Drives: 2013 Whiteout FR-S
6MT wont shift?
Car has 14000 miles and not driven too hard. I have not had any previous issues, then yesterday car wouldn't go into any gear while car is on, car off transmission works, no grinding or blockages. clutch still has pressure behind it. and no noises while trying to shift. any ideas. car is at dealership under warranty repair.
'13 6MT Whiteout FR-S
http://www.ft86club.com/forums/showthread.php?t=117970 |
#2 |
Let's see if I have this straight.
Your MT car will NOT go into gear if the engine is running, but it WILL go into gear if the engine is NOT running .. ?? If this is the case, that's above my pay grade ... ![]() Next .... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Mr.EvoMR (01-06-2014) |
#3 | |
Drives: 2013 Whiteout Scion FR-S 6MT
#4 |
Drives: WRB BRZ Sport Tech
Sounds like it could be a couple of things 1) pilot bearing is toast which is causing the input shaft to still spin even with the clutch in ( this happened to me with my Truck), or 2) your slave cylinder/clutch master cylinder is toast and not releasing the clutch by depressing the pressure plate.
| The Following 2 Users Say Thank You to Gords_zenith For This Useful Post: | Mr.EvoMR (01-06-2014), StRacngtC06 (01-06-2014) |
#5 | |
Drives: C6 Corvette Z06
Thread Starter: What does the clutch fluid itself look like? Still yellow and transparent? Car is at dealer? Let them figure it out then
#6 |
The Answer
Drives: Mazda 2
Could be a broken clutch spring/assembly, manuf. defect.
#7 |
I will be interested in the answer to this when you find out. I have a 2001 PT Cruiser that has been sitting in a garage for 3 years with the same problem. All hydraulics are working as I can see the fingers on the pressure plate move when the clutch is depressed. Didn't have the money to fix it when it happened and I had another car to drive, so it's been sitting.
#8 |
I did check the clutch fluid and it was looking brand new. got a call from dealership, mechanics found broken clutch springs inside.... new clutch assembly ordered.
#9 |
#10 |
well I didn't beat on it if that's what u mean...it always did feel really tight though.
#11 |
Shocked the dealer did not tell you the reason for the failure was because you were born.
| The Following User Says Thank You to Dezoris For This Useful Post: | sosick (01-08-2014) |
#12 |
#13 | |
Drives: 13 Subaru BRZ Limited
![]() I totaled my Miata on some slick roads so I am up for a new car...thinking the FR-S/BRZ. You must be in one now. Just wanted to say hi again
#14 | |
Yep, the same old humfrz ..... after my miata, I got an FR-S; I wasn't quite ready for a Buick ..... yet .... ![]() Sorry to hear you lost your miata ..... ![]() I replied to your PM. This is a good forum .... ther folks are generally a bit "younger", but they still tolerate my "back in the day" stories (I think). If you go with a FR-S/BRZ, come join us ..... humfrz |
| Car wont start? Anyone else? | ScionFrsFan | Issues | Warranty | Recalls / TSB | 150 | 06-09-2017 10:35 PM |
| Car Wont Start Up HELP !!*** | ScionFR-S | Issues | Warranty | Recalls / TSB | 20 | 11-28-2013 02:01 AM |
| Right headlight wont turn on | Matt90 | Issues | Warranty | Recalls / TSB | 9 | 11-11-2013 04:56 PM |
| URGENT : CAR WONT START | DarkCard | Engine, Exhaust, Transmission | 9 | 08-01-2013 09:57 PM |
| trunk wont unlatch | bakerr6 | Issues | Warranty | Recalls / TSB | 9 | 09-24-2012 02:32 AM |
