Old 04-09-2015, 03:34 AM   #15
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by WhiteChocolate View Post
2013 frs
The 2013's were prone to AVCS failure. Definitely covered via warranty.
Old 04-09-2015, 11:09 AM   #16
WhiteChocolate
WhiteChocolate's Avatar
Drives: White like Chocolate
SO when i go to the dealer should i mention that?
WhiteChocolate is offline   Reply With Quote
Old 04-09-2015, 12:29 PM   #17
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Yes, but your also only getting TCS light. Not a CEL. A better assumption would be your speed sensor. Your car would be idling very rough if you had AVCS sensor failure.
Old 04-09-2015, 03:31 PM   #18
WhiteChocolate
I have the CEL and traction control light
Old 04-09-2015, 06:43 PM   #19
BRZChix
Drives: Subaru BRZ 2013
If they are on at the same time, it is bad news. Bring the car in the dealership and ask them for a loaner until they take care of the issue.
CEL and TCS light on at the same time might be more serious issues.
Whatever it is, since your car is under warranty, make sure it is fixed correctly. Else you might want to look into lemon the car.
BRZChix is offline   Reply With Quote
Old 04-09-2015, 09:41 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Dealer.
Old 04-09-2015, 10:18 PM   #21
WhiteChocolate
Idk if they'll give me a loaner because I'm under the age of 21
Old 04-10-2015, 08:00 AM   #22
WhiteChocolate
Every time I've gone they've made the lights go away for like 50-100 miles then they come back. Do you think they'll give me a loaner car if I'm 18?
Old 04-10-2015, 08:55 AM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
Souns like they 'fixed' in a way some tuners do. - Cleaning CEL code. Not investigating and fixing actual cause.
Old 04-11-2015, 01:49 AM   #24
WhiteChocolate
Dealer.
Old 04-15-2015, 11:12 PM   #25
WhiteChocolate
UPDATE: Looks like they're putting in new cam shafts. So we'll see if this fixes the issue
Old 09-23-2015, 09:21 AM   #26
WhiteChocolate
Looks like they did the change and also had to put in a new ECU. Everything is fixed now
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 09:28 AM
Abs and Traction Light nabil_frs Issues | Warranty | Recalls / TSB 14 07-09-2015 09:39 AM
ABS + Traction Light After Fog Install Wyattkb Issues | Warranty | Recalls / TSB 1 03-22-2015 05:47 PM
CEL and Traction Light came on today myjobis2pimp NY / NJ / CT / PA 9 10-05-2014 01:45 AM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 01:04 PM
