4th to 5th gear grind.
Recently, I've been noticing that when shifting from 4th to 5th, it makes a crunch like feeling. I've been noticing this happening at least twice a week. I feel like it's starting to happen with 2nd and 3rd too but it's not nearly as bad.
It doesn't happen after that though for another couple of days and I drive a lot. I'm still under warranty which is why I'm bringing this up, otherwise I would've just forgot about it till the tranny died then paid the 500 bucks and did it myself. Anyone else experiencing this? I was thinking an oil change might make a difference but, I don't wana touch it so they don't say "oh you voided the warranty. Any similar experiences? Sent from my iPhone using Tapatalk |
#2 |
Drives: 2013 Asphalt Frs
Crunchy and grinding 5th is very common, something i am dealing with personally at the moment, its most likely bad synchros, i just recently got my car used so im not under warranty so im curious to see what some other people have done to remedy this, im sure there is a previous thread regarding this and if thats the case i hope someone could post a link to that here
| The Following User Says Thank You to GoZ21 For This Useful Post: | MisterSheep (07-23-2017) |
#3 | |
Wow thanks for your post! I bought mine used too but from a Toyota dealership and it came with the remaining balance. I might take it to the dealer and see what's up but it's common? I need to research on that Sent from my iPhone using Tapatalk |
#4 |
Same with mine, and I'm still under warranty. I was suppose to take it to the dealership on friday but some things came up and couldn't make it. The problem with mine is that it doesn't happen all the time and the technician couldn't replicate the problem (The first time I took it)
#5 |
Yes, very common problem in early production lf the car, like i said before it is most likely because of bad synchros. Best way to tell if that is the issue is to give the gas a little blip while your shifting into that 5th gear almost like rev matching a downshift, if the grind or crunch is somewhat alleviated you can almost be sure that the synchros are the culprit. Toyota in the beginning was ripping the gearboxes out of the 13 model and sending them out for evaluation when this was becoming a problem so take it into the dealer for sure
#6 |
Hey... I've got a header on my car and a tune. Should I tune it back to stock and rip out the header before going in?
#7 |
Drives: frs
Change transmission fluid, make wonders on that simple maintenance
#8 |
Drives: '14 BRZ Limited
Got mine used too, had bad synchros in my transmission. Took it in and got it replaced under warranty. Took a while to get the unit in from Japan.
Sent from my Moto G (4) using Tapatalk
2014 BRZ
Mishimoto intake tube/TSW Nurburgring 18x8/Firestone Firehawk Indy500s/PLM muffler delete/JDL catted UEL headers |
#9 | |
Did they give u hassle? What did u do to convince them ? Sent from my iPhone using Tapatalk |
#10 | |
Transmission work is standard drivetrain warranty thing. Sent from my Moto G (4) using Tapatalk
2014 BRZ
#11 |
Because compromise ®
Drives: Red Herring
Same with my 4th to 5th if I hurry. Usually I just ease it in (that's what she said)
and there is no graunch.
#12 |
Drives: 2017 Subaru BRZ
I've had that feeling in my old 2015 FRS and my brand new 2017 BRZ.
#13 | |
See this is what I'm wondering. I've heard of people complaining about our transmissions a lot. what's the point of getting a new one swapped in if they all feel like that. Some say an oil change with motul 300 makes a difference. Sent from my iPhone using Tapatalk |
#14 | |
| 4th gear grind | dallenj | Engine, Exhaust, Transmission | 15 | 06-03-2016 04:04 PM |
| 5th and 6th gear grind... | Basket Case | Engine, Exhaust, Transmission | 7 | 02-11-2015 08:53 PM |
| Grind Into 5th Gear | Since885 | Engine, Exhaust, Transmission | 8 | 01-18-2015 05:47 PM |
| 2nd gear grind (yup another one) | SmartedPanda | Issues | Warranty | Recalls / TSB | 17 | 09-10-2014 04:02 PM |
| 3rd gear grind | Mo707 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-29-2012 07:37 PM |
