#15 |
Drives: WRB BRZ
FA20club's kit makes 283ish-hp with 5.3psi.... Are you just trying to justify buying a SC?
#16 | ||||||
Reverse Burnouts
Drives: 2013 Argento FRS
smart person + sarcasm Quote:
sc = fun everywhere else PTuning @ 6.2 psi making almost 300 whp Vortech @ 10 psi making 250 whp what is the difference? the Ptuning turbo is pushing roughly one and a half times as much air (cubic feet per minute, CFPM) than the vortech even though the pressure is much less. how does this happen? read a book because i dont feel like explaining for the millionth time
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x Last edited by carbonBLUE; 06-25-2013 at 12:17 AM. |
#17 | |
Drives: Very very slowly
![]() Just think about what boost is actually measuring. If boost is measuring air flow, I would agree that 10psi from one turbo is different from 10psi from another. Also notice I said that if air intake temps were normalized, 10psi is 10psi. Look, I get it; it's an emotional topic and I didn't do myself any favors stirring the pot. But here goes again: boost is a measure of restriction of air going into the motor. And it is measured at the intake manifold. The difference between ptuning's 6psi vs vortech's 10psi can be explained by: different dyno. Not going to argue which dyno reads high and which reads low. Dynos are always a tool that is effective only when comparing deltas. Read a compressor map sometimes and see those efficiency islands? Between the surge and choke lines? Those correspond to pressure ratios. So yea, different turbos have different efficiency ranges at different pressure ratios. That's why I say if intake air temps are normalized since that is a huge indicator of how much power gain/loss. Think of it another way, if you have a hole you are trying to cram a piece of dough through, the restriction of the hole overcomes how much pressure you try to push the dough with. But hey, let's pretend superchargers don't have any parasitic drag through their belt drive system, that it doesn't take 900hp to turn the supercharger on Top Fuel cars. That the low torque of the FA20 is a great fit for any belt driven superchargers. There are numerous advantages to a supercharger, but apples to apples, a properly set up turbocharger will always be more efficient in making power. Heck, even ptuning whom you said is well schooled agrees with little ole me who didn't go to school, according to you. And on their own comparison chart, they show, on their dyno, the same phenomena I'm describing when different FI systems were compared. Interesting how I'm not schooled and they are - we are talking about the same thing.... So allow me to ask you, oh wise one, how would YOU compare the Vortech kit to a turbocharged system? Since Vortech isn't publishing their compressor map, we'll never know what it's efficiency range is. In fact, I remember a member here (Mandalay, I believe) who kept pressing for Vortech to publish specs on the supercharger unit, believing that the unit Vortech was supplying at the time doesn't flow enough to make 250whp. And you know what, he was right. And Vortech supplied an updated, larger, better flowing unit. At no cost to early adopters even, so kudos to Vortech for that. Oh, and before you accuse me of not having gone to school: if anyone would like to ping me privately, I will gladly tell anyone what I've been involved in. I'm really glad though, that I am no longer in this industry. I had a heck of a time with misinformation back in the day and I see that things haven't changed all that much. budi |
#18 |
Drives: 2013 Black FR-S
lol
#19 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
The restriction on the exhaust side matters too. That's why supercharged cars can loose boost from a header swap. The temperature of the air going into the motor isn't the only thing that changes when you swap from a T25 at 12 psi to a T3/T04E 60 trim at 12 psi and gain 100 horsepower. The difference in air temperature in this real world example(it actually happened to me) can't possibly cause that much of a gain. |
#20 | |
budi |
#21 | |
If serious, this is one serious(ly wrong) accusation and you need to do some serious homework on turbo sizing, flow and pressure. |
#22 |
Then just get all three different kind of FI systems on the same day, on the same fuel, on the same dyno. The difference will be very apparent.
#23 | ||
Mr. Cranky Pants
http://www.ft86club.com/forums/showp...&postcount=245 |
#24 |
#25 | |
Reverse Burnouts
the simplest way to put it Bernoulli's principle states that for an inviscid flow, an increase in the speed of the fluid occurs simultaneously with a decrease in pressure or a decrease in the fluid's potential energy. when applying this in the simplest for air pressure flow speed scenario: air pressure is constant with 2 turbos, if the tubing is the same with a difference only in velocity, you get 2 different power potentials this is why some kits make much more power than others at the same PSI soooooo if compressor A was at 10 PSI moving 50 cfpm and compressor B was at 10 PSI but only moving 30 cfpm then you will make more power with compressor A with 20 cfmp more you are able to maximize the combustion chambers volumetric efficiency. an engine, 2L for example, does not take in exactly 2L of air during an intake cycle because the valves do not stay open long enough during the cycle for the air pressure to equalize and with a turbo that pushes the same psi bust does it fastest will achieve a higher volumetric efficiency because well... the air moves faster into the cylinder during its limited intake time so in conclusion: why do turbos make more power than superchargers, even at the same psi? simple, larger tubing, and the air moves faster.... simple...
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x Last edited by carbonBLUE; 06-25-2013 at 12:33 AM. |
#26 | |
budi |
#27 | |
budi |
#28 | |
Reverse Burnouts
mathematical equations not preformed in computer language is what i am used to ![]() i remember using boolean expressions in algebra 1 but that was back in the 6th grade... lol
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
| AVO Stage 1 Turbocharger Kit BRZ / FR-S Now Available For Pre-Order! | Boston Motorsports | Forced Induction | 82 | 07-23-2013 11:42 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 02:47 PM |
| Suggestions for more horsepower! Turbocharger upgrade + more! | forzajuve | Forced Induction | 14 | 04-10-2013 08:51 PM |
| Report: BRZ STI Model Already in the Works, No Turbocharger | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 188 | 08-30-2012 05:53 PM |
