Old 07-22-2013, 02:27 AM   #29
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Originally Posted by clayrush View Post
kinda like his prototype kit as well.
if all goes well, the final production kit will debut at 86fest
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
clayrush (07-22-2013)
Old 07-22-2013, 03:01 AM   #30
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
We gonna hold out for somthin bigger than the stage 0. and I need a full time job again.
clayrush is offline   Reply With Quote
Old 07-22-2013, 03:11 AM   #31
ft_sjo
Drives: GT86
Why did you put it on a dyno if you didn't feel it was running right?
Old 07-22-2013, 09:45 AM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by pmccut View Post
Now the bad news...switched to map 2. I tried going into boost a couple times and noticed my AEM failsafe didn't show any AF/R readings, as if it was outside of the 10-18 range it can read. Ok..headed home to review logs. Driving on local road, 25ish mph..heard a loud POP sound. Sounded really bad. Car drove the remaining 1/4 mile home and parked the car. Waiting to hear back from John to see if there's anything horrific in the logs.
It was probably way rich would be my guess, but as I have mentioned before, the advantage of the AEM Failsafe gauge is that it stores your last 3 hours of driving, so you can pull the data and look at it if you weren't datalogging with EcuTek.
Old 07-22-2013, 10:06 AM   #33
mad_sb
Drives: 2013 Asphalt FR-S
If you have it installed and configured correctly.. and i imagine a lot of people don't
Old 07-22-2013, 10:09 AM   #34
mad_sb
J...
Here's the really worrying plot - boost/afr.
Right before the car goes into boost it goes really lean, then super rich.
I have yet to drive this car fast, or even on a fun road. Someone keep my hopes up please
I'd like to see the datalog of that pull if you have it.. I'll shoot you a pm.
Old 07-22-2013, 12:11 PM   #35
pmccut
Drives: Blue Subarus
Honestly - I didn't realize they were putting it back on the dyno. When I brought it there for install over a month ago I asked them to do a before/after, but we ended up not doing one for that reason. This time I brought it back for clutch, engine mounts, fuel pump re-install w/ 4 o-rings. They wanted to see if it resolved the fuel starvation I thought I was seeing. I didn't realize they had until I got there.
I do believe the gauge is configured right as I've pulled logs off it before. I was logging through ecutek so I haven't had to look at the AEM logs lately. Was only using it before my cable was sent.
I was logging through EcuTek the whole time, I'll shoot them over to you.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 07-22-2013, 08:19 PM   #36
FullBlown
FullBlown's Avatar
Drives: Scion FRS
map sent
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
pmccut (07-23-2013)
Old 07-23-2013, 03:55 PM   #37
pmccut
afr logging
Originally Posted by FullBlown View Post
map sent
Sent you a ~10 minute log with a single pull, plotting af/r vs boost with the aem gauge logs. Only saw -1 deg knock correction going into boost.
And here's the most recent map from Visconti.
Both of these are quick pulls stopping at 5k revs. Now that I know how to use aemdata I can probably scale these better for future logs.
Old 07-23-2013, 06:21 PM   #38
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Neither of those AFR curves look all that great, but I like seeing other people using the useful data that the AEM Failsafe provides.
whitefrs (07-23-2013)
Old 07-23-2013, 07:32 PM   #39
pmccut
Absolutely. I didn't know it had data logging before ordering. I do wish the aemdata app was more intuitive. It really doesn't seem to be geared for this data. Lap times, track data, blah.
Old 07-23-2013, 07:39 PM   #40
ModBargains.com
ModBargains.com's Avatar
I will adjust it and send it over
FBM to the rescue! Hopefully you're up and running in no time.
ModBargains.com is offline   Reply With Quote
The Following User Says Thank You to ModBargains.com For This Useful Post:
pmccut (07-23-2013)
Old 07-23-2013, 08:26 PM   #41
mad_sb
This one looks like it's holding closed loop way too long, your at peak boost and it's still 14:1... no good. Shoot me the ecutek log of this pull if you have it and I will let you know if they need to change the way they are handling the closed to open loop transition.
This one has a nasty lean spike (16.5:1) during spool up. Was it still showing -3 / -4 knock correction like the last map?
I would not consider either one of those maps safe to keep doing pulls on.
The Following User Says Thank You to mad_sb For This Useful Post:
pmccut (07-23-2013)
Old 07-23-2013, 10:17 PM   #42
pmccut
Just sent it over.
-5. Every log I've seen has had the same amount, no less, no more. I believe it's right as boost starts to spool, before it goes crazy rich.
This. It's my biggest worry. I don't drive the car outside of giving John a log and taking it to the shop for supporting mods. I really really want to drive this car without worrying about it knocking. The original plan was to get the 91 map looking good then switch to E85 right away, it's just been weeks into the process for 91
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Richmond VA Dyno Day Results 5/4/13 vtmike Engine, Exhaust, Transmission 86 09-17-2013 02:34 PM
Interesting Dyno Results Gen Forced Induction 86 07-31-2013 08:45 PM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
