Old 02-03-2014, 09:51 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Recommended Toe Alignment Settings
When getting my car aligned (weekend driver / occational track toy), the shop recommended a hint of toe both front and rear given my type of driving.
my Toe after alignment was ~ +.1 both front and rear.
Just curious what folks run as far as toe given there is so much discussion of camber settings.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 02-03-2014, 10:28 AM   #2
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I put as much negative camber as I could get on the fronts with just camber bolts.
Mine ended up at:
-1.0 in the front on each side. Zero toe
-2.5 in the rear and .15 toe in
Ranatsu is offline   Reply With Quote
Old 02-03-2014, 05:49 PM   #3
icemang17
Drives: Scion FR-S/ Subaru BRZ
it all depends on how often you run on track + the wheels-tires you run....another HUGE factor is how long you want the tires to last off track?
I found the factory settings "okay" running a pure stock car.....the brakes are MUCH worse than the handling in stock form
Tire pressure and alignment settings will help you tailor the handling feel more to your liking and typically increase tire life on track....for example I run max camber all around on my racer (above 3') with a touch of toe in out back and a touch of toe out up front....I like my cars to be a bit loose, which I define as always being able to tighten up the car mid corner if I need too...I hate understeer-push cars...since once you hit that limit mid corner its quite difficult to correct from a drivers point of view...all you can do is slow down until grip comes back
icemang17 is offline   Reply With Quote
Old 02-03-2014, 05:58 PM   #4
0 toe all around for this car.
Old 02-03-2014, 05:59 PM   #5
Static friction > kinetic friction. Reduce input, and slowly increase to regain traction and then get to a higher turning speed.
Old 02-03-2014, 06:06 PM   #6
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Doesn't it depend on application? My understanding is that Autocross guys run some toe out in the front and toe-in in the rear. From the looks of his signature he's more of a track guy, but it would be unfortunate for autocross guys to come across this thread and not realize it isn't really absolute.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
jdcorbitt3 (02-03-2014)
Old 02-03-2014, 06:23 PM   #7
Unless you have a dedicated autox setup, you don't want an autox alignment... and I'm 99% sure the guys with dedicated autox equipment will already know how they want their cars aligned. Anyone asking will generally be best off with 0 all around for this platform.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
raul (02-03-2014), smbstyle (02-03-2014), sosick (02-04-2014)
Old 02-03-2014, 06:24 PM   #8
raul
Lap time enthusiast
raul's Avatar
Fair enough Mike.
Old 02-03-2014, 08:48 PM   #9
itzmik3
DBC Racing
itzmik3's Avatar
we will be running the same set up for this year. 225 w/ the 1/16 total toe in worked great, but with the 245 set up this year we are looking for a bit more of rotation.
#194 SM
itzmik3 is offline   Reply With Quote
Old 02-04-2014, 07:26 PM   #10
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
So what do i want for my autocross build? Sorry for thread jacking
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 02-04-2014, 09:24 PM   #11
Well, first question... what class are you going to run?
sosick (02-04-2014)
Old 02-04-2014, 10:04 PM   #12
itzmik3
DBC Racing
itzmik3's Avatar
honestly. i would leave everything "as is" and see what kind of settings you need to implement to best suit your driving style.
we can recommend anything to you, but that might work for our set up and not necessarily yours
#194 SM
The Following 2 Users Say Thank You to itzmik3 For This Useful Post:
CSG Mike (02-05-2014), sosick (02-04-2014)
Old 02-04-2014, 10:44 PM   #13
sosick
fastest frs in sbg
sosick's Avatar
Ima a newb but a stx
2014 firestorm frs
Old 02-04-2014, 10:45 PM   #14
sosick
fastest frs in sbg
sosick's Avatar
Ok. Another newb question. Are camber plates those top hat things
2014 firestorm frs
recommended alignment shops in Az (tempe/chandler/mesa preferred) Juggles Southwest 1 11-19-2013 03:33 PM
RCE yellow springs. Expected alignment settings after install. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-24-2013 02:48 PM
BRZ EQ Settings Marcoscrdo Electronics | Audio | NAV | Infotainment 1 01-02-2013 04:35 PM
Settings for TCS and AT atledreier Scion FR-S / Toyota 86 GT86 General Forum 3 08-20-2012 09:36 AM
EQ settings chadz Electronics | Audio | NAV | Infotainment 2 07-15-2012 09:18 PM
