Old 02-13-2018, 09:20 AM   #1
celek
Resident Gear Head
celek's Avatar
New Things on the 2017 Engines
Figured I would post some findings.
Back story,
Customer purchased a built 2014 engine for his 2017, put all the 2017 sensors on the engine because the PIDs and programming at the ECU are different.
You can not run a 2014 ECU in the 2017 car because of the LCD dash compatibility.
Driver intake cam is a different part number for 1 so we are swapping that. Probably DI pump related but I will compare on removal.
Additionally lots of Cam position errors.
Here is why 2017 on TOP
2014 on BOTTOM
celek is offline   Reply With Quote
The Following 7 Users Say Thank You to celek For This Useful Post:
Barefootdan (02-13-2018), FunnyGopher (02-13-2018), gtengr (02-13-2018), Lonewolf (02-13-2018), Teseo (02-13-2018), Williampreza (02-13-2018), Zentec (02-13-2018)
Old 02-13-2018, 10:51 AM   #2
gtengr
Drives: 2017 BRZ
Interesting. Thanks for reporting your findings. I'm surprised that was even attempted as I'd much rather build off the newer, more rigid block.
gtengr is offline   Reply With Quote
Old 02-13-2018, 10:57 AM   #3
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Out of curiosity, what is the form factor of the exposed bolt heads?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 02-13-2018, 11:15 AM   #4
celek
Resident Gear Head
celek's Avatar
E-Socket, External Torx size 16 the Rods use the same form factor, lots of companies using this now on other things as well like the exhaust studs on some vehicles.
Problem was putting a rod through the 2017 block, not salvageable
The Following User Says Thank You to celek For This Useful Post:
Zentec (02-13-2018)
Old 02-13-2018, 11:50 AM   #5
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
this is gonna be a good thread keep up the useful info!
pgranberg11 is offline   Reply With Quote
The Following 2 Users Say Thank You to pgranberg11 For This Useful Post:
celek (02-13-2018), Zentec (02-13-2018)
Old 02-13-2018, 11:54 AM   #6
celek
Resident Gear Head
celek's Avatar
Not completely tearing apart both engines just compared Subaru part numbers between the 2 model years and differences are being swapped between 2014 and 2017.
There is a PDF floating around on all of the differences in 2017 including the reinforced block. But now I can visually see some differences
Zentec (02-13-2018)
Old 02-13-2018, 12:04 PM   #7
Teseo
Drives: frs
Would be helpful what requirements need to do for "bolt-on" swap, 2017 engine on a early model
Old 02-13-2018, 12:07 PM   #8
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I think visually seeing the differences is the most important part. sometimes the diagrams that are posted aren't even that good.
Old 02-13-2018, 03:45 PM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I assume the owner got a pre built block for cheaper than it would have cost to build the stock engine.
Old 02-13-2018, 05:04 PM   #10
gtengr
Drives: 2017 BRZ
I wouldn't say it's cheaper just yet. OP is already having to swap a camshaft over, which puts a big dent in the savings for anyone paying for labor. Hopefully it works out, and I do understand having a blown motor on a +2017 might be a bit complicated at the moment without many cores floating around.
The Following 2 Users Say Thank You to gtengr For This Useful Post:
Old 02-13-2018, 09:54 PM   #11
celek
Resident Gear Head
celek's Avatar
Here is the Driver intake cam differences
Same diameter and base circle.
No change in lift or duration to the valves.
DI pump lobe is much smaller in height on the 2017
They may have compensated in tuning or actually changed the internals of the pump bore for the shorter stroke. because it too has a different part number.
Which means 2017 Pump on 2013-16 cam may operate at a higher pressure but this is just speculation.
The Following 3 Users Say Thank You to celek For This Useful Post:
gtengr (02-13-2018), pgranberg11 (02-14-2018), Zentec (02-13-2018)
Old 02-13-2018, 10:18 PM   #12
Zentec
Drives: 2017 Toyota 86
Excellent thank you Celek! I did hear they changed something with the cams but if the lift wasn’t changed it must have been with pump and tuning.
Another thing I was thinking of is if we wanted a built engine and depending on who’s doing it are they using the 13-16 short block or the updated strengthend 17 blocks. With the differences that you have just shown here it would matter a grate deal for the project.
Zentec is offline   Reply With Quote
Old 02-13-2018, 10:38 PM   #13
StraightOuttaCanadaEh
Wes
In the updates they said the rods received some kind of coating or something to strengthen them? Do the rods look any different?
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Zentec (02-13-2018)
Old 02-14-2018, 09:35 AM   #14
celek
Resident Gear Head
celek's Avatar
I don't have access to the rods but I would not be concerned with them when aftermarket versions are available for the same price as OE.
I just have a few of these top end parts being inspected and swapped.
1 year with my 2017 BRZ - The 5 things I love justinco BRZ First-Gen (2012+) — General Topics 32 02-11-2018 10:59 AM
2017 BRZ things I hate. 1+CAN+1 CANADA 32 05-23-2017 09:50 AM
5 things I dislike about my 2017 BRZ justinco BRZ First-Gen (2012+) — General Topics 110 03-07-2017 10:12 PM
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 01:41 AM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
