Old 03-12-2013, 10:18 PM   #1
Hawk77FT
Drives: GTS 86
Port and Polish?
Hi all,
I was thinking the other day about getting the cylinder head, intake manifold, exhaust manifold (if not going to the aftermarket header route) and throttle body ported and polished?
This will free up some ponies for sure!!!
Has any one done it?
Hawk77FT is offline   Reply With Quote
Old 03-12-2013, 10:24 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Hawk77FT View Post
Hi all,
Subscribed for results. If you go ahead with this could you get them flowed befor and after?
1974 TA22 Celica
2013 86 GT
Old 03-12-2013, 10:50 PM   #3
xwd
Hi all,
The intake manifold is plastic so good luck with that one.
There are two heads, I don't doubt it will help but is best done when building the rest of the engine unless you like removing the engine.
I don't think anyone has done it yet.
Old 03-12-2013, 10:53 PM   #4
dabocx
dabocx's Avatar
Drives: Scion FRS
It hasn't been done and for the work your going to do id just wait and get cams/valve-train goodies at the same time.
Still if you do try and get flow bench data of the before and after.
dabocx is offline   Reply With Quote
Old 03-12-2013, 11:03 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Several rs25.com members have done it in their cars... but tbh, you'll won't see much as you think you'll get... but I'm looking from EJ engine & not FA engine, so I could be wrong on this one.
If you gonna do it, I would recommend get some cams too. That's where you'll see more result w p&p
The Following 5 Users Say Thank You to ichitaka05 For This Useful Post:
boxer 2.5 (09-27-2013), dabocx (03-13-2013), davesrave (06-22-2014), ftc~brz (09-25-2013), Hawk77FT (03-12-2013)
Old 03-12-2013, 11:21 PM   #6
Opposed
Drives: 2013 Asphalt FR-S
The throttle body on the FA20 is already pretty large. I doubt you will see much gains staying N/A.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 03-12-2013, 11:27 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
You will probably need a tune to make the most of any head work also.
1974 TA22 Celica
2013 86 GT
Old 03-12-2013, 11:39 PM   #8
Hawk77FT
Drives: GTS 86
How about doing just the ports? cyl head - intake and exhaust, and intake manifold, and exhaust. The intake is plastic? WTF?
Old 03-12-2013, 11:40 PM   #9
Hawk77FT
Drives: GTS 86
No doubt!
Old 03-12-2013, 11:49 PM   #10
Hawk77FT
Drives: GTS 86
I guess if you do JUST that the gains will not be as significant as if you do the whole thing:
1. Exhaust - port and polish ports, header back system
2. intake - port and polish ports and full intake system.
No point in doing just one bit if you dont go all the way. My .2 cents. Just like the exhaust - what is the point in having a high flow axle back if the rest of the exhaust is 1.5 inch (not that it is but you get my point). Yes, it will free up some power but not a great deal of it. Same with the intake. Yes, the throttle body might be big enough although Greedy is making one with a bigger diameter...so more air in the intake plenum will need to go somewhere with the same proportional flow. But than again a true free flow system would include cyl head - back in both intake and exhaust!
And if we go into the cyl head..than I agree with @dabocx by waiting for cams/valve goodies to get it done properly.
And it is quite obvious that such mod will need a tune.
I read that the top end would become quite crazy...not as much as the bottom end and who knows maybe that 4000rpm dip would disappear FOREVER!
Old 04-03-2013, 01:00 PM   #11
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
Resurrecting this semi-old thread...
Has anyone given the porting/polishing idea a try? Any results?
I know there have been some gains shown on late model Chevy's with the plastic intakes. Seems like it would be easier to work with the plastic than the metal.
TSW Nurburgring 18x8, BFG Comp-2 235/40, KW V3's w/ Vorshlags, ECUTek by Evasive, Injen intake, FT86 Header, Motiv OP/DP, Nameless Axleback, 4.88 Weir gears, Subaru Legacy GT brakes, Five Axis spoiler, Shark Fin, 3000k HID's, LED goodies
KVDB31 is offline   Reply With Quote
Old 04-03-2013, 01:21 PM   #12
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
FBM and others are working on beefing up the heads(CNC, Valvetrain, Cams)
The TB is 70mm, more than enough for high horsepower.
JDL is making a billet intake manifold after they popped the top of their motor.
Thats all I know of as of right now.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 04-03-2013, 01:22 PM   #13
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I used to do custom head work on Ford and Chevy small blocks back in the day. Those old factory heads were built by cavemen when compared to the R&D and engineering that goes into heads these days. I don't think there would be much to gain from this work unless you were building a full-on race long block with cams, stroker rods and pistons, the works.
Also there are some big misconceptions when it comes to port polishing. You really don't want to make the runners "perfect" and smooth. The small casting bumps and imperfections aid in turbulence which helps keep the fuel-air mixture from separating.
If it were me, I would like to set the heads up on a flow bench to see where the restrictions are (if any). Its never a good idea to start grinding unless you are doing it with a specific purpose, otherwise you are just working "blind".
Scott
naikaidriver is offline   Reply With Quote
The Following 5 Users Say Thank You to naikaidriver For This Useful Post:
Calum (04-03-2013), FirestormFRS (04-03-2013), flippy (09-03-2014), Muaddib (06-22-2014), Tansey86 (04-03-2013)
Old 04-03-2013, 01:41 PM   #14
Tansey86
Tansey86's Avatar
Scott
+1. A flow bench is critical. I think the heads are pretty decent on these cars in terms of flow, the cams will give the most gain in terms of beefing up the heads.
What did you wash/shine/polish/wax today? tuckdaddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-04-2013 07:42 PM
Glass polish? SubarooMike Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 11-08-2012 01:33 PM
Port and polish? Extrude hone? mrha Southern California 0 07-11-2012 09:54 PM
Saving / Re-using polish and waxing supplies? eikond Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-25-2012 04:25 PM
