Old 11-16-2018, 05:20 AM   #1
danielmailrs
Asphalt grinder
Drives: brz
NO LSD???????
hi
today i took the car to the garage for an oil change .
at that time i had to climb on a small bumper and one rear wheel left on the air AND it was the only spining wheel and at that point i started to suspect my car has no LSD .
i lifted the car and was spiningby hands the rear wheels and instead to spin to the same direction (both sides) it was the opposite .
at first gear one wheel was forward and one backword-and on Neutral only one wheel was spining.
I thought all the BRZ's has LSDS...
HELP!
danielmailrs is offline   Reply With Quote
Old 11-16-2018, 05:33 AM   #2
86MLR
86MLR's Avatar
TORSEN lsd
As long as you have both wheels on the ground your good, lift a rear wheel at the track....not so good, it's not the end of the world, it just upsets the car a bit.
A Torsen is fairly idiot proof and very reliable though.
https://auto.howstuffworks.com/differential6.htm
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following 9 Users Say Thank You to 86MLR For This Useful Post:
CSG Mike (11-16-2018), danielmailrs (11-16-2018), RToyo86 (11-22-2018), Spuds (11-16-2018), Teseo (11-18-2018), Tokay444 (11-20-2018), Ultramaroon (11-17-2018), whataboutbob (11-17-2018), wparsons (11-17-2018)
Old 11-16-2018, 05:39 AM   #3
danielmailrs
Asphalt grinder
Drives: brz
Originally Posted by 86MLR View Post
TORSEN lsd
thanks
ew then that torsen isnt that goodie like "Real"Lsd .
everytime ive put an lsd into my cars it was the opposite from what ive exped today.
interesting if both on them on the ground is exactly like normal LSD or its just feeling like a compromise to the real thing.
Old 11-16-2018, 05:55 AM   #4
danielmailrs
Asphalt grinder
Drives: brz
TORSEN lsd
great arcticle dude
according to his paragraph:
However, if one set of wheels loses traction completely, the Torsen differential will be unable to supply any torque to the other set of wheels. The bias ratio determines how much torque can be transferred, and five times zero is zero.
its explain why the car didnt push over on that bumper i had to climb.
and also the reason why one wheel spin to one direction and the other to the other direction -like an open diff.
cheers!
also found a nice video that explains well that issue -
[ame]https://www.youtube.com/watch?v=3Pw2fKt_0As[/ame]
if anyones is interested
Old 11-16-2018, 05:56 AM   #5
86MLR
86MLR's Avatar
For the street they are great, plus, no real maintenance is required.
For the track they can be a compromise, only on full slicks though I found, you can negate the cons with your set up, but if your at the pointy end you may want something else, maybe...
If your not at the pointy end, the TORSEN is fine.
I ran the TORSEN in my old MX5 club car for years without any real issues that couldn't be fixed by set up or driving style.
I have no intention of swapping the TORSEN in my 86.
The Following 3 Users Say Thank You to 86MLR For This Useful Post:
danielmailrs (11-16-2018), Ultramaroon (11-17-2018), wparsons (11-17-2018)
Old 11-16-2018, 06:24 AM   #6
JIM THEO
Drives: BRZ 2018
Torsen=torque sensing, it multiplies the torque of the spinning wheel with a number depending of gearing inside, say 2-3, and sends it to the other wheel, if it has zero torque on the air the other wheel will take zero too!
On the air try to spin with your hands the one rear wheel, if the other wheel spins the opposite direction it's a good sign for torsen differential
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
Old 11-16-2018, 07:02 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Yeah, if one wheel completely looses traction, with torsen diff it may act as open diff. It can be countered with nannies applying brakes to wheel with no traction, and while clutch type diffs work better ensuring traction no matter what, torsen is better then nothing/open diff, and compared to clutch LSDs it's simpler to maintain/last longer/operates quieter. These bits matter more to cars that are mostly daily driven.
As to twins w/o torsen LSD in stock trim .. IIRC there was some very-very powerty spec 86 in JDM, that was meant for modders, that will replace stock parts anyway. Unpainted bumpers, steelies as wheels, open diff. Most twins in other DMs in both top and lesser trims have these torsen LSDs, differing only with seat trim/seat heating/dash(w. digital speedo or not)/smart key/foglights/HID lights/dualzone AC.
The Following 2 Users Say Thank You to churchx For This Useful Post:
danielmailrs (11-16-2018), Spuds (11-16-2018)
Old 11-16-2018, 08:21 PM   #8
GrabTheWheel
Drives: 16' BRZ
If you like grip or drift a clutch type diff is a great mod and a serious upgrade over the stock torsen diff.
GrabTheWheel is offline   Reply With Quote
The Following User Says Thank You to GrabTheWheel For This Useful Post:
danielmailrs (11-18-2018)
Old 11-16-2018, 09:25 PM   #9
Originally Posted by danielmailrs View Post
thanks
The torsen is very much a "real" lsd, but situationally. It's also why the car has an e-diff function, the try to make the torsen function under any circumstance.
If you want to get a "real" lsd, PM me and we can get you a ATS/Cusco/Drexler/Kaaz/OSGiken/Tomei
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
danielmailrs (11-17-2018), whataboutbob (11-17-2018), wparsons (11-17-2018)
Old 11-17-2018, 02:15 AM   #10
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
If you ever find yourself needing traction because one wheel is up in the air or spinning on ice, pull up the e-brake and then hit the gas until they both spin.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Old 11-17-2018, 11:42 AM   #11
danielmailrs
Asphalt grinder
Drives: brz
Cheers mate
Whats e diff? Electronic? Didnt know our cars has any electronic function for the diff .
Maybe that vsc sport mode? Dunno lol
Whats that e brake?handbrake?
Sent from my SM-G960F using Tapatalk
Old 11-17-2018, 11:52 AM   #12
wparsons
wparsons's Avatar
Cheers mate
"e-diff" is the sames as a vlsd (virtual lsd), it's the ECU applying brakes to one wheel to stop the diff from unloading. If you manage to get a wheel in the air on these cars, the ecu will apply brakes to that wheel to let the LSD send power to the one still on the ground.
Yes, handbrake.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
86MLR (11-17-2018), CSG Mike (11-19-2018), danielmailrs (11-17-2018)
Old 11-17-2018, 12:04 PM   #13
danielmailrs
Asphalt grinder
Drives: brz
Yes, handbrake.
Which button turn that e diff on?
Old 11-17-2018, 12:52 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
You mean, which button turns it off? Far as I know, only pedal dance. Possibly 3 second press, I'm too lazy to search that one for you.
I don't think it's going to give you rock crawler capabilities, regardless...
The Following 3 Users Say Thank You to cjd For This Useful Post:
CSG Mike (11-19-2018), danielmailrs (11-17-2018), Ultramaroon (11-17-2018)
