Drives: GT86
Synchro issue
Hi guys,
I think i have a problem with my synchro, it grinds when shifting at high revs from 3rd to 4th gear. Any one had this problem? I'm out of warranty, so what would the cost to get this fixed, going to the dealer ship to have it looked at, but want to know a price so they don't rip me off. cheers |
#2 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | dvasqu01 (02-17-2016) |
#3 | |
Drives: Scion FRS Whiteout
Much help 😂😅 Yes I'll give you the rice noodle😘 |
#4 |
Drives: BRZ SWP Limited -6MT
yes, same issue. original tranny fluid. resolved issue by shifting sooner, or a little slower. will keep an eye out for the next 30k so miles or until I can find something better to go to the dealer for a check.
#5 | |
![]() First off, I would suggest you "check" your shifting technique. (remember, a warmer transmission is a happier transmission) I would suggest that when shifting, wind up the last gear pretty tight (4-5,000 rpms) before shifting into the next higher gear. Also, when shifting, pull (or push) the shift lever slowly and firmly into the next gear. I suggest you NOT "lazy leg" it ……. be sure to push the clutch pedal all the way to the floor. Check and make sure the clutch/brake fluid reservoir is full. Also, you may wish to check the clutch adjustment. If this technique doesn't help, you may consider changing the brake fluid and bleeding the system. Your transmission may like some new (different) oil. humfrz |
#6 |
I know. I felt kind of d!ckish but it was my turn.
#7 |
Drives: old
Had the same issue occasionally, trans was replaced under warranty.
#8 |
"D!ckish" does not become you, @Ultramaroon ........
![]() We already have enough "experts" in that field on this forum ...... ![]() humfrz |
#9 | |
You're right, though. I'm not that guy.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (02-18-2016) |
#10 |
#11 |
I don't recommend it. You don't strike me as a "Search, noob!" kind of guy either.
![]() Like @humfrz said, let's leave that to the professionals.
| 2nd gear synchro FIX- MT owners read this thread | gmookher | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 477 | 01-06-2019 07:22 AM |
| Synchro issue? and Dealership woes. | lextrueno | Issues | Warranty | Recalls / TSB | 31 | 05-28-2017 03:16 PM |
| Double Clutch vs Synchro wear | Concorazon | Engine, Exhaust, Transmission | 72 | 12-10-2015 04:16 PM |
| 5th gear synchro harshness? | Subie | Issues | Warranty | Recalls / TSB | 28 | 05-29-2013 05:22 PM |
| Will FT-86 have Synchro Rev Match? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 05-27-2010 12:05 PM |
