Old 05-24-2013, 12:49 PM   #1
Gen
Drives: Scion FR-S
Interesting Dyno Results
91 Octane
Stock Exhaust
FBM base kit
base map vs tuned
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
DesertFrs (01-25-2014)
Old 05-24-2013, 12:51 PM   #2
nonicname
Drives: it has 4 wheels and a motor
why? because of the low power achieved?
nonicname is offline   Reply With Quote
Old 05-24-2013, 12:57 PM   #3
xwd
More details?
Old 05-24-2013, 01:00 PM   #4
Gen
Drives: Scion FR-S
Curve seems strange to me--seems to run out of steam pretty quickly at 6500 and less linear than other examples I've seen.
Power was definitely lower than I expected, but stock FRS tend to dyno around 140 on this particular dyno.
Old 05-24-2013, 01:18 PM   #5
2forme
Looks like you have a boost leak....
The Following 2 Users Say Thank You to 2forme For This Useful Post:
Gen (05-27-2013), Shawnofthedead (09-12-2013)
Old 05-24-2013, 01:26 PM   #6
sw20kosh
Drives: 2013 Black FR-S
I would definitely do a boost leak test on the whole system. Doesn't look right.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
2forme (05-24-2013), Gen (05-27-2013)
Old 05-25-2013, 01:27 AM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did you get any datalogging of your boost curve? Something is definitely going wrong at 6500 RPM. You are either losing a ton or boost, or knocking and pulling timing.
The Following User Says Thank You to King Tut For This Useful Post:
Gen (05-27-2013)
Old 05-26-2013, 02:17 AM   #8
Gen
Drives: Scion FR-S
Looks like you guys may have been right. The weld where the MAF sensor is installed had several leaks in it. I'll try and get back on the dyno here soon.
Old 05-26-2013, 02:30 AM   #9
whataboutbob
AutoX-10/10ths every run
How did you find the leaks?
Build thread:Here
Old 05-26-2013, 02:32 AM   #10
Gen
Drives: Scion FR-S
Built a boost leak tester and hooked it up to a compressor. Tester looks like this:
Immediately I could hear air leaking around the maf sensor and I was only reading about 3 psi on the gauge. After spraying soapy water I could see bubbles forming on the weld. Thankfully I don't think it's anything a little JB weld can't handle for the time being. It was the last thing I thought would leak.
The Following 4 Users Say Thank You to Gen For This Useful Post:
Calum (05-26-2013), Pete (05-26-2013), Sportsguy83 (05-26-2013), whataboutbob (05-26-2013)
Old 05-26-2013, 10:30 AM   #11
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
this. Are you data logging on the dyno?
448hpsti is offline   Reply With Quote
Old 05-26-2013, 01:20 PM   #12
Pete
Pete's Avatar
Drives: 22 BRZ
Good advice, problem located, problem solved. I love this club.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following 3 Users Say Thank You to Pete For This Useful Post:
Sportsguy83 (05-26-2013), suaveflooder (07-21-2013), Tim_Asphalt_FRS (05-26-2013)
Old 05-26-2013, 11:01 PM   #13
FA20Club.com
Drives: 2013 White Out FR-S
thats sucks, back to the rollers we go. at least you seemed to have found the leak.
FA20Club.com is offline   Reply With Quote
Old 05-26-2013, 11:41 PM   #14
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
My car made 134.5 stock on that same dyno.
tom@kartboy is offline   Reply With Quote
86 Dyno results Anban AFRICA 18 01-14-2014 07:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Compilation of Dyno results somewhere??? Scooby South Engine, Exhaust, Transmission 3 01-08-2013 07:51 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 11:45 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 11:15 PM
