Old 12-30-2015, 01:44 PM   #1
Ben_G
Drives: Blue BRZ
Rays valve stems on RPF1
Hey, does anyone know if these valve stems would fit on a set of RPF1? I would assume that it's all standard size, but just wanted to be sure.....
http://www.evasivemotorsports.com/mm...t_Code=RAYS-VS
Ben_G is offline   Reply With Quote
Old 12-30-2015, 02:11 PM   #2
MrDinkleman
Drives: 2016 Oceanic, "base" model
Although most manufacturers seem to have standardized on one size, there are some that are smaller and larger. You should measure yours and compare to a Volk wheel before ordering.
MrDinkleman is offline   Reply With Quote
Old 12-30-2015, 03:00 PM   #3
Ben_G
Drives: Blue BRZ
Thanks. that would have been my next step, but was hoping that someone would have tried this before. I can't be the only one who wants to have the locking nuts on the outside, just in case??
Old 12-30-2015, 03:33 PM   #4
ryoma
ryoma's Avatar
do you want the TPMS light to come on all the time? the TPMS for our car has the valve stem included and you can't switch it out unless you don't install it at all.
The Following User Says Thank You to ryoma For This Useful Post:
gdrider77 (12-31-2015)
Old 12-30-2015, 07:48 PM   #5
Ben_G
Drives: Blue BRZ
BRZ in Canada does not have TPMS...
Old 12-30-2015, 08:19 PM   #6
MrDinkleman
Luckieeeeee...
Old 12-30-2015, 09:27 PM   #7
ryoma
ryoma's Avatar
oh that's awesome then lol
Old 12-31-2015, 02:41 AM   #8
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Shoot, didnt realize that, so i guess i will not use mine...i will have some for sale in about a week or so, give you a good deal.
gdrider77 is offline   Reply With Quote
Old 12-31-2015, 09:04 AM   #9
Ben_G
Drives: Blue BRZ
Luckieeeeee...
Yes.... FRS here has TPMS, but not Subaru....
Let me know! Not sure if shipping and exchange rate will kill it, but might be good to find out if something like this might make it work for you to use non-TPMS valves ...
http://www.clublexus.com/forums/is-2...pipe-bomb.html
http://www.hardworkingtrucks.com/tpms-sensor-canister/
The Following User Says Thank You to Ben_G For This Useful Post:
gdrider77 (01-04-2016)
Can't install Valve Stems? iNcontroL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-15-2015 11:22 PM
RPF1 OEM Valve Stem Question pf330ci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-22-2014 09:18 PM
Enkei Valve Stems Squishy86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-26-2014 05:26 PM
New WORK RS-R forged aluminum lug nuts and valve stems - anodized red dminner Wheels and Tires 0 08-10-2014 12:41 PM
WTB: Blue Enkei Valve Stems Squishy86 Want-To-Buy Requests 0 06-04-2014 11:34 PM
