Old 06-25-2013, 12:30 AM   #29
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by buditjoenawan View Post
I missed that. Has Vortech confirmed that map does indeed correspond to the shipping unit?
budi
Yeah they have, couple posts after that one. This link actually takes you to that post in the thread instead of a single post view: http://www.ft86club.com/forums/showt...660#post876660
I bet that if you pair the hotside of the larger turbo with the cold side of the smaller turbo, you'd see the gains - at the same boost level.
In the example I gave, the smaller turbo's compressor is physically incapable of flowing the additional 100hp. At any boost level.
I gained 100 HP through a combination of lower backpressure AND better compressor efficiency
Also, someone else mentioned that if you make the turbos the same, then of course they'll do the same amount of work... Your comparison only works if you have a turbo that has the vortech compressor wheel in it, and you compare it to a vortech supercharger on the same dyno/same conditions. Then you would see the difference between them, but we don't need to. We can already see that turbos are making more power at even lower boost levels.
Sellout is offline   Reply With Quote
Old 06-25-2013, 12:40 AM   #30
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
essentially a turbo has limit which it can flow air, not in pressure but in velocity. i think this is called "head loss" correct me if im wrong. It is where a fluid such as air becomes condensed and its surface area (the amount of air molecules that come in contact with the pipe) increases along the inside of the tube. This causes friction and slows the air down an heats it aswell causing a drop in pressure, thats why turbos have max pressures!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 06-25-2013, 12:59 AM   #31
Scoobyrs25
Drives: 01 RS, STI V6 RA Limited, BRZ
Ok, so what everyone is forgetting is the boost curve. The superchargers make peak boost at redline. A properly tuned Subaru motor (please don't bother bringing Toyota into this, it's really NOT a Toyota) will make peak boost between 3-4k rpm and taper towards redline. The supercharger isn't making any boost when the motor likes it and maxes out where it really doesn't run well with boost. The supercharger delivers hot air where the Subaru motor does poorly with it. Because of this, we tuners must take out gobs of timing up top and power suffers.
The classic, superchargers make more torque argument really does not apply here since the turbo makes fantastic power everywhere. It's kinda funny that the NA stock motor and the supercharged motors feel laggy while the turbocharged FA20 makes great power from idle to redline.
Scoobyrs25 is offline   Reply With Quote
Old 06-25-2013, 01:07 AM   #32
buditjoenawan
Drives: Very very slowly
This is true only of the centrifugal type superchargers. Positive displacement types behaves sort of the opposite, but modern twin screws which compresses does far better in this department. But parasitic drag is still parasitic drag. No power is free.
budi
buditjoenawan is offline   Reply With Quote
Old 06-25-2013, 04:47 AM   #33
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Then just get all three different kind of FI systems on the same day, on the same fuel, on the same dyno. The difference will be very apparent.
I might be able to arrange that. Not sure what the hoopla is about, some say torque, some say boost. People will want to see what they want to see though.
You can pump relevant information in their faces till they're blue but the bunch of armchair critics who've read a few books would certainly be able to tell you otherwise with obscurities to boot.
I prefer to let the customer's decide what's best for themselves, but certainly, cutting down on the noise is a different story...
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 2 Users Say Thank You to Drift-Office For This Useful Post:
nlp187 (06-25-2013), Pete (06-25-2013)
Old 06-25-2013, 05:15 AM   #34
Drift-Office
Originally Posted by SloS14 View Post
sorry, but horribly misinformed comparison.
Still waiting on how this is 'misinformed' since the dyno with sensors is how we quantify the tangibles like, HP/ TQ / AFR / BOOST as units of measure. That is unless, you're saying we've all been doing it wrong all this time?
Old 06-25-2013, 09:18 AM   #35
jamesm
Originally Posted by carbonBLUE View Post
i know boolean, its java right? i thought it was a mistype and i wasnt bashing you in any way or form lol
mathematical equations not preformed in computer language is what i am used to
i remember using boolean expressions in algebra 1 but that was back in the 6th grade... lol
it's the same for pretty much every language (with some rare exceptions). the sample was actually ruby. sorry, i'm a nerd.
Old 06-25-2013, 12:58 PM   #36
AVOturboworld
Let's say that, for the sake of argument, the two main forms of FI are used to get towards a goal of maximum power on 93 octane gas on an identical FA20 with a free-flowing exhaust system, upgraded fuel pump, and upgraded fuel injectors. And lets say that, give or take 10~15ft/lbs, that is about 260 ft/lbs of torque. Because, of course, torque is what is being measured to produce hp figures.
Here is the possible issue - say the two systems are similarly efficient and are forcing in roughly the same amount of air into the pistons. Theoretically, they are all making the same power at that point give or take the compressor charge temperatures.
What modifies that value further, though, is the amount of parasitic drag.
Very unscientifically (since there is not a lot of specific figures):
Turbocharged system may reach about 255ft/lbs - loses some power due to the backpressure at the turbo.
S/C systems may reach between 210-240ft/lbs - loses some power due to parasitic loss at the pulley.
Now, that power lost to a pulley doesn't mean that the s/c engine is running at less power, it means that it's pushing the same amount of air and fuel into the engine, producing the same amount of power (or more) than the turbo, but that the pulley system is then eating up that specific amount of produced power.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Books (06-27-2013), Pete156 (06-26-2013)
Old 06-25-2013, 04:02 PM   #37
wparsons
wparsons's Avatar
I would argue the dyno is misinformed because it claims that it's parasitic drag (pulley losses) making the entire difference in hp/tq. In reality the difference is from the boost curve, the compressor sizing/efficiency/etc and the parasitic losses of both the pulley on the s/c and the hot side on the turbo.
Claiming all the differences present in the dyno is purely from the parasitic drag needed to spin the supercharger is what is misinformed.
I'm not arguing that one will make more power than the other, just that there is a lot more at play than just the power needed to spin the s/c.
flickr
Old 06-25-2013, 05:57 PM   #38
buditjoenawan
Aaaaah, I told myself I won't post again, but I have outed myself as a liar.
Even if what you say is true, then how does one explain when boost levels meet at 6500rpm? The Vortech car in this example has a full exhaust, so backpressure should be as low as it can possibly be - giving it a theoretical advantage over the turbocharger's turbine and housing. I have been corrected in that Vortech has indeed published their compressor's map. The AVO kit in question uses a 38-ish lb/min turbocharger (with a smaller hot side) and from the looks from the Vortech map, the supercharger has a 40 lb/min compressor at peak efficiency. So again, advantage supercharger. So yea, the chart does show, as well as it can, the difference between a supercharger and turbocharger's output to be mainly –*mainly –*drag induced. How else can you explain the difference in torque output at >6500 when boost levels become identical?
budi
Old 06-25-2013, 07:47 PM   #39
wparsons
wparsons's Avatar
Because there are still more variables at play. Just because the s/c flows more at peak efficiency doesn't tell you how close to peak efficiency is it running on this engine at 6500rpm? More flow doesn't mean more efficient in every situation.
It's the same reason two different turbos at the same amount of boost won't make the same power on the same car.
The only way to measure the power difference caused by the parasitic drag on the s/c is to run identical compressor wheels and housings and regulate the boost pressure so they match up the same across the RPM range. You can work out theoretically how much hp the s/c needs to spin as well, but that's not measurable.
flickr
Old 07-11-2013, 01:17 AM   #40
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Or you could use the compressor work equation and factor in the isentropic efficiency (or adiabatic eff. in case of twin screw SC) to figure out power/torque consumption of an SC at a given boost level...
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 07-11-2013, 01:32 AM   #41
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
It is well known that moving air at pressure requires power. The superchaeger takes out of the crank. The turbo takes it from blowdown pressure. Some pumping hp and some temperature (as seen with the 300 degree temperature drop we have logged on a 12 psi kit across the turbine).
Toma is offline   Reply With Quote
Old 07-11-2013, 01:39 AM   #42
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
If you guys math any harder I will fertilize my keyboard
Ammonia is offline   Reply With Quote
AVO Stage 1 Turbocharger Kit BRZ / FR-S Now Available For Pre-Order! Boston Motorsports Forced Induction 82 07-23-2013 11:42 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Suggestions for more horsepower! Turbocharger upgrade + more! forzajuve Forced Induction 14 04-10-2013 08:51 PM
Report: BRZ STI Model Already in the Works, No Turbocharger Sport-Tech BRZ First-Gen (2012+) — General Topics 188 08-30-2012 05:53 PM
