Howling sound turning
I get this howling / warping air sound when I turn right on my car. I can replicate it almost every single time, any suggestions / advice on what I should look for?
#2 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
| The Following User Says Thank You to Aztec For This Useful Post: | cdrazic93 (12-11-2015) |
#3 |
You should mention your mods and maybe a pic of how low you are. Also do a visual inspection if you haven't done that already. Have someone ride in your car and stick their head outside and see if it is from the front or rear, left or right side.
#4 | |
I thought it was after getting my 4.88 installed but it seemed it did that before according to a friend |
#5 |
Drives: 2014 BRZ SCCA STU endurance car
Does it sound like it's coming specifically from the front or the rear?
#6 |
#7 |
Drives: 2016 Oceanic, "base" model
Are your tires' pressures okay?
#8 |
Drives: '13 FRS - STX
Might be an alignment issue, tires not pointed in the right direction can make a helluva noise.
#9 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Noise? Who cares? Why? Becuase racecar!!!
Does it happen at all speeds? |
#10 |
Drives: 2005 Toyota Camry
It would help if you provided how you replicate this noise.
-alex |
#11 |
Not Bаnned Anymore
Lets all just take random guesses and see who was right
![]() I think its a wheel bearing |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Ultramaroon (12-10-2015) |
#12 |
Frosty Carrot
Drives: The Atomic Carrot
Commence the random guessing!
All that FA20 squirrel power finally busted loose:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | go_a_way1 (12-09-2015) |
#13 |
i tried replicating the noise today.. couldn't do it.. I was able to do it last night.
I replicated this noise by turning the steering wheel all the way to the right / going slightly up a slope or down from a slope. |
#14 |
Drives: 2013 FR-S Argento
Sound like it could be tire rub?
Sent from my iPhone using Tapatalk Last edited by bfrank1972; 12-10-2015 at 11:01 AM. |
| Turning the FR-S into a Mustang Soon | Areddi | Mid-Atlantic | 3 | 09-15-2015 11:31 AM |
| Foglights not turning on | Bergen23 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-26-2015 09:57 AM |
| Sub pop when turning off car | Noob4Life | Electronics | Audio | NAV | Infotainment | 2 | 07-27-2013 03:12 PM |
| TC turning back on after turning it off | Xdragonxb0i | Issues | Warranty | Recalls / TSB | 2 | 02-01-2013 04:19 PM |
| AC pump turning on and off | BRZY | Issues | Warranty | Recalls / TSB | 3 | 11-26-2012 03:17 PM |
