Old 07-14-2013, 12:28 PM   #1
OakmanSmalls
Drives: 2013 DGM BRZ
Ultra low jack options?
Before I get yelled at I did search for about 40 minutes.
Anyways I'm wondering if anyone has found a good low profile jack that can reach the front center jack point?
Of course price is a concern but functionality is the most important issue. So give me some feed back about how you guys are getting the car in the air
OakmanSmalls is offline   Reply With Quote
Old 07-14-2013, 12:38 PM   #2
comic0guy
Drives: Evo X, 1996 Celica, DGM BRZ
I've gotten my jack from this place. I got the AFF Model 200T. But I wanted a jack that was lower than most, but sturdy. I don't like getting a cheap jack that I couldn't fix. I can buy the parts from the manufactuer, unlike the cheap autozone jacks. The 200T is built like a tank, literally it is a solid 80lbs.
Either way, they have lots of options and I have ordered more than just the jack from them.
http://www.asedeals.com/auto_shop_jacks.html
comic0guy is offline   Reply With Quote
Old 07-14-2013, 12:46 PM   #3
Ingen
Drives: Ultramarine FR-S 6MT
I got the harbor freight 1.5 ton aluminum racing jack when it was on sale, for like 60. Works fine, reaches front support and has more than enough room for a 2x4 to protect the car.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 07-14-2013, 12:56 PM   #4
DarkestBuddha
Drives: BRZ limited GBS
also looking for a good low pro jack
especially for a lowered car with a lip kit installed
DarkestBuddha is offline   Reply With Quote
Old 07-14-2013, 01:25 PM   #5
infinite012
Drives: 13 DGM BRZ Ltd
Lowered with a lip kit installed? Probably gonna need to drive it up on some 2x4s before you could even fit the lowest of the low profile jacks.
I have an Arcan XL325R that I bought from Costco about 2 years ago for $100. It's low profile and rapid pump. Worked great on my slammed STI and works great on my lowered on RCE Yellow BRZ.
infinite012 is offline   Reply With Quote
Old 07-14-2013, 01:37 PM   #6
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
I will second this. Works great on my lowered MR-S and my son's lowered FR-S.
Cannot beat it for the price.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 07-14-2013, 01:50 PM   #7
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
got the aluminum 3t harbor freight jack and works fine.. they also make a 2t ultra low profile steel one with extra long reach. http://www.harborfreight.com/automot...uty-68050.html
xDBOYx is offline   Reply With Quote
Old 07-14-2013, 03:33 PM   #8
OakmanSmalls
Harbor freight has a steel jack on sale right now for 148. It's very low 2 3/4" I believe. Rapid pump, and the actual lift is 21" from the pivot point. I believe I'll be buying this jack sometime next week. I do like the aluminum jacks but this will stay in the garage so weights not an issue. This is also the longest flattest and lowest jack at harbor freight
Old 07-14-2013, 03:34 PM   #9
OakmanSmalls
Didn't see the post above mine but ya that's the one. Very nice jack if you don't mind the weight
Old 07-14-2013, 03:49 PM   #10
xDBOYx
xDBOYx's Avatar
Yea I like it as well. I think im going to get it as well when my 3t can no longer get under my brz.
Old 07-14-2013, 06:19 PM   #11
37
degrees
37's Avatar
Drives: 6MT BRZ
Brunnhoelzl Low Profile: http://www.brunnhoelzl.com/low_profile_jacks.html
The cup is 2.5" from the ground. If that doesn't fit under your radiator support then you might want to rethink your priorities.
Either that or buy a set of plastic ramps and use whatever jack you want.
37 is offline   Reply With Quote
Old 07-14-2013, 07:29 PM   #12
utekineir
blowhard
Drives: frs, project forester
my low aluminum harbor freight 1.5 ton has been working like a champ as primary jack for about 5 years now, won't hesitate to buy another when it does die
utekineir is offline   Reply With Quote
Old 07-14-2013, 07:45 PM   #13
OakmanSmalls
Holy crap $1200+ that's intense. I'll stick to harbor freight I think lol. Sweet piece of equipment tho
Old 07-14-2013, 08:12 PM   #14
37
degrees
37's Avatar
Drives: 6MT BRZ
Indeed. That's why I also suggested the ramps.
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
Ultra Everdry on Exterior joergasm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 06-15-2013 08:11 PM
Ultra FR-S ultra_frs Member's Car Journals 8 05-30-2013 09:22 PM
ultra marine fr-s vs maserati mrnibbs FR-S / BRZ vs.... 6 05-28-2013 09:51 AM
