Old 12-31-2018, 12:26 AM   #1
Legend@wheels
nenber
a quick one-colors
hi
is the mt90 redline 75w90 trans oil is the same color as the OE one?(still under warranty so..)
if not,whats the oe's oil color?
Legend@wheels is offline   Reply With Quote
Old 12-31-2018, 12:48 AM   #2
nico_rsx
Drives: BRZ 2017 Pure Red, MT
http://www.ft86club.com/forums/showthread.php?p=3167619
According to this video, at 8min, it looks red/pink.
OEM oil is probably going to be black/blackish if you have some miles on it.
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
Legend@wheels (12-31-2018)
Old 12-31-2018, 02:18 AM   #3
Legend@wheels
nenber
probably but obviously i meant when its new and not burnt
still havent picked the one to go with(tried 300 and its shitty) so i might be more interested to know what color is the OE one.
Old 01-01-2019, 02:56 PM   #4
Legend@wheels
nenber
is anyone know the OE gearbox oil color?
Old 01-01-2019, 04:02 PM   #5
Hi ya, Legend@wheels.
I don't know what the color of the OEM transmission oil is.
However, I'm curious as to why you want to know??
What difference does it make?
JohnJuan (01-02-2019)
Old 01-01-2019, 04:14 PM   #6
Brink
Drives: 2017 BRZ
The bit about warranty suggests OP wants oil that can pass for OEM in a visual inspection in case of any warranty work that might arise in the future.
Brink is offline   Reply With Quote
The Following 2 Users Say Thank You to Brink For This Useful Post:
humfrz (01-01-2019), Legend@wheels (01-01-2019)
Old 01-01-2019, 05:28 PM   #7
Hmmm...….OK, you are probably right.
Question for the OP @Legend@wheels as long as the oil that was put in the transmission meets the specifications in the manual, would it make a difference, when it comes to warranty work in Israel?
I'm just wondering if you're worrying over something that doesn't need to be worried about?
Old 01-01-2019, 11:34 PM   #8
Legend@wheels
nenber
Exactly. @humfrz
Sent from my SM-G960F using Tapatalk
The Following User Says Thank You to Legend@wheels For This Useful Post:
humfrz (01-02-2019)
Old 01-01-2019, 11:36 PM   #9
Legend@wheels
nenber
Uhmm hard to say for sure.
If its 100% fits so it might be more easier .
But i dont think that the oils we put does that.
(Mt90,mt85,pentosin,motul300 and so on)
P.s
If i was thinking what we put is bad i wasnt doing that in the first place/or the oil ive put caused that then i wouldnt go dealer at all since its my fault.
But in this case those boxes came out from the dealer as a rubbish boxes.
humfrz (01-02-2019)
Old 01-02-2019, 12:53 PM   #10
wparsons
wparsons's Avatar
If the fluid is compatible, it doesn't matter if it's OEM or not...
flickr
venturaII (01-02-2019)
Old 01-02-2019, 01:28 PM   #11
Legend@wheels
nenber
Not enough for the dealer.
Anyway i just want to know its color thats it.
If anyone got his previous oil out and it was new car so its the still the same color so its a good indication
Old 01-02-2019, 02:25 PM   #12
86TOYO2k17
Drives: 2017 toyota 86
Can you not replace with oem factory fluid? and or call the dealer and ask what would be deemed acceptable to not have warranty issues?
If it’s the same “spec” it should not matter assuming the proper filling protocol was met and that replacing it wasn’t the specific issues “filling too much, too little, forgetting to put drain and or fill plug back on etc...”
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
wparsons (01-03-2019)
Old 01-02-2019, 02:30 PM   #13
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
The dealership cannot reject the factory warranty simply because you purchased a compatible fluid elsewhere. As long as it's the correct weight and grade, you have met the factory defined requirements. Use a different dealer if they try pulling that stunt, or get Toyota involved directly.
And to answer your question, OEM is amber in color. I've been using Toyota LV 75W transmission lube for changes at Toyota's suggestion (also amber). It ain't cheap though... I recently changed to Amsoil 75W-90 GL-4 because it's half the price of the Toyota stuff, and I have to say I'm not impressed. I might switch to Redline MTL 75W80 GL-4.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Legend@wheels (01-02-2019), wparsons (01-03-2019)
Old 01-02-2019, 02:45 PM   #14
Legend@wheels
nenber
Tnx
Then its yellowish like the 300.
Always thought its red.
FS: NRG Quick Release 3.0, Quick Lock, Steering Wheel akiranakayama Interior Parts (Incl. Lighting) 13 08-16-2016 10:40 AM
FS: New NRG Quick Tilt & As-Is NRG Quick Release bear89103 Interior Parts (Incl. Lighting) 2 10-16-2014 01:11 AM
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 05:59 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
FRS colors = Prius colors? lemonspeakers Scion FR-S / Toyota 86 GT86 General Forum 21 04-11-2013 12:14 AM
