Old 07-28-2018, 01:13 PM   #1
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Throw out bearing comparison old vs new
Old #30502AA051, New #30502AA150.
Trueweltall is offline   Reply With Quote
The Following 3 Users Say Thank You to Trueweltall For This Useful Post:
akyp (07-29-2018), EndlessAzure (07-13-2022), Irace86.2.0 (07-29-2018)
Old 07-28-2018, 02:09 PM   #2
CoolHandMoss
Drives: 2013 FRS
I'm surprised there's not more obvious improvement. It must be more a matter material choice and internal structure. Cannot believe they're still using plastic on the inside though!
CoolHandMoss is offline   Reply With Quote
Old 07-28-2018, 02:37 PM   #3
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Maybe I'll cut both in half to see if there are differences internally... The TSB states different grease which honestly sounds like it could solve the issue since the bearing degrade. The plastic seems to only overheat once the bearing is going.
IMO, the plastic is to protect the transmission snout. Plastic (w/ a bit of grease) on an aluminum input snout *should* last longer than say, aluminum on aluminum. Granted, the plastic will wear quicker than aluminum; but I'd rather replace a $25 TOB vs. the crank snout (IIRC, they're $120ish). And we're lucky we can actually change that part! Some Subaru transmissions it is part of the casting and it cannot be replaced.
Eric
VerusEric is offline   Reply With Quote
The Following 4 Users Say Thank You to VerusEric For This Useful Post:
akyp (07-29-2018), Sportsguy83 (07-31-2018), Teseo (08-01-2018), wparsons (07-30-2018)
Old 07-28-2018, 02:44 PM   #4
CoolHandMoss
Drives: 2013 FRS
That would be impressive if the difference was just about the grease. I'm curious to see if you do cut them open. Having had a premature TOB failure on the way home from picking up my new-to-me 13 FR-S, it's a subject that has my attention.
I get your point on the plastic. I had considered that. The plastic likely will hold up fine as long as the throw out bearing does its job correctly. Still, there are plenty of cars with no plastic sleeve that have no problems being all metal and I think a correctly chosen metal would make a higher quality part. It may be that as of now the plastic sleeves have only failed due to excessive heat associated with a bearing failure, but if the updated bearings don't fail so early we may well see the sleeves failing first due to repeated heat cycles if the clutches and throw out bearings are lasting 100k or more like they do on many cars. Too soon to say though.
Old 07-28-2018, 06:55 PM   #5
Trueweltall
Where are you getting them that cheap? I paid $44 for the newer TOB.
Old 07-29-2018, 10:13 AM   #6
VerusEric
VerusEric's Avatar
If the throwout bearing lasts 100k; I'd say that is a pretty solid design. Most clutches last around 100k miles or need changed before then. The TOB should be replaced anytime the clutch is changed IMO. I'll see if I can find some time to crack open two as this has peaked my curiosity.
We sell them on our website with our clutch fork (highly recommended for this platform by the way) for $35 with the TOB clips. I have a connection at a dealership and we order in large quantity.
https://www.verus-engineering.com/pr...30-clutch-fork
I'll see what I can do about getting both cut; I need to figure out the easiest route to go.
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
Sportsguy83 (08-01-2018)
Old 07-29-2018, 10:33 AM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I replaced the snout. Mine was worn. See my build pics. It was like $83-93. Apparently it is just the temperature characteristics of the oil that was changed.
Old 07-29-2018, 12:54 PM   #8
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I mean that's not really surprising. The part still has to fit all of the other parts. They can't completely redesign it without changing more parts on the vehicle. So the solution is internal improvements and material changes, as you mentioned.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (08-01-2018)
Old 07-30-2018, 04:56 PM   #9
reeves
I just swapped mines out..
The old one from my car looked pretty identical to the new #30502AA150 part.
No real differences it seems, besides the white dot.
reeves is offline   Reply With Quote
Old 07-30-2018, 08:02 PM   #10
humfrz
If the white dot makes that much difference, why didn't they paint a white dot on the original ones ??-
humfrz
The Following 4 Users Say Thank You to humfrz For This Useful Post:
bcj (07-31-2018), chipmunk (04-26-2022), churchx (07-30-2018), wparsons (07-30-2018)
Old 07-31-2018, 10:40 AM   #11
reeves
humfrz
Well I have to pull apart my tranny again... Maybe I'll paint a white dot on the old one and re-install it, then we'll find out.
The Following 2 Users Say Thank You to reeves For This Useful Post:
andrew4554 (06-27-2020), humfrz (07-31-2018)
Old 08-01-2018, 01:13 AM   #12
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Looks different to me. The metal stamping has a bulge ring around the center near the seal vs the old one when it just slops down to the seal. That and a few other things.
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
Tcoat (08-01-2018)
Old 08-01-2018, 02:49 AM   #13
saikat.saha
Drives: Toyota Gt86 2012 orange
Hello guys,
I am not expert. Need your help guys. I bought used 2013 gt86 . Got exedy satge 1 clutch on it. Throwout bearing noise increased so much. I am confused that 1 clutch has different throwout bearing or stock throwout bearing
saikat.saha is offline   Reply With Quote
Old 08-01-2018, 03:57 AM   #14
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
How many miles were you on the original TOB before you swapped with the new one?
Spec C Wannabe is offline   Reply With Quote
Search this Thread:
Advanced Search
Throw out bearing Hyp Northern California 26 03-13-2017 11:42 PM
Post If You Have Had Your Throw-Out Bearing Go Bad! Bushhy Issues | Warranty | Recalls / TSB 8 10-24-2016 05:34 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 04:45 AM
throw out bearing clips... Shit Luck Engine, Exhaust, Transmission 0 04-12-2014 06:34 PM
