Old 07-17-2018, 05:26 PM   #1
max20s14
Drives: 14' Raven M/T - 02' is300
possible to convert outside temp sensor to water/oil?
is it possible to convert outside temp sensor to water/oil?
Ive heard of this being done on other cars before.
max20s14 is offline   Reply With Quote
Old 07-17-2018, 05:54 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Just get a Bluetooth dongle and the torque app.
MS, CSCS, TSAC-F, CPT
Old 07-17-2018, 09:06 PM   #3
toyubie
Drives: none
I don't see why not. The sensor is mounted in front of the A/C condenser, if you found a voltage compatible sensor for water or oil you could definitely wire it in. AFAIK nobody has done this on our car yet.
toyubie is offline   Reply With Quote
Old 07-17-2018, 09:13 PM   #4
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
What's the range on the readout for the outside temp gauge? If it doesn't read above 200º (unless you're working in ºC!) it wouldn't be of any use. Also, is the OT sensor used by the engine management system? (I don't know the answer, just brainstorming..)
Williampreza is offline   Reply With Quote
Old 07-17-2018, 11:19 PM   #5
max20s14
not sure. I guess we could try putting a heat gun to it to see if it goes over 200
Old 07-18-2018, 11:59 AM   #6
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
That shouldn't matter if you're using Torque. As long as you replace it with a sensor that has the same voltage output (assuming it's an analog output) you can put in a custom PID that converts the reading to the sensor's range. The dash wouldn't read the correct temperature then, though, only the app with the custom PID.
As far as if the engine management system uses it, that could be a problem but I highly doubt that it does. It should only care about intake temperature, not outside temperature.
Horrid_Funk is offline   Reply With Quote
The Following User Says Thank You to Horrid_Funk For This Useful Post:
Williampreza (07-18-2018)
Old 07-18-2018, 02:12 PM   #7
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Interesting idea. Would definitely make for a stealthy, oem looking temp monitor. An OBD BT dongle + Torque works too but has its own issues like always having to wait for pairing, bad pairing, battery drain depending on BT adapter, etc. Enough issues wasting my time and with the frequency of me using torque just for temp read outs that I switched to manual gauges. OP I hope you try this temp sensor conversion and I hope it works.
Pointmutation is offline   Reply With Quote
Old 07-18-2018, 03:01 PM   #8
I have no clue if it does anything other than display the temperature on the dash but I would want to make bloody sure it isn't sending a signal to any other system in the car before messing with it.
May be fine on a manual HVAC control but I do know that it plays a part in the automatic HVAC systems.
Old 07-18-2018, 03:03 PM   #9
nico_rsx
Drives: BRZ 2017 Pure Red, MT
The HVAC probably use that temperature reading to know if it needs to start the AC compressor when you use the windshield defrost vent.
nico_rsx is offline   Reply With Quote
The Following 2 Users Say Thank You to nico_rsx For This Useful Post:
Horrid_Funk (07-18-2018), Tcoat (07-18-2018)
Old 07-18-2018, 04:05 PM   #10
Good call!
nico_rsx (07-19-2018)
Old 07-18-2018, 06:14 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
How about that!
https://demos.starbase7.net/t3Portal...02LJ403UX.html
Old 07-18-2018, 07:08 PM   #12
Was too lazy to look it up. Would appear that it would probably not work with just any sensor anyway.
Old 07-18-2018, 10:28 PM   #13
Ultramaroon
not playing cards
I first posted to correct Nico's guess about the defrost mode because the AC kicks in to dehumidify no matter what the temp. Then I did a panic delete when I checked myself.
Was relieved when I saw that you were offline.
Old 07-18-2018, 11:45 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
How about this project to use display place where clock is to show oil/coolant/intake temps, voltage, a/f ratio?
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
Water temp. Reaper Engine, Exhaust, Transmission 7 08-28-2014 10:20 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
