follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 6
1
2
3
4
5
Last
Showing results 1 to 30 of 151
Search took
0.32
seconds.
Search:
Posts Made By:
andrew20195
Forum:
Engine, Exhaust, Transmission
02-13-2017, 11:56 PM
62
Aftermarket pulley wobble with video
12,800
Posted By
Hawk77FT
Here is an educated answer from an engineer: ...
The crankshaft damper has nothing to do with engine balance and vibrations. Motion and oscillation of the powertrain, as an assembly, is addressed by...
Forum:
Forced Induction
05-18-2016, 01:12 PM
4,969
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
1,510,035
Posted By
BigFatFlip
^This. Its the front mount bracket that needs...
^This. Its the front mount bracket that needs "modification" since it installs in front of the LTR (intercooler radiator) and may interfere. Depending on where you decide to relocate the core, you...
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
04-21-2016, 04:24 PM
4,440
Sticky:
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
1,155,448
Posted By
Racecomp Engineering
The theory that many subscribe to that the rear...
The theory that many subscribe to that the rear natural frequency has to be ~0.3 Hz more than the front was NOT a theory that was developed to make the car faster around a track. It was NOT developed...
Forum:
04-19-2016, 05:15 PM
4,440
Sticky:
1,155,448
Posted By
ajc209
Problem with looking at only wheel frequency is...
Problem with looking at only wheel frequency is that is doesnt consider roll stiffness contribution from the roll bars.
I suspect RCE selected their spring rates to give the balance they wanted to...
Forum:
04-19-2016, 01:03 PM
4,440
Sticky:
1,155,448
Posted By
Ro_Ja
Awesome! Thanks for sharing that calculator. ...
While I've noticed that while the rear motion ratios of 0.77 is agreed upon by a lot of people who have done their own calculations, I have noticed...
Forum:
04-19-2016, 08:40 AM
4,440
Sticky:
1,155,448
Posted By
Shankenstein
I remember hearing Shaikh from Fat Cat...
I remember hearing Shaikh from Fat Cat Motorsports talking about his standard "aggressive street + light track" setup is 1.8-1.9 Hz in front and 1.9-2.0 Hz in rear.
As the CSG guys can attest, a...
Forum:
04-19-2016, 02:08 AM
4,440
Sticky:
1,155,448
Posted By
Ro_Ja
Right.. Ugh. I'm not very good at the numbers...
Right.. Ugh. I'm not very good at the numbers thing and apparently reading as well..haha
So, I got ~362 lb/in front and ~403 lb/in rear (man, that seems stiff). Based on Kost's testing, I suppose...
Forum:
04-19-2016, 01:56 AM
4,440
Sticky:
1,155,448
Posted By
strat61caster
Look here again: ...
Look here again:
http://www.ft86club.com/forums/showthread.php?t=26661
Motion Ratios:
F: ~0.95
R: ~0.76
Different terminology, same numbers.
Decent starting point if we did our math the same...
Forum:
04-19-2016, 01:49 AM
4,440
Sticky:
1,155,448
Posted By
Ro_Ja
So I'm playing around with Hyperco's spring rate...
So I'm playing around with Hyperco's spring rate calculator (http://www.hypercoils.com/spring-calculator) and I found a lot of information here (http://www.ft86club.com/forums/showthread.php?t=26661)...
Forum:
07-03-2014, 03:35 AM
290
Why do people do wild swaps(RB, LS1), when u can just buy a Porsche, Ferrari, etc?
80,053
Posted By
cf6mech
LS only adds 50 to 60 pounds over the OEM engine,...
LS only adds 50 to 60 pounds over the OEM engine, If your like me, going from FI, the turbo, inter cooler, piping, external oil pump etc.etc. that 50 to 60 pounds is negligible.... btw...that boxer...
Forum:
07-02-2014, 06:21 PM
305
A discussion on improving ride quality
100,845
Posted By
gramicci101
Fill the trunk with bags of concrete to simulate...
Fill the trunk with bags of concrete to simulate the weight of a rear-engined car?
Forum:
Forced Induction
07-02-2014, 02:58 AM
43
BadBRZ Turbo build discussion...
9,995
Posted By
Boss Paco
Do it. Don't be a puss.
Forum:
Forced Induction
07-01-2014, 05:03 PM
12
PTuning intake location?
2,744
Posted By
ptuning
As other owners have already mentioned, you will...
As other owners have already mentioned, you will notice very little difference in inlet temps vs ambient temps with our intake set-up. Once the car is moving, the intake will draw air predominantly...
Forum:
Forced Induction
07-01-2014, 11:29 AM
12
2,744
Posted By
mkivsoopra
FWIW, I typically see intake temps of about 5F...
FWIW, I typically see intake temps of about 5F over ambient when running off the wastegate spring and with the car moving.
Forum:
06-26-2014, 11:15 AM
16
Coilover quality progression
3,824
Posted By
7thgear
first there are physics then there is personal...
then there is personal preference
a suspension is designed to control physics that is in line with your preference
the list that you made is irrelevant because we...
Forum:
06-25-2014, 03:36 PM
39
Im buying coil overs within the next 2 days i need help deciding what coil overs
8,168
Posted By
7thgear
your goals are simply outrageous and your budget...
your goals are simply outrageous and your budget lacks forethought entirely
want to have fun in your car? go to an autocross or lapping day
4000 dollars is 3 seasons worth of top of the...
Forum:
06-25-2014, 03:12 PM
39
8,168
Posted By
ZDan
I'd much rather try to put 400-450hp down through...
I'd much rather try to put 400-450hp down through the stock suspension than through budget coilovers...
Forum:
Issues | Warranty | Recalls / TSB
06-25-2014, 10:53 AM
19
Car flooded suspicious of dealer
3,999
Posted By
DC2R
For anyone interested it appears water DID come...
For anyone interested it appears water DID come in where amp cable is ran. AC drain was loose and pointing at carpet but they said they did that while troubleshooting. Make sure you silicone up your...
Forum:
06-22-2014, 10:46 AM
5,031
Poll:
Engine idle chirping (cricket) noise poll.
1,375,101
Posted By
strat61caster
I've noticed a resonance at 70-80, like the wind...
I've noticed a resonance at 70-80, like the wind whistling over the mirrors but it goes away when I go faster, it doesn't get louder. So I'm not sure what you've got going on, might be the same,...
Forum:
Forced Induction
06-20-2014, 08:15 AM
22
Is this DoAble?
3,524
Posted By
SloS14
Do you like clutch really hard or something?
Forum:
06-19-2014, 11:52 PM
290
80,053
Posted By
Poodles
Keep in mind that they're not using used parts at...
Keep in mind that they're not using used parts at all, there's a lot of fluff added to that, and you're paying all the labor.
It's a hell of a lot cheaper than that to do the swap in reality, they...
Forum:
06-19-2014, 05:21 PM
290
80,053
Posted By
Malt
A fully dressed LS3 weighs 418 lbs. I don't know...
A fully dressed LS3 weighs 418 lbs. I don't know the exact weight of a FA20 but it cant be significantly less than that. Adding at most 30-40 lbs (and I'm being VERY generous here) to the front of...
Forum:
06-19-2014, 01:23 PM
156
More info on Penske shocks
51,147
Posted By
RBbugBITme
Hello, I am the designer of the BRZ shocks...
Hello,
I am the designer of the BRZ shocks and I develop all of the product pages for the website so I am as they say, the horse’s mouth. There is some misinformation here I would love to clear...
Forum:
Forced Induction
06-19-2014, 12:34 PM
59
forced air tech twin turbo frs
32,072
Posted By
fst86frs
Alright guys to chime in, this is my car. Any...
Alright guys to chime in, this is my car. Any questions feel free to ask. Radiator and fan are still in their normal spot and running a mishimoto. For the heat nothing is melting and doesnt generate...
Forum:
Forced Induction
06-19-2014, 10:15 AM
59
32,072
Posted By
Model Citizen
Of course it isn't this one has an engine in...
Of course it isn't
this one has an engine in it.
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
06-19-2014, 09:43 AM
47
Did I wait to long to get an oil change?
12,271
Posted By
Mikem53
Lots of beneficial moly is present in the factory...
Lots of beneficial moly is present in the factory oil fill from the assembly lubes used. Modern Machining processes and quality control make for a clean block to begin with. Quality OEM oil filters...
Forum:
06-19-2014, 09:35 AM
290
80,053
Posted By
malave7567
One comment, it irks me when someone refers to an...
One comment, it irks me when someone refers to an LSx engine as a huge engine just because they see the liters number... It's not very big at all. In fact, it doesn't really add much weight at all....
Forum:
Forced Induction
06-14-2014, 03:51 AM
38
New Turbo Option - Lachute Performance
9,835
Posted By
brianhj
Piqued
Piqued
Forum:
Forced Induction
06-13-2014, 03:07 PM
89
Can't decide (new to car mods) turbo or supercharge
23,823
Posted By
King Tut
fixt again.
fixt again.
Forum:
Forced Induction
06-13-2014, 09:46 AM
89
23,823
Posted By
King Tut
fixt. :laughabove:
fixt. :laughabove:
Page 1 of 6
1
2
3
4
5
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
11:56 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
