Old 07-14-2013, 10:27 AM   #1
fuzzybat23
fuzzybat23's Avatar
Drives: FR-S Series 10 Release
OEM USB/Stereo Port
Does anyone know the part number, or where I could order this? It's that little usb and mini jack port to the right of the cellphone/ipod holder, down by the shifter. I plan on upgrading my headunit to one that doesn't have an aux input, but has two usb inputs on back, so I want to order another of this part and modify it to accept two usb jacks. Thanks!
fuzzybat23 is offline   Reply With Quote
Old 07-14-2013, 12:58 PM   #2
lsr78
Drives: 2013 Scion FR-S MT Ultramarine
I'm not sure about the part number but I think it would be easier to make something custom out of a blank piece of plastic or wood. The whole piece pops out and it doesnt seem like it would be very easy to modify. I took mine out and used some cardboard and closed cell foam to make a temporary solution.
Perrin Non Res Cat Back/CAI/Inlet/Tranny Mount/Shifter Bushing
Enkei PF01
18x7.5 et38/Conti DW 225/40/Eibach Pro-Kit
H&R spacers 15mm rear/5mm front/Whiteline PSK/ECUTek Tune
Alpine IND-S920HD/MRX-V70/CDT HD-62/JL StealthBox/Bel RX65/JPM Coachworks interior bits
lsr78 is offline   Reply With Quote
Old 07-14-2013, 01:00 PM   #3
fuzzybat23
fuzzybat23's Avatar
Now that I think of it.. yeah, I probably could just pop it out and measure it. Model it in Rhinoceros and have Shapeways.com print me out an actual insert.. I might just try that.
Old 07-14-2013, 01:06 PM   #4
fuzzybat23
fuzzybat23's Avatar
I probably wouldn't need to do this if they'd make a wiring harness that could easily hook into the oem usb and microphone. Toyota, as smart as they are, really are dumb as hell for not using a universal mini jack and usb connectors on the backs of the stock radios.
Old 07-14-2013, 10:19 PM   #5
fuzzybat23
fuzzybat23's Avatar
It'd actually look something like this, if it prints right.
Old 07-14-2013, 10:36 PM   #6
Gunman
Drives: 2019 Mazda Miata RF
Gotta love rapid prototype machines.
Old 07-14-2013, 10:50 PM   #7
fuzzybat23
fuzzybat23's Avatar
Yup. Instead of waiting for those knuckleheads to make a part that should've existed already, or shouldn't have needed to exist, I can just model it and order the part for myself. I loves you, Shapeways.com!
Old 07-15-2013, 02:24 PM   #8
You need one of these. It worked great when I temporarily swapped mine out but then decided I liked the new headunit even less.
Old 07-15-2013, 03:52 PM   #9
fuzzybat23
fuzzybat23's Avatar
Well, I just got an email that my custom part is going to the 3d printer. Hopefully, it will fit right. if it does, the two radios that I'm looking at are:
Pioneer avh-x8500bhs
Or
Sony xav-701hd
Anyone have any useful info on either deck? I chose both for hd radio, dual usb in reat and both claim full pandora integration with android over bluetooth.
Old 07-15-2013, 05:51 PM   #10
GreenPants
Drives: Burnt Orange GT86
I'd still be interested if anyone knows the part number.
NZ cars ship with a different head unit that doesn't support AUX/USB so the car doesn't have this connector block - just a blanking plate where one would be.
Now that I've replaced the radio with one of those Chinese Android-based units, I'd quite like to add the connectors to the dash.
GreenPants is offline   Reply With Quote
Old 07-15-2013, 06:26 PM   #11
fuzzybat23
fuzzybat23's Avatar
I had to pull the usb/aux port out of mine so I could measure it for the 3d model I sent to shapeways.com. The part number on the side of the thing is 86257CA000 I googled it and it showed up on a few subaru part sites. It isn't cheap, though, ranging from like $60 to $90 or so.
Old 07-15-2013, 07:04 PM   #12
GreenPants
Well, at least I know what to order now! Thanks.
Old 07-27-2013, 11:25 PM   #13
fuzzybat23
fuzzybat23's Avatar
Update. Here's the part I modeled in Rhinoceros and had Shapeways.com make, with thet two usb plugs installed.
The Following User Says Thank You to fuzzybat23 For This Useful Post:
|-Goku-| (07-27-2013)
Old 07-27-2013, 11:58 PM   #14
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
Now, is the actual part just two rectangle holes, and the usb just clicks in?
|-Goku-| is offline   Reply With Quote
Port and Polish? Hawk77FT Engine, Exhaust, Transmission 69 12-18-2018 06:31 PM
SOLD OEM USB/Aux port abutterman Interior Parts (Incl. Lighting) 2 07-14-2013 10:45 PM
BRZ & USB Port brz007 Electronics | Audio | NAV | Infotainment 14 04-14-2013 09:06 PM
More power to USB port Z86 Electronics | Audio | NAV | Infotainment 22 12-27-2012 10:19 PM
FR-S at the NJ Toyota port. IloveBaldEagles Scion FR-S / Toyota 86 GT86 General Forum 11 11-08-2012 11:34 PM
