CANADA Canada
View Poll Results: Petro Canada Ultra 94
Always 11 18.64%
Sometimes 11 18.64%
Rarely 8 13.56%
Never 29 49.15%
Voters: 59. You may not vote on this poll
Old 07-18-2013, 08:53 PM   #15
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by wparsons View Post
^^ I would have it looked at if you're actually getting pinging under no load (like a rev match blip).
I usually get petro 94, but used to run more shell 91 through it. A couple observations:
1) mileage was definitely better on shell 91 than petro 94, I track mileage on every tank and it was definitely repeatable under identical driving conditions (I used to commute ~40km's each way on the 407 with cruise control on every day).
2) ethanol content is not the only factor with the crickets, I've run full tanks of petro 94 without hearing the crickets and I've had full tanks of shell 91 that never stopped making noise. I find it has just as much to do with the weather conditions as it does the fuel.
The main reason I run mostly 94 now is because I get a discount card from the wonderful people at the 407 for a few cents/L off of 140L of fuel. If I use up all of it I switch back to shell 91 until the next month.
1) Agreed...It's not a night and day difference, but it is noticeable.
2) It's definitely not the only factor (ethanol), but I think it is a major contributor. Ambient temperature also seems to play a big role. Weird...any time I use the Shell 91 my crickets stop almost immediately as long as the tank is low enough when I fill it up. I always get crickets on Petro 94 if it is warm out. Below ~5 C, I don't get the crickets on either fuel.
Originally Posted by f0rge View Post
I try to stick with Shell 91.
Even when I'm forced to go to Petro I only pump 91, too much ethanol in the 94 and you get worse mileage while paying more money.
I could be wrong, but I think the Petro Canada fuel all contains "up to" 10% ethanol regardless of grade or octane rating.
Old 07-18-2013, 09:31 PM   #16
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
i used to pump 94 but go chrips.. but switched to shell 91 and chirp free
Minovsky is offline   Reply With Quote
Old 07-18-2013, 11:00 PM   #17
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Can someone verify this, I heard people saying Esso gas nowadays contains upto 15% enthenol. is that true? Is this the trend of more ethenol in gas?
chenshuo is offline   Reply With Quote
Old 07-18-2013, 11:31 PM   #18
Minovsky
Minovsky's Avatar
Ethanol is bad for our engines i think. so just stick to shell since it contains none!
Old 07-19-2013, 12:11 AM   #19
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by Honeydew View Post
Entenol is bad for our engines i think. so just stick to shell since it contains none!
No it isn't this isn't the 1980's anymore. Do you honestly think Toyota would design a car in 2012 that couldn't run on any ethanol??
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-19-2013, 12:24 AM   #20
Apoc
Apoc's Avatar
Esso has up to 10% ethanol but but does not sell it at all stations according to their website. They will have it clearly labeled as required.
http://www.imperialoil.ca/Canada-Eng...uels_fuel.aspx
“The World is Flat”
[||•]=(86)=[•||]
Old 07-19-2013, 12:57 AM   #21
Minovsky
Minovsky's Avatar
Calm down bro its my first car and im just stating what i saw from this froums... i switched over and lost the chirps so that was the only reason i can think of... That why i said I think....
Old 07-19-2013, 01:18 AM   #22
Apoc
Apoc's Avatar
I'm totally calm. I am just sharing my opinions. A friend of mine who has worked in petroleum products for many years says Shell V-Power has lots of additives put into it. Those additives although not specifically designed to, seem to be adding a bit a lubrication to the HPFP making it less noisy. Awesome choice for your first car =P.
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
Minovsky (07-19-2013)
Old 07-19-2013, 01:34 AM   #23
Minovsky
Minovsky's Avatar
Heh :happy0180: hope those additives wont be bad for the car! Anyways yep i totally love it!
Old 07-19-2013, 02:05 AM   #24
kALMIGHTY
Drives: TRD Ultramarine '13
It's not true. My mom's a manager of an Esso gas station and there is 0 ethanol in the gas. Esso and Shell are the only two as far as I know that don't have any ethanol. I'm still running the gas that the dealership put in it (I just got the car yesterday), and I'm planning on using either Esso or Shell 91, though I heard there's a Shell in the community next to mine here in Calgary that has 0% ethanol V-power 93!! Will definitely go look for it.
Old 07-19-2013, 07:47 AM   #25
wparsons
wparsons's Avatar
There are three Esso stations around my home and all three of them clearly state on the pumps that the fuel will contain up to 10% ethanol.
As for ethanol being bad for the car, it's been proven that there is zero harm being done if the HPFP is making the chirping noises, it's just a noise, so I wouldn't say that ethanol is bad for the engine at all.
There's also been a couple reports of guys running e85 without the pump making noises, although most seem to make the noise.
flickr
Old 07-19-2013, 11:58 AM   #26
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Yea, that's what I don't get. Some of our neighbours down south are going with complete E85 tunes. They seem to be doing okay.
I think I'm just going to continue on pumping the PC94 and see what happens. There's something about pumping 91 octane into the car that doesn't sit well with me because it clearly states the car should use 93 whenever possible.
hmong337 is offline   Reply With Quote
Old 07-19-2013, 12:01 PM   #27
Enemies
Drives: '13 SWP Sport-Tech (Limited)
I've filled every tank with Chevron 94 since I got the car back in June of 2012 and have never heard a chirping noise.
Enemies is offline   Reply With Quote
The Following User Says Thank You to Enemies For This Useful Post:
hmong337 (07-19-2013)
Old 07-19-2013, 01:19 PM   #28
wparsons
wparsons's Avatar
For those of us not in BC, does Chevron 94 have any ethanol in it? I believe it does but I'm not even close to sure
flickr
Ultra low jack options? OakmanSmalls BRZ First-Gen (2012+) — General Topics 53 09-24-2013 04:09 AM
Ultra Everdry on Exterior joergasm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 06-15-2013 08:11 PM
Ultra FR-S ultra_frs Member's Car Journals 8 05-30-2013 09:22 PM
Ultra 94 gas at Regular gas prices today Feb 10, 2013 at select Petro stns (TORONTO) Ultra86 CANADA 5 02-11-2013 12:30 AM
94 octane now at petro Sasquachulator CANADA 19 08-09-2012 01:11 PM
