Old 10-27-2014, 04:26 PM   #1
mike the snake
Clutch wear and pedal adjustment
As the clutch wears, the disk gets thinner.
This has the pressure plate moving in, towards the flywheel, as the disk wears and gets thinner.
The throwout bearing moves in the opposite direction of the pressure plate.
So as far as the adjustment at the pedal goes, as the clutch wears, at the pedal it should feel like it's getting tighter (engaging earlier) correct?
Old 10-28-2014, 11:18 AM   #2
humfrz
I don't believe you will be able to notice a difference in pedal play due to clutch wear ....
humfrz
Old 10-28-2014, 12:27 PM   #3
mike the snake
I'm trying to visualize the whole thing because so many people have issues with clutches a few thousand miles after installing (hard to get into 1st/dragging clutch) and many other people I see are recommending to LOWER the clutch adjustment.
This to me this means the clutch itself gets pushed in less. As you push the pedal, there's more pedal deadband before the clutch begins to be pushed on.
I personally raised my adjustment, so I have only maybe 1/2" dead pedal before I feel the clutch start to actuate, and so my clutch gets pushed in further, which opens the clutch more.
It made it easier to select 1st, and easier to launch in 1st.
BUT, as the clutch disk wears, it may tighten my adjustment up even more until the throwout bearing is being spun all the time, unless I stay on top of making sure I have the 1/2" of deadband pedal.
Other cars I've owned they suggested adjusting for the 1/2" of deadband pedal, not lowering the adjustment.
It just seems everyone is adjusting their clutches backwards to how I adjusted mine.
Old 10-29-2014, 12:04 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
humfrz
Correct, sir. No more than you can feel your brake pad wear through the brake pedal.
If anyone wants proof, pop the hood and compress the clutch fork into the slave cylinder. One pump of the clutch pedal and presto...
Mike, I hear ya because I also remember the days of clutch cables. Plenty of time spent twisting the wingnut both under the hood and behind the wheel.
Old 10-29-2014, 03:30 AM   #5
kbye
kbye's Avatar
Drives: 2014 FR-S
Correct me if I'm wrong, but aren't all modern hydraulic clutches self-adjusting? So the engagement point remains the same throughout the life of the clutch?
kbye is offline   Reply With Quote
Gas Pedal Adjustment ML Cosmetic Modification (Interior/Exterior/Lighting) 32 05-01-2017 09:26 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Clutch pedal height adjustment, just do it Suberman CANADA 0 10-24-2013 06:00 PM
Feels sluggish after clutch pedal adjustment brianhj Engine, Exhaust, Transmission 6 08-24-2013 12:58 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
