Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 30 of 333
Search took 0.01 seconds.
Search: Posts Made By: celek
Forum: Engine, Exhaust, Transmission 01-23-2019, 09:12 PM
Posted By celek
Just to correct your statement if I am reading it...
Just to correct your statement if I am reading it right, They are not removing the heads. You may already know this as the post was several days ago.
They are pressurizing the cylinders to hold the...
Forum: Engine, Exhaust, Transmission 09-03-2018, 08:23 PM
Posted By celek
Gaurenteed delivery we have already spent a huge...
Gaurenteed delivery we have already spent a huge chuck of money on everything to be made. Everything is ordered now we wait for the machinists. I really don’t want to discuss sales on this forum as I...
Forum: Engine, Exhaust, Transmission 08-28-2018, 12:52 PM
Posted By celek
If it is bent you will get sync loss and issues...
If it is bent you will get sync loss and issues as well. option is to by a new plate from Subaru and just put that in. or save the $30 or what ever put it together hope it is not bent so you don't...
Forum: Engine, Exhaust, Transmission 08-17-2018, 12:27 PM
Posted By celek
1300 miles now. I have 4 more prototype units...
1300 miles now.
I have 4 more prototype units scheduled for local cars for more testing.
Forum: Engine, Exhaust, Transmission 08-14-2018, 02:44 PM
Posted By celek
My plugs are at 55k miles a change is coming up...
My plugs are at 55k miles a change is coming up at 60k the recommended interval.
My car is a 2012 production year which is prone to this issue. It is the first time it reared its ugly head though.
Forum: Engine, Exhaust, Transmission 08-07-2018, 12:34 PM
Posted By celek
Came back only at High RPMs, duty cycle is dying...
Came back only at High RPMs, duty cycle is dying but if I keep it below 6000 its fine.
I did take a laser thermometer to each coil pack after a NON spirited drive home.
#1 195 degrees
#2 140...
Forum: Engine, Exhaust, Transmission 08-02-2018, 02:46 PM
Posted By celek
All in who's label is on the parts Subaru makes...
All in who's label is on the parts Subaru makes most of the parts, but Toyota makes the driveline. Although strange Subaru has been using the same TOB part number since 1990 in 476 different models
Forum: Engine, Exhaust, Transmission 08-02-2018, 11:55 AM
Posted By celek
Had a local semi celebrity drive the car over the...
Had a local semi celebrity drive the car over the weekend.
If you have been involved with Subarus for a long time and have been on forums like LERSOC(RIP)
NASIOC
RS25
You may have seen the...
Forum: Engine, Exhaust, Transmission 07-14-2018, 03:07 PM
Posted By celek
Im beating the heck out of it now trying to make...
Im beating the heck out of it now trying to make it fail purposely riding the clutch shifting more than needed randomly pumping the pedal while driving let the car idle for a few hours sit at traffic...
Forum: Engine, Exhaust, Transmission 07-12-2018, 02:18 PM
Posted By celek
This is what we are testing right now is bearing...
This is what we are testing right now is bearing life. beating it up.
Forum: Engine, Exhaust, Transmission 07-11-2018, 04:36 PM
Posted By celek
Or depending on the damage buy a new snout for...
buy a new snout for $86
The New EO TOB for $55
New Fork for $26
Change trans fluid for $40
new Exedy Clutch assembly $200
Spend 2-3 hours of time pulling the trans...
Forum: Engine, Exhaust, Transmission 07-11-2018, 01:42 PM
Posted By celek
Nothing was touched in the stock pedal besides...
Nothing was touched in the stock pedal besides removing the helper spring. Everything can still be adjusted if need be.
Forum: Engine, Exhaust, Transmission 07-11-2018, 09:36 AM
Posted By celek
The Tilton component alone is $300
Forum: Engine, Exhaust, Transmission 07-09-2018, 02:21 PM
Posted By celek
Depends If the Height of the pressure plate...
Depends If the Height of the pressure plate changes from factory height.
I have a little bit of give in the bearing to support a taller Pressure plate but if it is too tall I will have to custom one...
Forum: Engine, Exhaust, Transmission 07-09-2018, 09:40 AM
Posted By celek
entire unit is dead centered to the clutch. if...
entire unit is dead centered to the clutch. if there was any movement it can slide on the contact surface and there is movement of the piston in any direction X Y Z axis inside the seals it can shift...
Forum: Engine, Exhaust, Transmission 07-05-2018, 01:01 PM
Posted By celek
With no pressure the piston just touches the...
With no pressure the piston just touches the fingers not constant pressure the bearing is sealed and replaceable.
The entire unit is rebuildable at a fraction of original cost. Seals and base are...
Forum: Engine, Exhaust, Transmission 07-04-2018, 01:05 PM
Posted By celek
Piston is designed for over 1 million cycles. The...
Piston is designed for over 1 million cycles. The contact surface is solid steel bearing axial load surpasses force needed to depress a clutch by almost 3x. It won’t end up collapsing like factory.
Forum: Engine, Exhaust, Transmission 07-03-2018, 01:07 PM
Posted By celek
Did a thing, converted to complete hydraulic no more TOB problems ever again.
Taken me 8 months to design this and get it right.
Installed yesterday
Billet mounting plate and highly modified Tilton hydraulic release bearing.
Enjoy pics below.
Currently at 50miles of...
Forum: Engine, Exhaust, Transmission 03-19-2018, 09:23 AM
Posted By celek
I can make a 2.5 with the same rod to stroke...
I can make a 2.5 with the same rod to stroke ratio as the FA20 I have already done it at 2.3 liters capable of 9500 RPM
the limitation is in the valve train not block.
Forum: Engine, Exhaust, Transmission 03-16-2018, 01:02 PM
Posted By celek
Those are not ITBs and if the OP thinks they are...
Those are not ITBs and if the OP thinks they are they are definitely not for him to buy
Forum: Engine, Exhaust, Transmission 03-13-2018, 03:54 PM
Posted By celek
The FB25 is actually worse shorter rods crappy...
The FB25 is actually worse shorter rods crappy rod to stroke ratio and smaller thinner rod bearings
Forum: Engine, Exhaust, Transmission 03-13-2018, 10:52 AM
Posted By celek
In theory yes. I have been trying to locate a...
In theory yes. I have been trying to locate a FB25 since about 2013 to confirm fitment. I have not validated the setup yet.
Forum: Engine, Exhaust, Transmission 03-13-2018, 09:23 AM
Posted By celek
Yes same block height the F series are modular. ...
you can bolt a set of BRZ heads on a FB25 block, they have the same head bolt pattern.
Unknown at least to me is the front cover bolts and how they...
Forum: Engine, Exhaust, Transmission 02-22-2018, 04:26 PM
Posted By celek
Lots of math and calculations. You can measure...
You can measure anything and reverse engineer anything.
Forum: Engine, Exhaust, Transmission 02-22-2018, 04:04 PM
Posted By celek
LOL $17k Plus shipping from Japan + Import taxes...
LOL $17k Plus shipping from Japan + Import taxes and duties
Ill build you a 2.3 - 2.5ltr for half the cost
Forum: Engine, Exhaust, Transmission 02-14-2018, 10:38 AM
Posted By celek
I have seen first hand the 13 short block with...
I have seen first hand the 13 short block with rods and pistons hold 700+HP the casting changes to strengthen it do not really help much.
Basically I think they strengthened the FA casting for the...
Forum: Engine, Exhaust, Transmission 02-13-2018, 10:54 PM
Posted By celek
Here is the Driver intake cam differences Same...
Same diameter and base circle.
No change in lift or duration to the valves.
DI pump lobe is much smaller in height on the 2017
They may have compensated...
Forum: Engine, Exhaust, Transmission 02-13-2018, 12:54 PM
Posted By celek
Not completely tearing apart both engines just...
Not completely tearing apart both engines just compared Subaru part numbers between the 2 model years and differences are being swapped between 2014 and 2017.
There is a PDF floating around on all...
Forum: Engine, Exhaust, Transmission 02-13-2018, 12:15 PM
Posted By celek
E-Socket, External Torx size 16 the Rods use the...
E-Socket, External Torx size 16 the Rods use the same form factor, lots of companies using this now on other things as well like the exhaust studs on some vehicles.
Problem was putting a rod...
Forum: Engine, Exhaust, Transmission 02-13-2018, 10:20 AM
Posted By celek
New Things on the 2017 Engines
Figured I would post some findings.
Back story,
Customer purchased a built 2014 engine for his 2017, put all the 2017 sensors on the engine because the PIDs and programming at the ECU are...
