Old 10-31-2018, 03:50 AM   #1
GrabTheWheel
Drives: 16' BRZ
Radium surge tank
Who has a surge tank setup? What has your experience been? I'd like better fuel filtration and to be able to track with less than half a tank.
GrabTheWheel is offline   Reply With Quote
Old 10-31-2018, 05:06 AM   #2
Are you ready to wear a fire suit every time you're in the car? Are you boosted? Ethanol?
A stock car on NA power with gasoline can run quite low.
Old 10-31-2018, 11:53 AM   #3
nico_rsx
Drives: BRZ 2017 Pure Red, MT
If you don't already have the Verus fuel flapper door, you could try it.
https://www.verus-engineering.com/pr...tarvation-door
There is a thread somewhere on this forum about it.
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
DarkPira7e (10-31-2018)
Old 10-31-2018, 12:58 PM   #4
GrabTheWheel
Drives: 16' BRZ
Car is far from stock it will have an LS3 crate motor running on MoTeC. I’m walking a fine line between street and track car for now. Eventually if California doesn’t want to let me drive it anymore it will be caged and towed to and from the track. You really think I can’t drive it without a fire suit? I’ve found the stock fuel filter to be inadequate so aside from being able to run hard down to empty I’d like some more peace of mind when it comes to the fuel being filtered.
Old 10-31-2018, 01:00 PM   #5
GrabTheWheel
Drives: 16' BRZ
I’ve heard very mixed reviews on the fuel flapper.
Old 10-31-2018, 02:47 PM   #6
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
I still fuel starve towards the end of a session with the velox fuel flap door installed if I go out with less than 2/3 tank
It's not a cure-all.
Joesurf79 is offline   Reply With Quote
Old 10-31-2018, 03:06 PM   #7
GrabTheWheel
Drives: 16' BRZ
That’s what I’ve heard. Thanks for your input. I’ll probably be going through half a tank in a 20 min session. So it sounds like a surge tank would almost be mandatory.
Old 10-31-2018, 03:46 PM   #8
Joesurf79
Joesurf79's Avatar
yep. I go through a little more than a 1/4 tank per session. If I go out with a half tank or a hair more, I'll starve before the session is over.
Old 10-31-2018, 10:18 PM   #9
nico_rsx
Well I think it works on NA+tune, but if you're swapping the engine for something that will use that much fuel, then no the flapper isn't going to be enough.
Old 11-01-2018, 02:54 AM   #10
I would highly caution you against driving without a fire suit once you have a surge tank in the car. Aftermarket surge tanks are not built to OEM standards for resistance to the elements and even use. Even with race level maintenance, every race car driver will have a fire suit on, because the risk of fire is high enough to mandate it. When being driven hard, even the smallest failure in the system can lead to a catastrophic fire.
To put it in perspective, I would consider a fire suit to be higher priority over a HANS type device, or even air bags, with a surge tank. Imagine if someone hit you on the road, and a link just barely got kinked and springs a small drip. Things involving fuel and a lot of hot surfaces (and a car has a LOT of those), can get ugly very quickly.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
byun (02-26-2019), CatDaddysBBQ (11-06-2018), ka-t_240 (02-27-2019), norcalpb (04-22-2021), Tristor (02-27-2019)
Old 11-01-2018, 03:59 AM   #11
GrabTheWheel
Drives: 16' BRZ
What about Radium's fuel pump hanger? Anyone have this?
Old 11-01-2018, 04:06 AM   #12
GrabTheWheel
Drives: 16' BRZ
Ok Mike, you've convinced me. Now can I drive without any starvation at least to a half tank with their fuel pump hanger? Being able to convert the oem returnless system to a traditional return system seems like it would be beneficial. It would also address the filtration issue.
Old 11-01-2018, 04:49 AM   #13
Turbo
Drives: FR-S Turbo
Really? I haven't seen anything like this.
Turbo is offline   Reply With Quote
Old 11-01-2018, 04:52 AM   #14
Turbo
Drives: FR-S Turbo
You sure it's installed correctly? No problems with your fuel pump?
I'm boosted and can practically run down to vapours without issue. I see close to 2G's cornering and consistently hit 1.4G's braking on the track.
DIY : Draining the gas tank - Methods to empty fuel tank Mermoz DIY (Do-It-Yourself) Guides 13 10-09-2025 02:56 PM
JUN GT SURGE TANK FOR FT86/BRZ scubie.brz Engine, Exhaust, Transmission 60 11-23-2020 07:48 PM
Radium Engineering developing dual in-tank pump hanger slicktop Forced Induction 18 06-13-2017 02:42 AM
SARD Surge Tank Kit w/ ITB from TAS 2017 mav1178 Engine, Exhaust, Transmission 50 05-12-2017 10:50 PM
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion Xero-Limit Engine, Exhaust, Transmission 42 04-27-2017 09:16 PM
