Old 04-28-2015, 10:53 PM   #15
gramicci101
Off Topic
Originally Posted by wparsons View Post
^^ top hole, not bottom hole. You'll get more adjustment range in the top hole.
Ok, I was just going off the instructions. Top hole it is.
Old 04-28-2015, 10:54 PM   #16
wparsons
wparsons's Avatar
Whiteline says top hole, same bolts. Consensus is that the bottom hole really limits how much adjustment you get.
flickr
Old 07-23-2015, 07:42 PM   #17
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
Put in SPC bolts in the front and LCA's in the rear.
After coming off the alignment rack specs are bang on and didn't need to use toe bushings.
-2.0 front camber 0 toe.
-1.5 rear camber 1/32 toe on each side for total 1/16
DieselDog is offline   Reply With Quote
Old 07-24-2015, 11:01 AM   #18
Basket Case
Drives: 2013 Raven fr-s
Not to thread jack, but can the rear camber be adjusted at all without LCA's? I have hotchkis springs and havnt gotten anything aligned yet. You can visably see the negative camber in the rear. Will an alignment even gain me anything?
Basket Case is offline   Reply With Quote
Old 07-24-2015, 11:40 AM   #19
wparsons
wparsons's Avatar
There is zero camber adjustment stock, so if you want to change it then you'll need parts.
flickr
Old 07-24-2015, 11:48 AM   #20
Basket Case
wow, so then there really is no point in getting an alignment done after a spring install then unless you get the LCA's...At least my car tracks strait.
Old 07-24-2015, 11:59 AM   #21
Racecomp Engineering
Your toe does change after a spring install, so you'll want to take care of that at least (and yes there is toe adjustment stock). Toe is more important for tire wear than camber as well.
- Andrew
Old 07-24-2015, 12:05 PM   #22
Basket Case
- Andrew
Cool, I guess i will actually go and get it done then...Going on a couple thousand mile trip next week, probably best to not ruin my tires, lol.
Old 07-24-2015, 12:40 PM   #23
wheelhaus
wheelhaus's Avatar
Toe is the most important factor for tire wear.
Camber (static camber) can have an effect on tire wear, but the idea for camber is to balance inner/outer wear to your driving style and utilize more contact area when you need it most.
Caster only affects the front wheels, and it's not adjustable without camber plates. This is the axis the wheel steers around, like the angle of a bicycle fork. It helps the tire lean into a turn, and can be considered "dynamic camber" because it changes the tire's camber as the wheels are turned farther.
If you're 98% highway miles, then OEM to -1° F and -0.5°R would probably be just fine.
If you have a more "spirited" time behind the wheel and uh, well, frequently capitalize on any opportunity to utilize more lateral grip, then -2 to -2.5 F and -1.5 to -2 R should be fantastic. The idea here is to square up the tire's contact patch in a loaded turn when the outside tires are weighted.
There's no perfect alignment for everyone, the factory just gives safe ranges to make the car understeer and more stable.
For anyone not getting an alignment after lowering... wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-16-2014 12:13 AM
Alignment question? cjsporl1996 Tracking / Autocross / HPDE / Drifting 13 05-12-2014 05:00 PM
Alignment After Lowering mjsivee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 12:12 PM
Proper Alignment - Post Eibach Pro Lowering Thatruth2001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-10-2012 02:48 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 03:57 PM
