go_a_way1
Old 06-22-2013, 10:17 AM   #1541
86silver
86silver's Avatar
Drives: scion frs silver
alright i plan on getting a staggered setup up of enkei raijin i want 18x8.5 and was thinking about getting 225/40R18 and then 18x9.5 for the back with a 255/35R18 and i was just wondering if that would fit properly on my frs
86silver is offline   Reply With Quote
Old 06-22-2013, 03:22 PM   #1542
jshadeck
jshadeck's Avatar
If u know the offsets just read through this thread. Its been answered
jshadeck is offline   Reply With Quote
Old 06-22-2013, 03:24 PM   #1543
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Yes! Very good for staggered setup! :happy0180:
Be sure the offset is correct. (+30 ~ +45)
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 06-22-2013, 07:02 PM   #1544
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Originally Posted by ill86 View Post
It should not. I can measure in the AM if you like.
And yes, I would choose 245/35 over 245/40. The latter is too tall.
If staggering, 235/40 on 8" front, 265/35 on 9" rear
If square, 245/35 on 8"-9" front/rear
Thanks. I think I will go with stagger. Someone in the forum posted with 245/35 setup. The front was a lil poke. I'm sure that 235/40 will get me the flushness.
Now, I really hope that 265/35 on the rear will not rub or hit the stock struts. I don't plan to adjust the rear chamber. I know 275/35 might sound crazy on the rear, have you seen anyone doing that without chamber adjustment?
hanabie is offline   Reply With Quote
Old 06-22-2013, 08:03 PM   #1545
ft86me
ft86me's Avatar
Drives: 2013 FRS
hey guys have 18x9.5 +38 and 245 40 18 right now. looks like i have some more room wondering if i can squeeze some 275 in the front and the rear or is 245 all around the most I can do? no demon camber= no thanks, functional camber = yes, fender modding = no
oh and if 275 is no go, what are my options from your guys experience with a wider tire all around. 245 just seems like i got more tire i can squeeze in there.
ft86me is offline   Reply With Quote
Old 06-22-2013, 11:30 PM   #1546
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by ft86me View Post
hey guys have 18x9.5 +38 and 245 40 18 right now. looks like i have some more room wondering if i can squeeze some 275 in the front and the rear or is 245 all around the most I can do? .
Measure the extra room you have. Your vantage point is a little better than ours. :happy0180:
Old 06-22-2013, 11:36 PM   #1547
ill86
ill86's Avatar
Drives: iG FR-S
One man's flush is another man's poke due to alignment settings..
You're going to want an alignment anyway. If you are lowering the vehicle you will gain negative camber.
Just keep taking it on step at a time.
The Following User Says Thank You to ill86 For This Useful Post:
hanabie (06-23-2013)
Old 06-23-2013, 01:45 PM   #1548
ft86me
ft86me's Avatar
Drives: 2013 FRS
how would i go about doing this?
Old 06-23-2013, 02:25 PM   #1549
ill86
ill86's Avatar
Drives: iG FR-S
Your current tire:
245mm wide
Tire in question:
275mm wide
Difference:
275-245 = 30mm
30mm/2 = 15mm additional inner and outer clearance needed.
Take measuring device and see if you have 15mm more room.
ft86me (06-23-2013)
Old 06-26-2013, 02:03 PM   #1550
BLKFRS
Maverick.
Drives: Scion FR-S
I was looking for 9.5-10 rear and 8 in front with 255/35 tires rear snd 225/35 in front
BLKFRS is offline   Reply With Quote
Old 06-26-2013, 02:11 PM   #1551
ill86
ill86's Avatar
Drives: iG FR-S
OK... well, they aren't in here.
What other questions do you have?
Old 06-26-2013, 03:30 PM   #1552
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
So i put on my rpf1 17x9 +45 today... Is is safe that the tire is so close to the coil?
Size:  202.2 KBName:  ImageUploadedByTapatalk1372271389.936052.jpg
Lee358 is offline   Reply With Quote
Old 06-26-2013, 03:47 PM   #1553
jshadeck
jshadeck's Avatar
Looks familiar thats even closer then my 9.5 +38 i think, tho it may look that way due to tire width... If its the same as mine, its "safe", drive it a little, check the sidewalls for rubbing. Then drive the shit out of it, i did 60-85 around on/off ramps to get the tires to roll if they do at all. I have no rubbing regardless of how hard i pushed. But i currently have a stretched 235 tire
Old 06-26-2013, 03:57 PM   #1554
Lee358
Lee358's Avatar
Thanks! Yeah im running 245/40 they are close i might look into 3mm spacers.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
