Old 06-24-2013, 03:03 PM   #1
buditjoenawan
Drives: Very very slowly
Comparison between a supercharger and a turbocharger at the same boost level
Same dyno, same peak boost. Just to compare the different torque curves and the resultant discrepancy due to pulley drag on the supercharger. If pulley drag is not present, then the supercharger and turbocharger puts out the same power, boost for boost.
budi
Last edited by buditjoenawan; 06-24-2013 at 03:05 PM. Reason: Image not showing up...flickr hates me...
buditjoenawan is offline   Reply With Quote
Old 06-24-2013, 03:06 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
You can't just compare PSI in forced induction.... efficiency comes into play, 10psi on turbo A might be different than 10psi on turbo B
Your dyno could be two different turbocharger models with different power outputs even though they are running the same amount of boost
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
Sonolin (10-07-2013)
Old 06-24-2013, 03:20 PM   #3
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
sorry, but horribly misinformed comparison.
SloS14 is offline   Reply With Quote
Old 06-24-2013, 03:44 PM   #4
ptuning
ptuning's Avatar
Drives: White FR-S
A PROPERLY set-up turbo system will make more power and torque everywhere on the same engine using the same fuel. The choice on what FI system to get usually comes down to cost and a few other factors, so turbos may not be a good fit for everyone. CARB exemption is an important consideration for California residents. This is where a SC may be a better fit, for instance.
Blue - PTUNING GT3076R Turbo 6.2 psi on 93 Octane Pump Gas
Green - Stock BRZ
Red - Centri-SC (raised rev limiter with no other mods)
Pencil - Blower (Early dyno sheet converted KW to WHP and WHP to WTQ) - Will update with new info once more dyno charts are posted.
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
86_Insider (07-12-2013), ScottDRFT (06-24-2013)
Old 06-24-2013, 03:51 PM   #5
buditjoenawan
Please enlighten us?
budi
Old 06-24-2013, 04:14 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
budi
10psi is not 10psi when they are on different turbochargers. You have to take into account FLOW at that pressure.
2013 FRS
Vortech V3 11psi
Old 06-24-2013, 04:20 PM   #7
buditjoenawan
Ah, but I disagree. 10psi IS 10psi: assuming you normalize intake air temps. It doesn't matter how the boost is made and by what, because that measurement is taken in the manifold. On the same motor, 10psi of boost measures the same restriction to airflow made with a turbocharger and a supercharger.
budi
Old 06-24-2013, 04:39 PM   #8
Opposed
Drives: 2013 Asphalt FR-S
budi
So 10psi on a T25 turbo is the same as 10psi on an 80mm turbo?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 06-24-2013, 04:43 PM   #9
DJCarbine
Thupercharged
DJCarbine's Avatar
budi
10psi of hot air is the same as 10psi of cold air?
I know you said "assuming you normalize intake temps" but when you normalize everything such as backpressure, compressor/turbine housing size etc..... you end up with 2 of the same turbocharger. Its the differences that make... a difference.
2013 FRS
Vortech V3 11psi
The Following 2 Users Say Thank You to DJCarbine For This Useful Post:
kuhlka (06-24-2013), Sonolin (10-07-2013)
Old 06-24-2013, 04:54 PM   #10
djdnz
1337
Drives: 2013 BRZ WRB S/C
budi
It's not "pulley drag", look at the boost chart. If you still don't understand, go read more before you start any more new threads.
djdnz is offline   Reply With Quote
Old 06-24-2013, 08:24 PM   #11
charged86
charged86's Avatar
What @DJCarbine is trying to explain is cubic feet per minute cfm. Also efficiency ranges play a factor. And those are complicated graphs.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-24-2013, 08:29 PM   #12
jamesm
10psi != 10psi unless they're coming from the same turbo. do we really have to go over this again?
Old 06-24-2013, 08:42 PM   #13
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
No. Let people who have never driven a vehicle on two different turbos continue spouting crap. Everyone else knows better.
Sellout is offline   Reply With Quote
Old 06-24-2013, 08:53 PM   #14
Scoobyrs25
Drives: 01 RS, STI V6 RA Limited, BRZ
he he... word. Volume and pressure are two different things entirely. Also, just to add to the fun: I have personally tuned an HKS supercharged FRS and my turbocharged BRZ. At 10 lbs of boost with the supercharger and only 8 lbs of boost with my GT2871, my turbo BRZ made 30 more hp and way more torque, much sooner. I don't remember the tq numbers, but for example, Evasive's car makes 200 tq at 4000 rpm, and my turbo does that at 2000 rpm. I'm sorry, but superchargers on these cars just seem to be lacking.
Scoobyrs25 is offline   Reply With Quote
AVO Stage 1 Turbocharger Kit BRZ / FR-S Now Available For Pre-Order! Boston Motorsports Forced Induction 82 07-23-2013 11:42 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Suggestions for more horsepower! Turbocharger upgrade + more! forzajuve Forced Induction 14 04-10-2013 08:51 PM
Report: BRZ STI Model Already in the Works, No Turbocharger Sport-Tech BRZ First-Gen (2012+) — General Topics 188 08-30-2012 05:53 PM
