Old 01-16-2019, 09:28 AM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
OEM Valve train part questions
With the recall for the valve springs I'm wondering about updating my valve train for reliability while they have the engine out and apart. I know there were some running changes to the rocker arms and likely a few other parts. I'm wondering what, if anything, I should have the dealership install and what parts can be installed without removing the heads/changing the valves.
Thanks.
Sent from my ONEPLUS A3000 using Tapatalk
Old 01-16-2019, 01:59 PM   #2
Did you look at what I gave you when you asked in the other thread?
There is nothing that can be done without removing the heads. This includes the valve spring itself.
The dealer is only going to replace the parts that are specified in the recall instructions.
Anything beyond that you are going to pay for if they will do it at all.
Very unlikely they will put 2017 parts in your 2013 engine even if you ask. They are a dealership that repairs engines not a speed shop that modifies them and will not take the liability of swapping non standard parts.
DarkPira7e (01-16-2019), humfrz (01-18-2019)
Old 01-18-2019, 07:26 PM   #3
Cesium Rainbow
Cesium Rainbow's Avatar
Drives: '13 dgm brz
I'm doing similar research right now so I don't have answers but just to echo Tcoat, what you're describing is a speed shop job as opposed to a dealer job. Which in that case would only makes sense if you're upgrading the valvetrain as opposed to swapping in other OE parts.
So I guess the answer to your question is "no."
Cesium Rainbow is offline   Reply With Quote
Old 01-18-2019, 07:38 PM   #4
humfrz
Thanks.
Well, Calum, I'm seeing it this way.
I figure that 95% of the techs that are going to do this recall work are going to do it "by the numbers".
If you try to throw something else different into the mix, there is a good chance that something will get messed up.
humfrz
Calum (01-21-2019)
Old 01-21-2019, 11:29 AM   #5
Calum
That Guy
humfrz
Well, that's why I was asking about the parts dropping in directly or not. If it's just a matter of putting in the new rocker arms with no other work then it should be fine. But yeah, they are going to have to re-shim everything which would be a pain in the ass and not at all worth it.
The Following User Says Thank You to Calum For This Useful Post:
humfrz (01-21-2019)
Old 01-21-2019, 11:31 AM   #6
Calum
That Guy
While I agree getting the dealership to reshim the valves isn't worth it, why would replacing OEM rockers with newer OEM rockers and then shimming the valve buckets be a speed shop job? Shimming the valves is just normal maintenance work. I'm not asking about have the valve seat radiused or anything.
Old 01-21-2019, 02:00 PM   #7
By putting non spec 2017 parts in a 2013 engine you are modifying it not just performing maintenance work. I simply meant that the dealership is not into modifying engines not that only a speed shop could do it.
Calum (01-22-2019)
Old 01-21-2019, 02:21 PM   #8
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I've had mine for over 8 years and i street race it and autox, no problem has arose from the valves springs so i see no point of taking mine in especially when I'm modded like full pulleys and etc. I don't feel like the dealership messing something up.
Dr. BRZ is offline   Reply With Quote
Old 01-21-2019, 05:00 PM   #9
humfrz
Well, Calum, allow me to give this another go.
As I eluded to in my previous post, I'm figuring the majority of the techs that are going to do this spring recall work are going to do it "by the numbers".
What do I mean by that? They are going to have a set of new valve springs and your car. As we used to say in the old Army - KISS (Keep It Simple Stupid). They will (by the numbers) take the engine apart, so as to get to the valve springs, replace the valve springs, then put it back together (by the numbers).
I would recommend that you NOT confuse the process.
Yes, back-in-the-day or at your grandpa's garage, what you suggest would not be out of the question.
Reminds me of a back-in-the-day story when a good friend of mine, who lived nearby, called and mentioned her husband was out of town and her front door would not lock, could I come over and fix it. Of course, I would, can't leave a poor good looking mother of three young children in an unsecured house.
I arrived with my tool box and proceeded to disassemble the very, fancy, intricate front door locking mechanism. I carefully laid all the pieces in a line on the floor in order that I took them off. OK, time for a CC&7up break. While me and her were having some refreshments, her oldest son (Mike) (a 4 year old) decided to help out by re-arranging all of the pieces on the floor by order of size.
So, after several drinks and a few hours, I finally got the lock back together and her house secured. Normally, the re-assembly would have been a 10 minute job.
Ya get ma drift??
humfrz
Calum (01-22-2019)
Old 01-23-2019, 09:12 PM   #10
celek
Resident Gear Head
celek's Avatar
Just to correct your statement if I am reading it right, They are not removing the heads. You may already know this as the post was several days ago.
They are pressurizing the cylinders to hold the valves up. Per the instructions I read and pictures of techs online.
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
Calum (01-25-2019), Tcoat (01-23-2019)
Old 01-23-2019, 09:34 PM   #11
Ya I should have specified the head covers not the heads.
Valve train woes WingHrtMan Issues | Warranty | Recalls / TSB 1 02-01-2018 01:48 PM
Jrsc intercooler and bypass valve upgrade questions Brzxton Forced Induction 4 11-28-2017 09:01 PM
Questions about Valve Stem Fitments Stayreal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2014 05:25 PM
How do you train/workout? Timmy_Jones Off-Topic Lounge [WARNING: NO POLITICS] 27 09-08-2014 08:23 PM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 10:10 PM
