Old 12-19-2015, 12:35 AM   #1
rickygt86
Drives: 2015 FR-S Raven
Car feels sluggish after new Intake + Exhaust
Hello everyone,
This is my first time posting on this forum although I've been lurking around for a while.
Recently I went and invested in a new intake+exhaust. Installed it about 3 days ago and it's feeling a bit sluggish compared to the OEM stock intake and exhaust. Was wondering if either I did the install incorrectly or the car just needs to get used to the new components. I made sure there were no leaks from the exhaust and that in intake was firmly bolted.
It is an Injen air intake and a greddy exhaust. Also this exhaust is super loud. no idea it was gonna be this loud lol
Thanks!!
rickygt86 is offline   Reply With Quote
Old 12-19-2015, 12:36 AM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
did you tune?
Old 12-19-2015, 12:47 AM   #3
stockysnail
Just the tip
stockysnail's Avatar
Is it a catback exhaust, full exhaust? Need more details. I would guess the intake you installed is doing it as the MAF sensor plugs into it. First step is to put the stock intake back on, then see if it still does it. You don't need to put the sound generator back in, just plug the hole where it was. Generally speaking I would avoid the Injen intake. As I've heard over the years some people having small issues with that type of intake and losing a little power. If my above suggestion doesn't work or you're not willing to put the stock intake back in I would remove the positive battery connection for a while so the computer resets and relearns. I'd try the putting the stock intake back in first though.
The Following User Says Thank You to stockysnail For This Useful Post:
humfrz (12-19-2015)
Old 12-19-2015, 12:53 AM   #4
rickygt86
Originally Posted by Packofcrows View Post
did you tune?
I have not, I was looking into local shops in my area.
I was thinking about doing a tune down the road
The Following 2 Users Say Thank You to rickygt86 For This Useful Post:
Digitalanalog (12-19-2015)
Old 12-19-2015, 12:56 AM   #5
rickygt86
dual catback with just midpipe, stock OEM front. greddy evo gt it is called i believe.
I'll put back the stock intake since the install is relatively easy. do you think I should just drive it for a couple more days to see if everything settles?
thanks for the reply!
Old 12-19-2015, 12:59 AM   #6
How far have you driven it? Sort of along the lines of what Stocky said the ECU will have to relearn some things with the new intake (presuming you have a catback then that won't affect anything). It can take a 100 miles or so sometimes.
Give it some time to learn or like Stocky said switch the intake back and see if that makes a difference.
Old 12-19-2015, 01:22 AM   #7
rickygt86
since i just did it about 3 days ago, probably less than 75 miles since then.
Old 12-19-2015, 01:23 AM   #8
Well it should be close to learning then. I would still give it a little longer before pulling the intake.
Old 12-19-2015, 01:28 AM   #9
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
The stock air box is pretty efficient, to be honest. Unless if you're chasing the cone filter/cold air intake noise, a drop-in filter is basically all you need. Chances are the MAF scaling for the new intake is different, so it may require a tune. As far as I know, only a few aftermarket CAIs are close to the factory MAF scale. The Grimmspeed one comes to mind. If you have a datalogger you can compare commanded AFR to actual AFR to get an idea of how far off the scaling is.
jawn is offline   Reply With Quote
Old 12-19-2015, 01:54 AM   #10
rickygt86
okay ill do just that, if it seems to be doing the same thing I will try putting back in the stock intake. hopefully all goes well!
The Following User Says Thank You to rickygt86 For This Useful Post:
Tcoat (12-19-2015)
Old 12-19-2015, 01:55 AM   #11
Please let us know. I am curious now.
Old 12-19-2015, 01:56 AM   #12
rickygt86
The CAI was recommended to me by someone who had one. This is the first car I purchased on my own that has more than 130HP (lol). so i'm pretty stoked about adding stuff to it. maybe I jumped the gun to quickly haha. the car has only about 4000 miles on it
Old 12-19-2015, 02:00 AM   #13
Check these out
http://www.ft86club.com/forums/showthread.php?t=47798
http://www.ft86club.com/forums/showthread.php?t=15651
Old 12-20-2015, 01:46 AM   #14
rickygt86
Interesting, thank you for the post.
Do you know anything about OFT? Is there stage 1 tuning good enough for an aftermarket exhaust +intake?
Car feels "sluggish" and less nimble with new rims/tires autograph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 04-04-2015 08:38 AM
Feels sluggish after clutch pedal adjustment brianhj Engine, Exhaust, Transmission 6 08-24-2013 01:58 PM
frs sluggish in first and second gear at 2k-4k rpm M&W_FRS Issues | Warranty | Recalls / TSB 3 06-23-2013 04:09 PM
Sluggish/Stalling After aFe Intake Install FR-S Matt Engine, Exhaust, Transmission 6 01-15-2013 09:57 PM
So... is it sluggish? Surge101 BRZ First-Gen (2012+) — General Topics 62 06-04-2012 06:30 PM
