Old 06-05-2014, 02:39 PM   #1
Squishy86
Squishy86's Avatar
Drives: Your Car
Enkei Valve Stems
So I've noticed that Enkei has different part numbers for valve stems for different wheels. For example, I see NT03s use valve stem V365 while rpf1s use valve stem A379. I'm guessing these aren't interchangable? I'm looking for blue valve stems for my nt03s but now just realized that they might be different from the blue rpf1 valve stems I keep finding.
RPF1 Valve stems
NT03 Valve stems
Squishy86 is offline   Reply With Quote
Old 06-05-2014, 07:20 PM   #2
mfbmike
Drives: 2013 FRS, 2008 R32
My NT03's (currently for sale) used the bottom valve stem in your original post.
Actually, 2 of them per wheel.
mfbmike is offline   Reply With Quote
Old 06-05-2014, 07:44 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If the valve stem opening on the wheel & stem seat is the same, you can interchange valve stems.
Having said that, the bottom pic (NT03) seems to be upside down on the rubber seal on the outside.
The only way to know if it'll work is to compare the rubber seal of the RPF1 valve stem vs NT03 valve stem, and see if the shape is identical or not.
-alex
Old 09-26-2014, 03:59 AM   #4
Stayreal
Drives: 13' Scion FR-S
-alex
Does these Valve Stems work with stock TPMS ?
Stayreal is offline   Reply With Quote
Old 09-26-2014, 09:49 AM   #5
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
They should both work, no need to have 2 seals, but some stems do. They're all just cheap $1 stems and varying lengths, so while they may all bolt on just fine, there may not be enough clearance at the valve stem hole area to fit the air nozzle.
As for TPMS, no, those use special stems.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
The Following User Says Thank You to aznatama For This Useful Post:
Stayreal (09-26-2014)
Old 09-26-2014, 11:18 AM   #6
wparsons
wparsons's Avatar
Nope. The TPMS has a built in valve stem, so you can't run a different one.
The stock TPMS work no problem with RPF1's though (my stock sensors are in my RPF1's).
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 09-26-2014, 05:26 PM   #7
Stayreal
Thanks for the reply man, appreciated it
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 06:38 PM
FS:PA Enkei Evo 5 17x7 et42 225/45/17 BFG Rivals auto x setup SterlingBrz Wheels and Tires 17 09-02-2014 09:10 AM
WTB: Blue Enkei Valve Stems Squishy86 Want-To-Buy Requests 0 06-04-2014 11:34 PM
PA:WTB/FT black enkei raijin 18x8.5 18x9.5 for enkei rpf1 17x9 SterlingBrz Wheels and Tires 1 05-28-2014 11:36 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
