Drives: 86 GTS Auto in Pegasus White
More power to USB port
Is there any way to boost the power to the builtin USB port? I haven't tested the actual output but it must be pretty low - my phone battery goes down if I'm running a nav app, even though it says its charging.
#2 | |
Drives: '04 350Z/ 2013 LR BRZ (LM)
Manual (i think) says its a 2 or 7.5. I dont know lol |
Drives: 2013 Subaru BRZ Limited in WRB
It's the amperage coming from the head unit that controls the USB port. There's no way to "tweak" it. You'd either have to rig up your own LM7805 to the USB power wires or buy one of those cheap cigarette lighter to USB converter and use the bluetooth on your phone instead to stream music.
#4 | |
Drives: 2013 frs white out
" Knowledge is nothing with out execution"
#5 | |
Sarcastic SOB
btw the fuses only protect the circuit, changing fuses wont change the amp/ voltage. you can only alter the output source and use a fuse to suit your needs.
| The Following User Says Thank You to xpicer For This Useful Post: | ProjectD (12-16-2012) |
#7 | |
It's USB - USB is USB - it's 5V and 250mA standard. Charging is based on amperage not voltage. The 7805 is capable of supplying 1A and unless your phone is shorted, it will not draw 1A of current. You may need a resistor to limit the current draw such as a 20 ohm 1.25W in series between the output leg and the device. That would limit the current draw to 0.25A. But if you're looking to get a boost than you'd probably want to match whatever your regular charger amperage is (not USB power).
| The Following User Says Thank You to rmjjensen For This Useful Post: | Sportsguy83 (12-14-2012) |
I just looked at my home charger - it's output is rated at 5V 1A. So, the 7805 is right at it's limit. Throw a heatsink on it and it'll be fine and if you're nervous put a resistor on the output leg.
I Love custom Turbo kits
Drives: Limited BRZ
Words of wisdom. Listen to this guy!
#10 |
[QUOTE=rmjjensen;608840]That's what the LM7805 does - it's a 5V regulator - no need for any voltage divider circuits and it costs something like $1. You'd install the 7805 and take the output leg (5V) and connect it to the power wire in the usb port. Break out the volt meter, find the existing +5V cut it, and then use the out from the 7805 and feed it to the USB port.
![]() ![]() you dont think that the hu might have problems if the orginal power wire coming out of the hu is not connected to anything? like i know on some other modules the voltage/ amperage drop is measured to dictate if the component is connected to the module ???
#11 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
However, many hosts can provide more than that, and many clients will request more than that. If the host is providing 1000mA (or 1A), then it should be charging fiarly well. But it might be a case of the device asking for 1.1A or more, and the host just saying 'No dice, I dont have that much' and reverting back to 500 or even 100. If you have a multimeter you could easily test what you are getting. |
#12 |
You wont find an automotive usb port on a head unit over 1 amp usually and the ports on most are .5amp which is why the devices never charge. Some phones and tablets now require 2 amp usb ports as well.
#13 |
Drives: 2013 Firestorm Scion FR-S
The nav app on android is definitely a power hog. I switched to waze and I find my phone keeps it's charge longer. I would get something that goes above 1 amp because I find my phone charges much faster if I plug it into my 2A tablet charger.
#14 | |
| OBD2 Port | RJ_ | AUSTRALIA | 33 | 08-25-2016 10:25 PM |
| What is your prediction on FT86 power and Subaru 086a power? | 86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 08-26-2013 11:49 PM |
| BRZ & USB Port | brz007 | Electronics | Audio | NAV | Infotainment | 14 | 04-14-2013 08:06 PM |
| FR-S at the NJ Toyota port. | IloveBaldEagles | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 11-08-2012 10:34 PM |
| BRZs at port? | itsfun | Mid-Atlantic | 7 | 10-02-2012 07:58 AM |
