
Old 07-21-2013, 05:41 AM   #13
pmccut
I certainly considered it. The owner of WORKS does ecutek/brz tuning, but he hasn't done a FBM kit yet. I went with Visconti since I plan to switch to E85 as soon as I make sure I have a good 91 map to fall back to. I imagine I'll go the flexfuel kit as well.
I haven't actually seen anyone posting good power levels for these kits on 91. I really just want to see my AFRs around the appropriate area, so it doesn't have knock correction everytime you enter boost - crazy. Can't wait for some corn
Old 07-21-2013, 05:43 AM   #14
pmccut
I believe you're supposed to use the one from your OEM pump. I just took my FBM pump w/ OEM spacer out of my trunk when I got the car back today. Wish it had fit as well as the DW65c.
86 Dyno results Anban AFRICA 18 01-14-2014 07:54 AM
Richmond VA Dyno Day Results 5/4/13 vtmike Engine, Exhaust, Transmission 86 09-17-2013 03:34 PM
Interesting Dyno Results Gen Forced Induction 86 07-31-2013 09:45 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 11:45 PM
