Old 04-02-2015, 10:25 PM   #1
autograph
autograph's Avatar
Drives: 6MT Hot Lava
Car feels "sluggish" and less nimble with new rims/tires
Hi guys. I recently purchased a set of RPF1 17x9 wheels (+45) and Bridgestone RE-11's (235/40/17). Although I love the extra grip, I can't help feeling the car feels a lot less nimble. I came from using snow tires on the stock wheels, and the snow tires were around 23 lbs.
The RE-11's are 25 lbs. The 40 aspect ratio also means a slightly smaller diameter. And of course I dropped ~4.x lbs from the stock wheels. Despite this, the car feels much more sluggish and not nearly as "nimble". Slow speeds in first gear seem to bog it down and launching seems to take a little more gas.
Is this the effect of increased grip that I am feeling? Or is it the 25 lb tires and the weight being more towards the outside that I am feeling? Car feels like it has more "rolling resistance" also, if you know what I mean. Not very experienced with changing out tire setups.
Thanks for your input
autograph is offline   Reply With Quote
Old 04-02-2015, 10:45 PM   #2
wparsons
wparsons's Avatar
Wider, stickier, tires will definitely have more rolling resistance, but I would also bet some of it is placebo. Are the tire pressures good?
flickr
Old 04-03-2015, 12:29 AM   #3
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
1. You have a noticeably higher MOI (moment of inertia) with the 25lb and very grippy compound tires.
2. The 1" wider contact patch on a wider track is trading agility for stability when it comes to transitional handling, so the car will be less willing to change direction as quickly.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 04-03-2015, 12:34 PM   #4
JS + BRZ
Drives: 2010 MS3
Had the same feeling on the first day.. trust me you will love the new set up.
JS + BRZ is offline   Reply With Quote
Old 04-03-2015, 01:47 PM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Well. You know what this means? New coilovers.
Old 04-04-2015, 12:09 AM   #6
autograph
autograph's Avatar
tire pressure is at 32 psi. lolll.. oh boy.. coilovers. might as well lmao. and im about to supercharge too.. bye bye paychecks
Old 04-04-2015, 12:22 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 04-04-2015, 01:40 AM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Please get good ones, I see too many people compromising for cost. Just wait for the right set, and save save save. If you don't 110% like it, don't buy it. Get rides, do research. Good luck.
Old 04-04-2015, 01:57 AM   #9
Higher Being
Drives: 2014 Asphalt Grey FRS
Try raising your tire psi, dont get too crazy, check out the max psi on the side wall of the tire. But i run a higher psi tire when its nice and dry, its a slight change, but you can "tune out" some of the excessive grippyness.
Higher Being is offline   Reply With Quote
Old 04-04-2015, 02:38 AM   #10
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Give it two weeks and you will forget how it drove before.
That being said, I went from huge heavy wheels to much much lighter than stock wheels/tires because of such things.
Kostamojen is offline   Reply With Quote
Old 04-04-2015, 07:38 AM   #11
longhornjoe
Drives: '13 Raven FR-S
I noticed the same after upgrading to my lighter O. Z. 17x8 wheels and Michelin Pilot Sport AS/3 225s.
Installing a Perrin steering rack lockdown seemed to offset a lot of the sluggishness.
http://perrinperformance.com/i-15768...-fr-s-brz.html
longhornjoe is offline   Reply With Quote
WTB: OEM BRZ 17" Rims and Tires - Looking to BUY 335icandy Canada Classifieds 17 05-15-2014 09:15 PM
18" rims/tires with stock height ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 11-05-2013 04:23 PM
Feels sluggish after clutch pedal adjustment brianhj Engine, Exhaust, Transmission 6 08-24-2013 12:58 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 08:33 AM
