follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 83
Search took
0.01
seconds.
Search:
Posts Made By:
nico_rsx
Forum:
Engine, Exhaust, Transmission
09-20-2023, 12:58 AM
5
OEM muffler heat-shield/metal sheet
2,366
Posted By
nico_rsx
Yes, it's the shield between the trunk and...
Yes, it's the shield between the trunk and muffler.
Forum:
Tracking / Autocross / HPDE / Drifting
11-28-2020, 02:50 PM
152
Oil Cooler/Reliability Mods
24,298
Posted By
nico_rsx
Similar. The sessions without the cooler were...
Similar. The sessions without the cooler were pretty hot. But I have done sessions similarly hot with the cooler. I also have not notice a statistically significant oil temperature difference with a...
Forum:
11-22-2020, 10:45 PM
152
24,298
Posted By
nico_rsx
I have the forester cooler (Ned Auto kit), with...
I have the forester cooler (Ned Auto kit), with the coolant from the throttle body.
Before I installed it I was seeing 266F max oil temp. With the cooler the max I've seen is 248F I think. So...
Forum:
Issues | Warranty | Recalls / TSB
08-13-2020, 09:43 PM
27
Steering being manipulated by something else?
2,156
Posted By
nico_rsx
Have you tried doing the pedal dance to...
Have you tried doing the pedal dance to deactivate all stability control?
The code suggest you need to do some kind of steering re calibration. You may need to go to a dealer for that (or someone...
Forum:
08-02-2020, 10:03 PM
970
SCCA Solo D Street discussion
210,531
Posted By
nico_rsx
I don't think you understand my point. Yes the...
I don't think you understand my point. Yes the suspension are moving equally, but the longitudinal movement of the suspension is transferred to a rotation movement of the sway bar by the arms of the...
Forum:
07-21-2020, 02:26 PM
12
Brake rotor damaged in shipping = still ok?
1,724
Posted By
nico_rsx
I contacted the seller, and he sent me a return...
I contacted the seller, and he sent me a return label and agreed to exchange it.
So one less thing to worry that may or may not break on the track :)
Thanks guys
Forum:
07-07-2020, 10:04 AM
13
Brake Pad Chunking from Track
3,315
Posted By
nico_rsx
From context, I'm pretty sure it's "maximum...
From context, I'm pretty sure it's "maximum operating temperature" (of the pads).
Forum:
07-05-2020, 12:48 AM
48
Tracking with ABS fuse removed?
9,404
Posted By
nico_rsx
You can do threshold braking without deactivating...
You can do threshold braking without deactivating abs. If abs is kicking in, that generally means you failed your threshold braking and the wheels were starting to lock-up.
Forum:
07-02-2020, 11:57 AM
48
9,404
Posted By
nico_rsx
Pedal dance doesn't turn ABS off. You need to...
You need to remove the fuse to turn ABS off (which also mess with electronic brake bias I think)
Forum:
12-07-2019, 04:02 PM
21
North American Track Map
3,898
Posted By
nico_rsx
Continent:America Country: Canada State(if...
Continent:America
Country: Canada
State(if applicable): Quebec
Track Name: Autodrome Montmagny
Address: 455 Chemin St Léon, Montmagny
Forum:
08-13-2019, 02:31 PM
970
210,531
Posted By
nico_rsx
If it has the same wheels as the standard...
If it has the same wheels as the standard edition, those wheels are 7.0".
If your car edition has 7.5" wheels, it should be in CS.
Edit: Also, if you have the bigger Brembo, you probably have...
Forum:
07-08-2019, 04:30 PM
3,914
Sticky:
STX Rules and Setup Questions
889,516
Posted By
nico_rsx
Before investing money, you should monitor your...
Before investing money, you should monitor your oil temperature properly. You can do that with an OBD2 dongle and torque app.
210-220 F oil temperature is not a problem at all. It's actually a...
Forum:
07-03-2019, 09:33 PM
42
Snell 2015 Helmet
8,357
Posted By
nico_rsx
From ASN canada website: ASN Canada FIA...
ASN Canada FIA (ASN) is the Sporting authority delegated by the FIA that oversees all Canadian national motorsport.
https://www.asncanada.com/about/
Time attack...
Forum:
07-03-2019, 10:25 AM
42
Snell 2015 Helmet
8,357
Posted By
nico_rsx
M rated helmet are perfectly safe for use in...
M rated helmet are perfectly safe for use in production cars without a roll cage. By dumber sanctionning bodies I guess you mean FIA, SCCA, and every major sanctionning bodies in north america,...
Forum:
05-16-2019, 09:07 PM
31
Ptunning Oil Cooler or just get the Jackson Racing
5,500
Posted By
nico_rsx
People who do autocross in street class (like...
People who do autocross in street class (like me), can't install an oil cooler because of the rules. It's a stupid rule, but it is what it is.
Forum:
02-08-2019, 03:50 PM
20
Forrester oil cooler with oil to air cooler question ?
4,001
Posted By
nico_rsx
Actually radiators don't work using convection....
Actually radiators don't work using convection. The forced air across it may make it seems like it, but it's actually a mix of radiation and conduction, not convection. To have convection the...
Forum:
01-07-2019, 11:43 PM
13
Rota titans and Teen street basis for a track day?
5,320
Posted By
nico_rsx
I'm no expert, but depending on what model of...
I'm no expert, but depending on what model of stoptech pad you got, that's more likely your weak spot than anything else.
Forum:
BRZ First-Gen (2012+) -- General Topics
01-03-2019, 03:03 PM
64
Too capable for public roads
9,671
Posted By
nico_rsx
I respectfully disagree. I have driven both...
I respectfully disagree. I have driven both (Primacy and RE71).
And while it's true that the RE71 have a lot more grip while sliding than the OEM that doesn't make them easier to control. That's...
Forum:
12-31-2018, 12:48 AM
15
a quick one-colors
2,018
Posted By
nico_rsx
http://www.ft86club.com/forums/showthread.php?p=31...
http://www.ft86club.com/forums/showthread.php?p=3167619
According to this video, at 8min, it looks red/pink.
OEM oil is probably going to be black/blackish if you have some miles on it.
Forum:
11-23-2018, 12:51 PM
90
NO LSD???????
20,401
Posted By
nico_rsx
It's hard to say, as I was not going really fast...
It's hard to say, as I was not going really fast and the ABS was kicking in because of the slippery surface. It seems there was no intervention except the ABS. But the brake pedal seemed firmer and...
Forum:
11-07-2018, 12:13 PM
41
How irritating is the tourqe dip
6,843
Posted By
nico_rsx
The problem with power (of any kind), is that you...
The problem with power (of any kind), is that you always want more.
Yes there is a dip, and I'd prefer it not to be there. But I'd also like to have 250hp, but if I had, after a couples of months,...
Forum:
11-06-2018, 03:45 PM
23
So, I found a weakness in the FR-S
4,239
Posted By
nico_rsx
The revised bearing was made somewhat recently....
The revised bearing was made somewhat recently. If you have an early production 2017 you could have the old TOB. There is a thread around with the technical bulletin saying when it was put in the new...
Forum:
10-31-2018, 11:53 AM
30
Radium surge tank
10,660
Posted By
nico_rsx
If you don't already have the Verus fuel flapper...
If you don't already have the Verus fuel flapper door, you could try it.
https://www.verus-engineering.com/product-page/fr-s-brz-gt86-wrx-fuel-starvation-door
There is a thread somewhere on this...
Forum:
10-19-2018, 01:21 PM
235
Contemplating FRS for track car
57,675
Posted By
nico_rsx
The Jackson Racing combo cooler is actually a...
The Jackson Racing combo cooler is actually a water to oil cooler, and seems to be satisfying those who have it. The part that cool the oil has no fins or aiflow and is only water cooled.
Forum:
08-27-2018, 10:21 AM
14
Full throttle for the first time
3,465
Posted By
nico_rsx
Just by curiosity, why? Is it because since the...
Is it because since the car is not properly tune yet it's bad for the engine? Or because it's easier for the tuner to read the data if you don't hit rev-limiter?
Forum:
Wheels | Tires | Spacers | Hub --
Sponsored by The Tire Rack
08-19-2018, 12:54 AM
67
Performance Package spare tire vs. regular spare
17,579
Posted By
nico_rsx
PP spare is different than non-pp. It's not a...
PP spare is different than non-pp. It's not a full size, but it's a little bigger than the non-pp.
Forum:
08-13-2018, 01:01 PM
14
Safety Equipment for Track Days?
3,159
Posted By
nico_rsx
A harness in a car with no roll bar/cage and...
A harness in a car with no roll bar/cage and stock seat, is actually less safe than the stock seat belt. If you just want it to move less in your seat, you could consider a CG-Lock, which lock the...
Forum:
07-20-2018, 10:30 AM
22
Transmission and rear differential drain plugs: Are they magnetic?
4,282
Posted By
nico_rsx
To make money? :iono:
Forum:
07-19-2018, 11:11 PM
19
possible to convert outside temp sensor to water/oil?
2,545
Posted By
nico_rsx
Haha. :D Yes there is supposed to be a...
Haha. :D Yes there is supposed to be a temperature (probably below freezing point), that the compressor won't start. Because at that temperature it probably won't have any effect on humidity, and it...
Forum:
07-18-2018, 03:03 PM
19
2,545
Posted By
nico_rsx
The HVAC probably use that temperature reading to...
The HVAC probably use that temperature reading to know if it needs to start the AC compressor when you use the windshield defrost vent.
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:02 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
