Old 06-06-2015, 09:46 PM   #1
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
Possible clutch wear?
So lately (last two days) I feel like my engagement Point on my clutch has changed or moved up a little (I have to travel the petal higher to hit the engagement point) , maybe a half centimeter. To the point it's been noticeable, I have to almost have the clutch petal all the way out to hit the engagement Point.
Note this is my first manual car and I don't ride the car hard, I have good technique (from the feedback from my father and uncles). But I've just becoming worried that my clutch is going out. I'm at 9.5k miles.
Romanov is offline   Reply With Quote
Old 06-08-2015, 01:47 AM   #2
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Hey buddy, whats up?
The FR-S has a odd clutch pedal. I noticed the same. I tested the BRZ, same as well. Stock clutch, you should press all the way down before engaging. It's not a big issue on 2-6th gears but downshifting or from a stop, 1st gear is where you notice it the most. I'm not sure if it might be a Subaru issue, or norm, but it is my first manual vehicle where the clutch is picky.
Just press it down all the way, check your fluid for your car, and you should be fine. If you do notice a leak/odd behavior, then go take it to mechanic or dealer.
I've put 4-6k miles already, and I'm used to it now.
My problem is going from full stop to first. I stall or jerk a lot, especially when I have loud music and cant hear the engine. Normal behavior on a stock FR-S.
Packofcrows is offline   Reply With Quote
Old 06-08-2015, 02:08 AM   #3
humfrz
I doubt that the clutch is wore out after only 10K miles of normal use.
Clutches do wear and springs in the pressure plate will weaken a bit over time, which may be what you're feeling.
I'd suggest you check the clutch fluid level.
If the difference in engagement point bugs you, you could adjust the clutch.
Another possibility is that the clutch system needs bleeding.
As long as you have "free play" at the top and bottom ..... the clutch won't hurt itself .....
humfrz
Old 06-08-2015, 07:18 PM   #4
Romanov
Romanov's Avatar
humfrz
Thanks for you response, I checked my clutch fluid level and it looks close to max. It just felt like a sudden difference for the travel of the pedal, kind of freaked me out (paranoid about burning my clutch). There is still some free play at the top and bottom still, but now that it is so high i might need to do that clutch adjustment.
Hello!, thank you for your response. I try to always push in my clutch all the way when engaging 2-6th. It makes my shift time slower but less chance of me wearing on my clutch. I'd say i'm fairly proficient at driving manual, just paranoid about wearing my clutch down. I can start smoothly, but normally i try to take my foot off the clutch petal as fast as possible (but not to the point where i'm dropping it at every start)
Old 06-09-2015, 01:09 PM   #5
SamGam
Drives: '13 BRZ SWP 6MT
To check your clutch wear get cruising at about 40mph then shift to 6th and give it full throttle. If your rpm needle zips to redline and you aren't moving any faster, your clutch is wearing. Otherwise maybe the cable linked to the clutch is stretched/worn, not sure about this option maybe someone can chime in.
SamGam is offline   Reply With Quote
Old 06-09-2015, 01:13 PM   #6
fika84
fika84's Avatar
We don't have a cable linked to the clutch. It's all hydraulic.
fika84 is offline   Reply With Quote
Old 06-11-2015, 09:12 PM   #7
SamGam
Good to know for future troubleshooting.
Clutch wear and pedal adjustment mike the snake Engine, Exhaust, Transmission 4 10-29-2014 03:30 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
