Old 09-29-2012, 10:53 PM   #1
brz007
Drives: 2013 SWP Limited BRZ
BRZ & USB Port
So not sure if anyone has ran into this.
I have a 16gb usb still that I use for music. I'm only using about 1/2 or less of it. 7.28 GB free. 74 Items/Folders.
1) It seems the unit only picks up some of my folders? All music was copied from iTunes.
2) I added some new songs this afternoon and the radio would not even read the usb, the button was gray. I deleted some songs and it would pick up the usb stick again however maybe still only 40% of all the folders.
So does anyone know if its a format issue? Max number of folders?
brz007 is offline   Reply With Quote
Old 09-29-2012, 11:24 PM   #2
Six
Drives: 2011 BMW M3 | 2011 BMW Z4 35iS
Are they all MP3? If you bought some of the songs through iTunes your going to need to remove the drm first.
Six is offline   Reply With Quote
Old 09-29-2012, 11:27 PM   #3
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Is formatted in FAT32? Maybe the problem is related to the 4GB file transfer cap? Although that's shouldn't technically affect it...
Have you tried formatting in exFAT? If it reads then perhaps that will solve it because exFAT doesn't have the 4GB cap...
- The Ancient BRZ Sacrament
by Zaku
Old 09-29-2012, 11:27 PM   #4
brz007
Yep they are all mp3s. 99.9% Were uploaded through cds and or convert youtube to mp3.
Old 09-29-2012, 11:31 PM   #5
brz007
Not sure I follow. Using a macpro for Itunes. The USB is PNY I bought from Best Buy and just plugged in and transferred files, made folders and off I went.
Old 09-29-2012, 11:46 PM   #6
Guff
Guff's Avatar
Drives: BRZ LZR
Well, you can try reformatting your drive, but you would have to resync all your tunes. If you wanna do that, then here's how:
Go to Disc Utility on your Mac.
On the left pane, click on your USB drive.
Go to the Erase tab.
Click the drop down box and select exFAT
Name your Drive
Hit erase.
Load up iTunes and resync all your music.
See if it works better! If it doesn't then, I have no idea what the problem is..
by Zaku
Old 09-29-2012, 11:47 PM   #7
Six
I think he's talking about how files can't be bigger than 4gb which wouldn't effect you since mp3 are small.
I would check the encode settings, I'm pretty sure by default iTunes encodes as AAC not mp3.
If that doesn't work I would wipe the drive and start over like Guff said.
Old 09-30-2012, 12:06 AM   #8
wheelhaus
wheelhaus's Avatar
Sounds like you're doing everything correctly. It's possible that your USB stick is just old and the head unit has issues reading it... Maybe pick up a newer USB stick and give it a shot.
"DRM" means Digital Rights Management" and it means the mp3 files are encoded with special data that restricts what type of devices can read the files and how they can be used, (i.e. they are "protected"). If you've done the encoding from CD, you should have control over this feature. If you're seeing discrepancies with which files are being displayed, sometimes XYZ files are visible, other times ABC files, it sounds like a software or hardware incompatibility.
wheelhaus is offline   Reply With Quote
Old 09-30-2012, 12:23 AM   #9
brz007
Its a new stick, like 1 month old I'll try reformatting it. For some reason I remember seeing somewhere that the head unit would only read up to a 16gb stick not anything larger. So my only thought is maybe that size limit is smaller? Strange thought b/c when you connect an ipod that size limit doesn't seem to apply but maybe its the way its managed.
As far as the itunes sync. Its not sync'd. B/C its a usb stick you manually create folders and drag and drop. Is there a way to sync external drives? I though you could only sync apple devices?
Old 09-30-2012, 12:25 AM   #10
brz007
I knew what DRM is. My understanding was that if you u/l from a cd, no drm. But if you d/l from itune DRM unless you purchase the 1.29 or what ever song. The work around being, d/l a drm, burn to a cd, then u/l back to itunes?
Old 09-30-2012, 12:26 AM   #11
Guff
Guff's Avatar
Drives: BRZ LZR
Right, and that's what I was thinking, but I guess there's no harm in trying a reformatting...
by Zaku
Old 09-30-2012, 02:49 AM   #12
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Your USB stick size is too large. 8 GB max.
You can also hit a 'number of files/folders' limitation. Many HUs have that issue.
According to an internal Subaru Tech Support Guide for the FT nav:
USB memory
Max data size: 8GB
Class: USB mass storage class
Max picture resolution size: 720*576 pixel
Max layers of directory: 8 layers [levels of nested sub-folders]
Max number of folders (overall): 3000
Max number of files (overall): 9999
Video formats: DivX, WMV, MP4
Audio formats: MP3, WMA
Supported file formats: FAT32
Supported audio formats: MP3/WMA/WAV
Maximum current: 1.0 A
Supported capacities: 16 MB to 8 GB
Compatibility: USB1.0/1.1/2.0 (maximum transfer speed is same as USB 2.0)
Mass memory support: Supports USB mass storage class
Does not support USB hubs or multi card readers
Max resolution for video playback: 720x480 (30 fps), 720x576 (25 fps)
Those specs (and more) are also listed in your navigation owners manual, starting on page 244. You can download PDFs here:
subaru.com/owners/resource-center/owners-manuals/index.html
Tip: Having the PDF version is handy for searching for a keyword (such as "USB" or "folders").
OP- Is 74 the total number of folders+files on your USB stick?
SVXdc is offline   Reply With Quote
Old 09-30-2012, 08:54 PM   #13
brz007
I knew I saw that somewhere
So got a new 8gb stick loaded up my folders and still nothing. So I started trying one folder at a time.
Turns out most of my old skool music is mpeg-4....which the unit does not see. So I'm searching for an easy way to convert them right now.
Old 04-03-2013, 07:54 PM   #14
FRS91761
FRS91761's Avatar
Drives: 2013 SCION FR-S 6MT
this sux!
Good thing that I came here before going out to buy a 128GB USB drive
FRS91761 is offline   Reply With Quote
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
BRZs at port? itsfun Mid-Atlantic 7 10-02-2012 07:58 AM
adding a second usb port for charging? Reason Electronics | Audio | NAV | Infotainment 5 07-11-2012 07:47 AM
New FR-S arrival to the Port of Jacksonville greenguy101 Southeast 7 06-25-2012 02:19 PM
