Old 04-05-2020, 01:25 AM   #1
vladniko86
vladniko86's Avatar
Drives: FRS
No start after TOB swap
Sooo, today I finally got the final parts for my TOB swap. Put in new input shaft cover, new TOB and fork and got everything back in the car. Everything went smooth for the most part, expect when I tried to start it. Nothing. Nada. Sometimes rarely I will hear a click but most times I dont. I checked the voltage on the battery and it showed 12.4V so I charged it a lil bit and still nothing. Decided to run codes. Got this whole slew of codes. Cleared all and 3 permanent codes stayed. Then I put it in 2nd pos on the key and heard some super weird noise in the engine bay. Cant figure out what it is, but sounds like some weird high pitched static noise. I can hear fuel pump priming when I turn key to pos 2 and I checked my clutch pedal and the sensor that sees if its pressed down works just the same as before. Car sat for a week while I waited for parts, but honestly I have no idea what it is. I checked the two grounds, on top of trans and bolted up to starter corner where it meets tranny, and both seem fine honestly. The only thing is the signal wire to the starter seemed to be covered in dried oil, but I looked at other brz motors for sale and most were like that. I cleaned out the inside of it with MAF cleaner and a pic and did the best I could. Don't know what to do next, any recommendations would be appreciated. Thanks
- Video link to noise
vladniko86 is offline   Reply With Quote
Old 04-05-2020, 01:45 AM   #2
AT-JeffT
Drives: 14 BRZ SWP
AT-JeffT is offline   Reply With Quote
Old 04-05-2020, 01:49 AM   #3
vladniko86
vladniko86's Avatar
Drives: FRS
Old 04-05-2020, 04:54 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
EndlessAzure is online now   Reply With Quote
Old 04-05-2020, 11:21 PM   #5
vladniko86
vladniko86's Avatar
Drives: FRS
Edit for all who care. Fixed it by tightening the stud that holds the plate, it's the nut right next to the one that holds the main power lead. My stud was crooked so the plate wasn't fully held down, a tiny bit of play but after tightening it with the impact it works fine!
The Following 2 Users Say Thank You to vladniko86 For This Useful Post:
humfrz (04-06-2020), Tcoat (04-06-2020)
Old 04-06-2020, 12:15 AM   #6
humfrz
Glad you got it fixed.
What plate?
vladniko86 (04-06-2020)
Old 04-06-2020, 12:16 AM   #7
vladniko86
vladniko86's Avatar
Drives: FRS
What plate?
humfrz (04-06-2020), Opie (04-06-2020)
Old 04-07-2020, 03:51 AM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Holy corrosion Batman.
Glad you found the problem.
The Following User Says Thank You to Mr.ac For This Useful Post:
vladniko86 (04-07-2020)
Old 04-07-2020, 09:45 AM   #9
gravitylover
Meh that's nothing. Try a year round driver here in the northeast...
Old 04-07-2020, 10:56 AM   #10
Those Cali folks would freak!
gravitylover (04-07-2020), Mr.ac (04-08-2020)
Old 04-07-2020, 11:53 AM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My heart skipped a beat.
Old 04-08-2020, 12:55 AM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
I have seen snow about 3-4 times in my life time. And only for a weekend.
So...... send some, and some toilet paper...please.
Tcoat (04-08-2020)
Old 04-08-2020, 12:57 AM   #13
vladniko86
vladniko86's Avatar
Drives: FRS
Trust me it's nice and dandy but the salt that they flood the roads with sucks
The Following User Says Thank You to vladniko86 For This Useful Post:
Mr.ac (04-08-2020)
Old 04-10-2020, 11:54 PM   #14
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
is there a glitch or are people posting blank responses?
Intent > Content
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 09:36 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
DIY: how to replace battery for push start keys, and scion to toyota swap 1GiantTurtle DIY (Do-It-Yourself) Guides 2 12-27-2014 01:24 AM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
