Old 08-05-2013, 05:35 PM   #43
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Seems like he kinda just disappeared after visconti burned down his car.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-05-2013, 09:11 PM   #44
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I have the FF kit mentioned and I also ran into a rather large fuel leak when the seal between the car's metal hose and the replacement hose from the kit lost it's seal. I was lucky enough to catch it in time, and have it towed to be fixed.
I'm betting was on that vehicle, the kit came with the hoses provided were not a decent match from the metal hardline to the e85 sensor that's installed - it attempts to make a seal with a replacement hose with a larger inner diameter and thinner side wall - which made the clamp the only failure point (in these applications from what I've read the clamp is in place only to stop the hose from backing out over the bung - the raised lip of the metal is what's actually creating the seal)
At any rate, John has changed this in the kits he's now selling (at least for US Customers) so there's a screw on fitting that goes over the metal hose on the car - no more need for a seal between rubber and metal. As for me, I got the hose in the kit replaced so it looks closer to what the stock rubber hose looks like, just mated to a different connection for the e85 sensor - you can see pictures in the DIY thread. I hope no one else from the initial kit buy has to deal with this.
mikalem is online now   Reply With Quote
Old 08-05-2013, 09:21 PM   #45
Dezoris
Dezoris's Avatar
Thanks for the update. Moral fuel system changes need to be designed, installed/tested with great care.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
enouf (08-05-2013), Sportsguy83 (08-05-2013)
Old 08-05-2013, 09:36 PM   #46
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
^^ This X1000
Since day one I have been hesitant regarding the FF kit because an error in install can be so devastating.
Old 08-05-2013, 09:39 PM   #47
Calum
That Guy
Drives: 2013 asphalt FRS MT
The forum automatically breaks links to that forum, but we can work around that.. (wink, wink)
@Calum
http://goo.gl/ypoeIJ
Jesus.
The Following User Says Thank You to Calum For This Useful Post:
Old 08-05-2013, 10:48 PM   #48
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
And that's the reason why I've harassed Rich@ViscontiTuning in the Visconti FF thread for charging money for the upgraded fitting. The upgraded fitting should have been sent out asap and free of charge, especially when your customers physcial safety is on the line.
Would be interesting to hear back on what happened in this case - if it was due to a hose leak, then all hell would break loose.
enouf is offline   Reply With Quote
The Following 2 Users Say Thank You to enouf For This Useful Post:
civicdrivr (08-06-2013), Turbowned (08-09-2013)
Old 08-05-2013, 11:02 PM   #49
Foobar
SLO NO MO
Foobar's Avatar
I'm actually surprised he posted any of this info to begin with after going through insurance. I suspect they would have a problem if they determined the fire was caused by a botched aftermarket install that he performed.
Sent from my Nexus 4 using Tapatalk 2
Old 08-06-2013, 12:50 AM   #50
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
This isn't worth much, but from what I was told on Friday the fire chief was still investigating the cause of the fire.
Its definitely fuel related though.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Sportsguy83 (08-07-2013)
Old 08-06-2013, 08:21 AM   #51
Sportsguy83
Drives: Limited BRZ
My friends, we will never know the real reason this happened. Think about it. It would help no one sell more parts $$$.
Old 08-06-2013, 08:38 AM   #52
Foobar
SLO NO MO
Foobar's Avatar
Agreed. I think the only update anyone would want to disclose publicly for liability reasons and continued parts sales would be "OEM failure with nothing to do with any aftermarket mods."
The Following User Says Thank You to Foobar For This Useful Post:
Sportsguy83 (08-06-2013)
Old 08-06-2013, 08:40 AM   #53
Sportsguy83
Drives: Limited BRZ
^^ Exactly and that might actually be the reason, who knows..... But I am pretty sure that if the problem was "fuel leak due to issues with FF kit" we would still be told the above story.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Bahraini86 (08-06-2013), enouf (08-06-2013), Foobar (08-06-2013)
Old 08-07-2013, 10:44 AM   #54
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Yeah it's sad we're not going to hear a thing about the cause. Swept under the rug and more kits by just blaming user install for a poor design.
Nolan
pheoxs is offline   Reply With Quote
Old 08-07-2013, 12:26 PM   #55
Sportsguy83
Drives: Limited BRZ
According to Visconti
Not sure why you would post such a thing. The car that had a fire burnt up from the mechanical fuel pump.. Those are the insurance company's words not mine.
John
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Foobar (08-07-2013)
Old 08-07-2013, 01:17 PM   #56
xjohnx
Grip>Slip
xjohnx's Avatar
If it was an OEM equipment failure then I certainly hope that an NTSB report/investigation has been started. Then again I doubt the insured was exactly jumping at the bit to mention the aftermarket fuel system modifications to the insurance adjuster.
Vortech Visconti Tuned on BRZ Limited v1ru5 Member's Car Journals 85 01-08-2015 01:09 PM
Vortech Visconti tuned on ft86me ft86me Forced Induction 38 08-25-2013 09:00 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
