Old 04-10-2020, 11:24 PM   #15
vladniko86
vladniko86's Avatar
Drives: FRS
Originally Posted by solidONE View Post
is there a glitch or are people posting blank responses?
The forum was down so no one's responses showed
vladniko86 is offline   Reply With Quote
The Following User Says Thank You to vladniko86 For This Useful Post:
solidONE (04-11-2020)
Old 04-11-2020, 04:54 AM   #16
alan.chalkley
Drives: 4wd zooks
Originally Posted by vladniko86 View Post
WOW, if i saw that much corrosion anywhere on my brz , my ocd would go mental with wd40 being sprayed over it every single day.
alan.chalkley is offline   Reply With Quote
The Following User Says Thank You to alan.chalkley For This Useful Post:
vladniko86 (04-11-2020)
Old 04-11-2020, 11:52 AM   #17
vladniko86
vladniko86's Avatar
Drives: FRS
I'd have to soak the whole car in a WD-40 bath if I wanted to cover the corrosion lol
Old 04-11-2020, 11:59 AM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
clearly, you don't live anywhere with salt or snow!
that is normal.
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 02:12 PM
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 08:36 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
DIY: how to replace battery for push start keys, and scion to toyota swap 1GiantTurtle DIY (Do-It-Yourself) Guides 2 12-27-2014 12:24 AM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
