Old 01-09-2018, 12:35 PM   #29
churchx
churchx's Avatar
Drives: 2014 GT86
Twinz: Best think of wheels (and brake rotors) as four flywheels. Going at constant speed/cruising engine will need same power with wheels of different weight. But you need to input more energy to spin them up to speed, and more energy to slow spinning due more stored rotational energy as with any flywheel. So car will accelerate slightly faster and will stop slightly sooner. Not by much, but with big weight differences it can be noticeable. More so vs removing same amount of weight elsewhere. Also in addition to that being rotational it's also unsprung weight. Lighter wheel/suspension can react better on road defects, as there is less mass inertia for springs to move wheel&brakes assembly&it's suspension arm alongside those bumps/roadholes, impacting slightly grip (wheel is more of a time and with better contact with road) and comfort. For many 'butt dyno' margin of detection error might be larger then slight weight difference, but if difference is much larger (eg. forged wheels and even more so + lightweight BBK), or in opposite to lightening direction (installing for sake of looks big heavy barrels for wheels of too big size, heavy weight and with heavier due width tires), then it can be felt subjectively by most. More so then with empty or full tank.
Old 01-09-2018, 01:30 PM   #30
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I agree on the handling aspect but for acceleration sake, even if we think of the wheels as flywheel, the vast majority of resistance is from the mass of the car itself and the load it creates when the wheel tries to move it.
If the wheel was just spinning in the air, that would be one thing, but it's sandwiched between the earth and a 2700lb car.
Twinz is offline   Reply With Quote
Old 01-09-2018, 05:22 PM   #31
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
While in theory, a lighter wheel will provide more response in both turning and accel/decel but the reality is that the strength of the wheel tends to provide a larger difference.
I remember reading an article where Enkei took 2 sets of the exact same wheel and shaved as much weight they could off one set. The set with weight removed negatively impacted rigidity although they were about 4 pounds lighter per wheel. Then they tested each set back to back on track with exact same tires on the exact same car and the heavier wheels were repeatedly faster. In the test data, the lighter wheels had slightly faster top speeds on the straights but lost time in the corners to the tune of half a second on a minute long lap. Enkei suggests this was due to improved steering feel and feedback to the driver with the stiffer wheels.
The take-away is that there are always compromises. At most, you are impacting performance by half a second per minute in a track situation. I'm a track rat so that is always a consideration for me but outside of that, I wouldn't worry about it and get what I think looks best within my budget.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
nikitopo (01-11-2018)
Old 01-09-2018, 05:51 PM   #32
churchx
churchx's Avatar
Drives: 2014 GT86
Lynxis: point is to not go overboard with lightening wheels. In that experiment imho Enkei overdid cutting material out for lightening from regular wheel and maybe even at wrong places/amount, and wheel rigidity got below acceptable, it got too weak. Not sure if results of this experiment can be attributed to lighter wheel that is designed from ground up such and tested/certified for specific loads. Rest being same forged wheels can be lighter even while still as rigid as heavier cast ones. Also often oem wheels are too strong then it's really needed due manufacturer erring on safe side to lessen any possible warranty work even if car is abused way above reasonable, with owner driving it without any care over worst roads possible at high speeds. Mentioned some posts above as example RPF1 imho is reasonable compromise of strong enough but light wheels. Something like Kosei K4R (even lighter, with weight on par to forged wheels of that side, but seen them talked about as easy to bend wheels) might be lightened too much.
Well, however things end, if someone decides to change stock wheels to aftermarket ones (most probably for looks), it's worth to at least not go for heavier ones. If it can be afforded, then - lighter ones, that are still sufficiently strong.
Lynxis (01-11-2018)
Old 01-11-2018, 11:04 AM   #33
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
that is why it is worth spending too much money on good forged wheels. I have had Volk Ce28N wheels on my Yaris for a decade. I'll take $200 a year for a wheel that can survive anything and is lighter than anything else.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Tristor (06-30-2019)
Old 01-11-2018, 12:56 PM   #34
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I was reading lately about the flow formed technique. A few manufacturers that use it is Rays, Enkei and Work.
A nice article related with cast, flow formed and forged wheels.
http://speed.academy/why-wheel-manuf...rating-matter/
A wheel I like is Work's M.C.O type CS, which is used in the 86/BRZ Gazoo races. Some wins here:
https://www.work-wheels.co.jp/en/top...ry/86brz_race/
Old 01-11-2018, 02:18 PM   #35
Lynxis
Lynxis's Avatar
Yes, all things considered equal, a lighter wheel is preferable but as I mentioned, there are always compromises. All wheels are manufactured with certain price, weight, stiffness targets. Compare wheels in Enkeis Racing line to the RR line. Many lighter and cheaper wheels are available in the Racing line but for drivers who value feedback and require more durable wheels for bouncing off curbs and pulling 2+ gs around corners, the RR wheels are for them. Of course, if you want an exceptionally stiff and lightweight wheel, I hear carbon fibre is making the rounds these days... but expect to pay around $3000 per wheel right now...
Old 01-11-2018, 02:58 PM   #36
tennisfreak
Drives: 2018 BMW M240i
Feel the difference for yourself.
Take a 4lb weight in your hand and hold your arm straight out. Rotate the arm.
Then do it with an 8lb weight.
There is your answer.
The Following 3 Users Say Thank You to tennisfreak For This Useful Post:
Busybee (06-07-2020), sroby (01-21-2019), why? (01-14-2018)
Old 01-11-2018, 03:04 PM   #37
OH god somebody get's it! I was beginning to wonder. This is the same concept as people that think they can feel an improvement in acceleration created by the 4 ounce weight difference in a light weight pulley.
sroby (01-21-2019), strat61caster (01-12-2018), Twinz (01-11-2018)
Old 01-11-2018, 03:05 PM   #38
That is NOT the same thing.
Old 01-11-2018, 04:02 PM   #39
Twinz
Twinz's Avatar
That 2700lb car is what makes the engine work to rotate the wheels. Yes, technically, the mass of the wheels themselvs add to the work. But then, technically, standing next to a swimming pool and peeing in it raises the water level too.
Old 01-11-2018, 04:04 PM   #40
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Acceleration is different with a heavier or larger wheel. Many times it matters even if the weight is similar, but distributed far away from the center of the wheel. Check in last column timings where corner entry speed is larger and acceleration is smaller giving a smaller top speed:
Source: http://www.roadandtrack.com/car-cult...ransformation/
Old 01-11-2018, 04:14 PM   #41
Racecomp Engineering
https://mbworld.org/forums/c63-amg-w...orsepower.html
Originally Posted by HRE Wheels
Test:
Davenport Motorsports (www.davenportmotorsports.com) of Canada, wanted to see the dyno effects of running different wheels on cars. They took a factory 2012 Camaro SS and ran 3 dyno runs. They ran the first run with a set of aftermarket wheels, the 2nd run with a set of stock factory wheels and the 3rd run with a set of HRE P45S wheels, all in 20” sizes.
These results highlight the effects of rotational inertia on drive-train losses (the hp lost between the engine crank and the ground). Wheels and tires contribute to drive-train losses as energy is used to spin up the wheels (and decelerate the wheels under braking). From the dyno chart you can see the effect of replacing factory wheels with lighter HRE wheels and see the negative effects of installing heavier aftermarket wheels.
Results:
1. (Blue curve) Factory wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 68 lbs combined per rear wheel. – Max hp: 371 hp, Max Torque: 375 ftlbs - (Baseline)
2. (Red curve) Aftermarket wheels: 20”x9.0” with Pirelli 275/40-20 tires weighing 72 lbs combined per rear wheel – Max hp: 369 hp, Max Torque: 373 ftlbs - (A [-] loss of 2 hp and 2 ftlbs)
3. (Green curve) HRE wheels: 20”x11.0” with Nitto 315/35-20 tires weighing 60 lbs combined per rear wheel – Max hp: 380hp, Max Torque: 384 ftlbs - (A [+] gain of 8 hp and 9 ftlbs and that is running a 2” wider wheel/tire combo)
Conclusion:
The engine obviously still cranks out the same amount of hp and torque, the lighter HREs simply waste less of it before it gets to the ground. Also interesting to note is that the gains are not just peak gains, but gains across the entire rev range. If they had done a braking test, we would have seen similar results as the rotational inertia effects also have a significant effect on how much energy is used to stop the wheel/tire combo vs. stopping the car. We talk about these effects all the time and focus on designing lightweight wheels with low rotational inertia, but it isn’t every day that you get to see real hard data showing the true effects.
- andrew
Racecomp Engineering is online now   Reply With Quote
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Icecreamtruk (01-11-2018), jmark (01-11-2018), nikitopo (01-11-2018), SuperTom (04-26-2018)
Old 01-11-2018, 04:39 PM   #42
Twinz
Twinz's Avatar
For the FRS, you are comparing two different-diameter wheel/tire combos. You are changing not just the weight, but the length of the "lever".
This test has two samples with the same outer diameter and the results of those two pulls fall within the "noise" of dyno pulls. My 350Z spent a good amount of time on different dynos and no two back-to-back runs ever matched....even when nothing was changed on the car between pulls.
I'm not saying that lighter isn't better. I personally think getting heavy rotating wheels to turn on the horizontal plane (left/right) is more likely to be felt by the driver than getting those same heavy wheels to move a much heavier vehicle forward.
Will changing wheel width and offset affect alignment? azynneo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-15-2017 02:46 PM
Am I missing something (fuel consumption vs performance vs weight) GRoss FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 33 09-23-2014 04:34 PM
Ideal size width and weight for max performance Boofneenee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-29-2013 04:44 PM
Best light weight performance tire brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-04-2012 03:24 PM
