#57 | |
Drives: 2013 frs
Sent from my VTR-L09 using Tapatalk |
#58 | |
Drives: Q5 + BRZ + M796
You are asking that if you can find a spring combo that holds 8psi, should you, even if that is not what the spring/s are rated for? If I were you, I would want to resolve the issue. Maybe replace the wastegate with a friend’s wastegate to eliminate that as a possibility. It just doesn’t seem safe.
#59 |
Drives: UK GT86
You could so long as the tune is solid and done for that boost pressure. Just need to raise the boost cut level.
.: Stealth 86 :.
#60 | |
Drives: 2013 frs
#61 |
Drives: 2013 frs
i was doing some research about the wg opening above the spring rating and someone mentioned backpressure. i have a trd catback which according to some. its got some 2.25 bends and its not the greatest for performance. could that harm the wg opening accuracy?
#62 |
Dismember
Drives: 2013 Red Scion FR-S
I still expect this threat to be about jerking off while flooring the car. I mean, am I the only one?
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Irace86.2.0 (06-22-2018) |
#63 |
Drives: 2013 frs
#64 |
Drives: 2013 frs
https://datazap.me/u/bryancatano93/l...6?log=0&data=7
heres a wot log. car is still overboosting a lot. not hitting fuel cut but im still scared of those numbers. specially with the low rate springs. imma put a softer spring today and check at what psi it opens. take a look Sent from my VTR-L09 using Tapatalk |
#65 | |
Drives: 2013 frs
![]() Sent from my VTR-L09 using Tapatalk |
| Sudden Power Loss / Hesitation and jerking under WOT | Jesse36m3 | Forced Induction | 6 | 05-14-2018 09:59 PM |
| Engine bogging / stumble / hesitation / jerking during accelaration ard 2.5k - 3k RPM | mo420 | Issues | Warranty | Recalls / TSB | 24 | 07-29-2017 07:35 PM |
| CEL p0456 code, jerking when braking | RedNWhite | Issues | Warranty | Recalls / TSB | 7 | 06-03-2016 06:35 PM |
| M/T and idling over speed bumps - jerking | mstoochn | Issues | Warranty | Recalls / TSB | 7 | 04-29-2015 04:45 PM |
| Was I being hard on my car? | Fr-s13 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 07-04-2013 09:54 PM |
