Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 30 of 46
Search took 0.01 seconds.
Search: Posts Made By: vladniko86
Forum: Engine, Exhaust, Transmission 06-18-2020, 05:54 PM
Posted By vladniko86
I think the one you’re talking about goes right...
I think the one you’re talking about goes right over the starter bolt hole and the trans/starter bolt holds it down
Forum: Engine, Exhaust, Transmission 04-27-2020, 07:53 PM
It’s not. I had the same thing. Take off...
It’s not. I had the same thing. Take off everything so you can see the boot. My bet is it’s the 2 pins and that you didn’t bend the thin bent retention bracket correctly so it’s not holding the top...
Forum: Issues | Warranty | Recalls / TSB 04-11-2020, 12:24 AM
The forum was down so no one's responses showed ...
Forum: Issues | Warranty | Recalls / TSB 04-08-2020, 12:57 AM
Trust me it's nice and dandy but the salt that...
Trust me it's nice and dandy but the salt that they flood the roads with sucks
Forum: Issues | Warranty | Recalls / TSB 04-06-2020, 12:16 AM
https://uploads.tapatalk-cdn.com/20200406/da5d11da...
https://uploads.tapatalk-cdn.com/20200406/da5d11da69e87aa84beb7059ea9eb414.jpg
Forum: Issues | Warranty | Recalls / TSB 04-05-2020, 11:21 PM
Edit for all who care. Fixed it by tightening the...
Edit for all who care. Fixed it by tightening the stud that holds the plate, it's the nut right next to the one that holds the main power lead. My stud was crooked so the plate wasn't fully held...
Forum: Issues | Warranty | Recalls / TSB 03-29-2020, 12:12 AM
Sounds about right haha thanks humfrz
Forum: Issues | Warranty | Recalls / TSB 03-26-2020, 08:20 PM
Need insight on leak and TOB issues
Well I finally dropped my trans (67k miles) to figure out my squeak. It had gone away previously but came back. Anyways, few questions. Any ideas why it seems like oil is leaking from my left head?...
Forum: Engine, Exhaust, Transmission 01-20-2020, 09:45 PM
How common is it to burn a cat?
Figured I would update y'all. After looking around in a well lit garage, I found a tiny puddle near the driver side front most direct injector. Pulled intake manifold and fuel rail, and the 3rd o...
Forum: Engine, Exhaust, Transmission 01-02-2020, 10:13 PM
Yeah I should’ve written down what I measured. ...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11-27-2019, 01:41 PM
So I did my alignment today and figured out what...
So I did my alignment today and figured out what the boat feeling / oversteer was about. Had .30 and .45 toe out from my new control arms. Made them .1 toe in and it feels so much...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11-26-2019, 10:41 AM
It’s a lot better now, I used the stiff wide...
It’s a lot better now, I used the stiff wide bushings instead of the thin ones.
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11-25-2019, 11:34 PM
Finally got everything mounted. Wish it wasn't...
Finally got everything mounted. Wish it wasn't night so I could take some proper pictures. Anyways this thing feels like a boat in the rear and I think it has to do with these funky control arms I...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11-23-2019, 11:32 AM
Sweet. Car should be done Wednesday then so...
Sweet. Car should be done Wednesday then so expect some pics :)
Forum: Issues | Warranty | Recalls / TSB 11-04-2019, 08:22 PM
This right here. Had the same exact issue, had to...
This right here. Had the same exact issue, had to lube both spots decently. I just pulled the slave pin out and dipped the whole thing in lube and put it back together. As well as that location...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 09-17-2019, 08:32 PM
Yup that ain't it boss[emoji23] I'll sell em then...
Yup that ain't it boss[emoji23] I'll sell em then or trade to a wide body boy
Forum: Engine, Exhaust, Transmission 09-16-2019, 03:06 PM
No my trans squeaks when I press clutch and I'm...
No my trans squeaks when I press clutch and I'm taking it out today. I had recall done not too long ago and should've had them replace it but oh well
Forum: NY / NJ / CT / PA 09-10-2019, 11:26 AM
Heck since you're doing it on both I'll give you...
Heck since you're doing it on both I'll give you $50 on the wheels and $50 on the supercharger just to start this off.
Forum: Wheels and Tires 09-09-2019, 08:31 PM
Got em a little bit ago, thank you sir!
Forum: Scion FR-S / Toyota 86 GT86 General Forum 05-12-2019, 11:51 PM
Yeah I'll fix it later by throwing in some uel...
Yeah I'll fix it later by throwing in some uel non catted headers and a tune but that's expensive and I'd like to do it all at once. Don't have the money right now
Sent from my iPhone using...
Forum: Scion FR-S / Toyota 86 GT86 General Forum 03-30-2019, 09:30 AM
Hows your FRS/BRZ holding up?
What in the world is money shifting
Edit: nevermind I got it. Yeah that's no good haha
Forum: Scion FR-S / Toyota 86 GT86 General Forum 03-27-2019, 05:18 PM
What did you do to it? Sent from my...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 02-19-2019, 05:19 PM
Thanks man! I loved the graphite but I feel this...
Thanks man! I loved the graphite but I feel this bronze will grow on me. The spacers were conversion spacers from 5x100 to 5x112. These are 5x100 so I'll just return the spacer
Sent from my...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 02-16-2019, 01:30 PM
Here they are! 20mm spacers, 18x8 sparcos assetto...
Here they are! 20mm spacers, 18x8 sparcos assetto gara +48mm with 225/40/18 square pirelli p7 all seasons. Camber bolts up front with swapped lower bolt for about 1.5...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 02-14-2019, 07:17 PM
Same size Sent from my iPhone using...
Same size
I got 10 dorman ones for now from autozone ...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 02-14-2019, 05:48 PM
I got 56.1mm. It's very minimal play and the lug...
I got 56.1mm. It's very minimal play and the lug nuts it came with are like a cone on the side that touches the spacer so I assume once all 5 are on it will center and be good. My sparcos are...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 02-14-2019, 05:33 PM
Hey Leonardo, my hubcentric conversion spacers...
Hey Leonardo, my hubcentric conversion spacers came today and my wheels look good on em. However, how can I verify they are hub centric? There is a lip that goes on the hub, but it still moves around...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 02-11-2019, 08:34 PM
Bought 4 used pirelli p7 and my 20mm hub centric...
Bought 4 used pirelli p7 and my 20mm hub centric spacers to convert to the 5x112 pattern. Once they're all mounted up I'll post up pics. No suspension mods as of yet just camber bolts
Sent from...
Forum: Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 02-11-2019, 03:23 PM
Have a set of 48mm offset 18x8 Sparco Assetto...
Have a set of 48mm offset 18x8 Sparco Assetto Garas. Off a VW GTI so its a 5x112 bolt pattern, so I bought 4 20mm hub centric spacer/conversion from 5x100. Now I just need to decide tire size....
