Drives: Scion FR-S 10 Series
Is this DoAble?
Let's say I choose the Jackson SC install....
Would it be possible to: not use the SC except on track days? BY:
Don't need it for daily driving... Wear & Tear.. engine life..cooler engine... ect..
In the software tuning section it looks like you can switch ROMS with the cruise control switch. The serpentine belt takes a couple of minutes at most The intake looks bothersome how about a Y coupling w a butterfly valve to choose NA or FI ? |
Drives: 2013 Black FR-S
Your engine will not be hotter while daily driving with the SC installed. It will only get hotter if you take advantage of the SC's boost.
Having oil sit in the SC and the oil lines/pump is not a good idea. The system is meant to be in circulation during heat cycles. I wouldn't do it. |
If you're not on it, it's basically not being used. Stay off the gas and then there is no need to remove anything
Drives: 2013 Whiteout FR-S
Stupidest thing I've ever heard . Just go the FI route or not. if you want a little more power at the track do full bolt ons and an E85 tune and make great power for daily driving and the track.
~@SalMPhotography~ -Instagram -Facebook -Flickr.com/SalMPhotography ![]() |
#7 | |
huh?
If it's connected by the serpentine belt it is being used, all the intake air is going thru it at all RPM's and it's hard not to drive the car without using some rpm's so ... |
A supercharger is not always creating boost. You can even give it a fair amount of gas before boost is created. Air going through it yes, but if you drive it on a normal street and keep your foot out of the gas, the car is pretty much going to drive like it did stock. You are worried about "Wear & Tear.. engine life..cooler engine... ect.." and none of that is going to be effected by a supercharger that isn't creating boost.
Off Topic
Maybe a turbo kit would work better for you? Or an electric supercharger?
#10 |
Drives: Scion FRS
Just get a upgraded rad and oil cooler if your worried about heat. Just keep it on
#11 |
Boosted Member
Drives: 2013 Subaru BRZ
OP To be honest, I think you should do a lot more research on the topic..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#12 |
Drives: 2013 DGM BRZ
Possible? -Yes. Is it really saving you anything? -No.
You're just making more components to fail, more human error to be made and you'll be essentially testing out your supercharger for the first time on the track every time. Just leave it on like a normal person, the drawbacks are very, very minimal. |
#13 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | ramiram1984 (06-16-2014) |
#14 |
Pretty sure you can daily drive a supercharger without flooring it. If you're keeping the RPM's under 3.5k and driving normally, you shouldn't be putting strain on it. The power is there if you need it, but just like any car whether N/A or FI.... if you floor it everywhere you go, you are wearing down the engine quicker.
