| View Poll Results: Best Lower Control Arms? | |||
| Stance |
33 | 14.60% |
| Whiteline |
32 | 14.16% |
| Cusco |
51 | 22.57% |
| SPC |
34 | 15.04% |
| Megan Racing |
4 | 1.77% |
| GTSpec |
4 | 1.77% |
| ISC |
8 | 3.54% |
| DME |
1 | 0.44% |
| Agency Power |
1 | 0.44% |
| None of the above (post reply of other product) |
58 | 25.66% |
| Voters: 226. You may not vote on this poll | |||
#29 |
So elite I'm 1338
Drives: WRB Subaru BRZ
I'm going to say whiteline, because spherical mounts bump me out of stx.
-Jack Burton |
#30 |
Drives: 2016 FR-S
RacerX is fine for just camber adjustments but doesn't come close to the adjustability to the SPL which has multiple sway bar link holes and lower shock mounting holes. I drive mine on the track a lot so the additional adjustment features on the SPL were a must have for me. I haven't found another LCA with comparable adjustability, tuning, features.
#31 |
F Z1LLA
Drives: Lexus IS-F Series 2
Whiteline cuz they're so dam pretty!
2URGSE |
#32 |
Time Traveller
Powered By Max LCA's
Lowering like Stance LCAs but with two positions (20mm and 45mm lower) Designed, and tested by PBM (this is huge). CHEAP -$220 a pair. http://www.partsshopmax.com/page.php?59
#33 |
Drives: AVO Turbo Subaru BRZ / Subaru WRX
What about Flatwell LCA? They are used on the RS-R Formula D 86
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
#34 |
#35 |
Time Traveller
RS-R is also selling Rear LCAs - $525.00
http://www.rs-r.com/product/rs-r-rea...-control-arms/ http://www.fteightysix.com/new-produ.../#.VMlgbaOQc1s
#36 |
Turning is for Nerds
Drives: 35 characters is not enough
FWIW the latest rev of SPL arms have even more adjustability.
#37 |
Drives: Whiteout Scion FR-S
I've always wondered why the SPL LCA's don't have any cross bracing like every other LCA on the market. Are cross braces needed or not for rigidity?
My cars always dress formally. They all wear black tires.
#38 | |
Flatwell LCA's at RHD Japan
#39 | |
Reasonable price and the shipping cost to where I am is pretty good.
#40 |
Theoretically, there shouldn't be much torsional force about the center-line or shear force across the center plane. Also once the shock and sway bar are bolted up and torqued, they effectively add to the overall rigidity.
#41 | |
I think that is exactly right. If you look at where the shock and sway bar mount, they effectively split the open span into 1/3s with only a few inches between each span, which should be more than strong enough for the minimal forces the LCA will see in that direction. Also, I am not sure of the material used for other LCAs, but the SPLs are titanium, which could contribute to the lack of cross bracing required. |
#42 | |
