Drives: 2013 GBS BRZ Limited
Recommended Alignment Settings?
I'm going to be installing a set of Tein Flex Z's and SPC LCA's tomorrow, looking to lower the car 1"-1.5". Is there a range of camber/caster/toe settings that is generally recommended for a DD with occasional spirited driving? Or is the stock alignment fine? I would like to have an idea of the settings I need before I set the appointment for the alignment.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
Front: -1.5 degrees / 0 toe (a little out if you want)
Rear: -1 to -1.5 degrees / 0 toe (a little in if you want) |
#3 | |
Because compromise ®
Drives: Red Herring
@BFIFE22 Have a read of this thread: http://www.ft86club.com/forums/showt...nment+settings Alignment, like a lot of other things, is a compromise. I'm on 6k/6k springs, the same as Tein Flex Z for the triplets, and I'm running -3.2/-2.7 camber. It depends on what you're trying to achieve. I am not suggesting you go with -3.2/-2.7 camber; I'm just saying it depends. Having 0 toe at the rear makes the rear less stable. That is, more prone to wander but it also makes the car easier to induce over-steer. I have settled on 0.3mm toe-in/side but it took 2 alignments to arrive at this figure.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Ultramaroon (12-27-2015) |
#4 | |
Drives: 2013 Raven FR-S
Not a troll
#6 | |
Drives: Red Herring
The OP mentions "occasional spirited driving" so there probably isn't too much need to take tires into account. As I have tried to emphasize there is no one right answer.
| The Following 2 Users Say Thank You to Captain Snooze For This Useful Post: | Cole (12-27-2015), Ultramaroon (12-27-2015) |
#7 | |
A little toe in in the front makes the car more stable in a straight line, toe out will make the car slightly less stable in a straight line but will have quicker turn in. |
| Alignment settings for Auto club speedway | ddeflyer | Tracking / Autocross / HPDE / Drifting | 12 | 07-08-2015 08:10 PM |
| DIY alignment - quick way to set alignment while new suspension settles? | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-11-2014 09:53 PM |
| Recommended Toe Alignment Settings | brillo | Tracking / Autocross / HPDE / Drifting | 18 | 02-05-2014 11:36 AM |
| recommended alignment shops in Az (tempe/chandler/mesa preferred) | Juggles | Southwest | 1 | 11-19-2013 03:33 PM |
| RCE yellow springs. Expected alignment settings after install. | diss7 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 02-24-2013 02:48 PM |
