Old 01-11-2016, 01:12 AM   #1
azynneo
Best two way dash cam that uses car battery and it's own battery?
I was wondering if anyone knows a good 360 dash cam that holds a battery charge and while the car is on uses the car battery instead (or charges the battery so it doesn't run out)
azynneo is offline   Reply With Quote
Old 01-11-2016, 01:30 AM   #2
ryoma
ryoma's Avatar
your best bet will be to go with a blackvue 2 channel (2 camera; 1 front, 1 rear) with a power magic pro. the power magic pro taps into your car battery once the car engine is off and once it measures that your car battery is at a certain voltage, it cuts off power to the camera so that your car can still start up when you want to turn it on. it gets pricey though
http://www.blackvue.com/dr650gw-2ch/
Old 01-11-2016, 01:32 AM   #3
azynneo
I was looking at that as well and it seemed very intriguing, but when i saw a few "failed within months" reviews on amazon that kinda led me off. Kinda wish there was a perfect product I wouldn't mind paying a bit of cash to have my car security .
Old 01-11-2016, 01:38 AM   #4
ryoma
ryoma's Avatar
as with any product, there will always be a few bad apples in the batch. I personally haven't used the Blackvue so I cannot attest to the quality, but I know a few people who have used one for a long time without any problems. though, they only have the single channel and not the 2 channel version. I personally use a mini 0806 that have also a few people who claim that it has many problems, but mine works fine. as long as you buy from a reputable vendor, I believe that they will do their best to fix any problems you might have.
Old 01-11-2016, 01:43 AM   #5
azynneo
guess I'll probably do just that, thanks man
Old 01-11-2016, 10:33 AM   #6
Chimera
Drives: FRS
problem with on board battery solutions is charge capacity and safety. most normal lightweight batteries don't hold up to car levels of heat well. the interior of your car can get quiet hot if sitting in the sun, and if the dash cam is in direct sunlight, then its worse.
that's why many use the car battery solution.
I have seen options before using a large capacitor in line with the camera, similar to how larger audio systems use.
a 1/2F should be more than enough if you are wanting to keep it running full time over several days and not worry about battery discharge, and should be easy to get from any auto audio retailer.
Old 01-12-2016, 09:34 AM   #7
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
like ryoma suggested, get powerpmagic pro. mine is 3 years and still works great.
or you can get
http://www.ebay.com/itm/New-LUKAS-LK...0AAOSwEK9UHW7l
this is small battery that works using cigarjack which is you dont have to tap or use add-on fuse.
Old 01-12-2016, 11:20 AM   #8
Stratoside
Stratoside's Avatar
Drives: Firestorm red MT FR-S 2013
blackvue is not that good
I bought 2 blackvue DR500GW-HD(1 for front and 1 for back) and one of them stopped working after a year and wi-fi for the second one stopped working.
they have no warranty service what so ever, they told me to talk to the vendor that sold me the unit
Stratoside is offline   Reply With Quote
Old 01-14-2016, 01:16 PM   #9
joop1987
Drives: 2013 FRS, Raven, Auto
You would probably be happy with Blackvue's Power Magic Pro. I suggest you use a camera with a capacitor though. The lipo's the the cameras always puff up from the sun and stop working. I'm using a Mobius with supercapacitor option but there are other that work just as good.
joop1987 is offline   Reply With Quote
Old 01-14-2016, 05:09 PM   #10
ARTBRZ
Aloha!
ARTBRZ's Avatar
I also have the mobius. Can you provide a link to the wires that you used to hard wire to the car battery?
ARTBRZ is offline   Reply With Quote
Old 01-14-2016, 05:19 PM   #11
DAEMANO
Time Traveller
Never used it before so YMMV, but Blackbox Guard Pro 2 seems to fit your requirements and is highly regarded (and is also kinda pricey, but maybe it's worth it).
http://blackboxguard.com/shop/shop/pro2/
Old 01-20-2016, 05:46 AM   #12
azynneo
oh god that's mighty expensive. and should've just bought one.. fucking got side swiped earlier at school today and no note left =/.. man I hate people
Old 01-20-2016, 06:29 AM   #13
azynneo
also no reviews on the blackbox
Old 01-20-2016, 06:39 AM   #14
azynneo
when you hardwired your mobius to your headliner, do you ever have to remove it? to let it rest?
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 08:55 AM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 10:05 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
